Author Topic: 1977 CB750K Cafe Racer Project - $$ Can't Take It With You  (Read 19898 times)
Re: 1977 CB750K Cafe Racer Project - $$ Can't Take It With You
« Reply #100 on: April 14, 2019, 01:11:36 PM »
They look good.
« Reply #101 on: April 14, 2019, 01:41:52 PM »
Finished the front fender and mounts.  I used 1/4" round bar and wrapped it over the top of the fender - proved to be a challenge to follow the contour of the fender but I got it.  I
Outstanding job getting the radius just right.
Offline BRAD CHIEDUCH
« Reply #102 on: April 14, 2019, 02:44:16 PM »
Thanks for the positive remarks guys!  The rear fender mount proved to be the most difficult because it is at a more laid back angle than the front which makes it really difficult to get the radius right.  It didn't fit as nice as the front but sometimes you just have to say good enough!
Buzzin' like a blue-arsed housefly.
Offline river
« Reply #103 on: April 14, 2019, 06:13:38 PM »
Damn those fender braces are sexy! Nice work!
Squirrel 1.0 http://forums.sohc4.net/index.php/topic,127186.2050.
ml
Squirrel 2.0
http://forums.sohc4.net/index.php/topic,176846.msg2055831.html#msg2055831
Squirrel 3.0
http://forums.sohc4.net/index.php/topic,185362.msg2146449.html#msg2146449
« Reply #104 on: April 14, 2019, 06:25:15 PM »
What! 1/4” material on a metric bike! Blasphemy  >:(
I'm the nut on the bike and I'm pretty standard! ;)
« Reply #105 on: April 14, 2019, 06:54:36 PM »
Looked like 6.4mm to me..
Offline mkoski
« Reply #106 on: April 15, 2019, 06:06:09 AM »
That front fender is AWESOME! Beauty work!
« Reply #107 on: April 15, 2019, 06:20:51 PM »
I can't take any credit for the actual fender.  It came from Rogue motorcycles out of Australia.  Not sure if Billy is a member on the forum but if anyone is looking for the same fender that's where it came from.
« Reply #108 on: June 01, 2019, 07:56:49 PM »
I had a little time to tinker today and thought I would mock up the hand controls today.  What should have been an easy task turned out to be anything but!   >:(  The problem was there was not enough clearance between the throttle cable cam and the inside of the throttle housing.  Once I clamped the throttle housing down on the handle bar the throttle would not turn freely.  The Rizoma grips are supposed to be "universal" and come with a series of different sized cams to fit in different housings.  However, even with the smallest diameter cam it was rubbing inside the housing.  I thought I could file down the cam a bit but there just wasn't enough meat on it so I turned my attention to the throttle housing.  The first throttle housing I tried was an Emgo Chinesium unit that really didn't work well at all.  I got a second housing from Motion-Pro which fit a little better and the throttle turned but still rubbed .  I guess I could have put shims between the throttle housing halves to give some clearance but that would have opened up a gap along the split line and would drive me nuts.  So rather than surrender I made a fixture for the throttle housing (upper half only) and using the boring bar on my lathe I was able to open it up a tad and now everything works the way it should.  It was frustrating but I should no better by now that every piece of Chinesium I buy just doesn't cut it!  As for the Motogadget pushbuttons, bar end signals, and mirrors ... always top notch stuff!
