Author Topic: wonder what this is gonna look like...  (Read 4919 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: December 26, 2006, 12:47:48 PM »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: wonder what this is gonna look like...
« Reply #1 on: December 26, 2006, 01:11:32 PM »
Gotta love great stuff !
Offline puppytrax
« Reply #2 on: December 26, 2006, 03:37:30 PM »
...Is that half of your gas tank laying on the lift???   :o
(I recognize that rear wheel/caliper/brake assembly!)   ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline paulages
  • 1976 cb735
« Reply #3 on: December 26, 2006, 05:04:24 PM »
that's half of another tank sitting on my lift. i first considered using it as the dummy section to stretch the stock tank (and haven't totally ruled it out), but decided that glass would be easier to work, and will allow me to customize the shape much easier.
by the way "Great Stuff" is not all that great stuff to use here. that particular brand of expanding foam dries soft and spongy, and is hard to sand. can't remember the brand name that has worked best for me, but it is a polyurethane expanding foam, and sands very easily. just came from the shop, and i'm covered in foam dust...  ::)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #4 on: December 26, 2006, 05:35:09 PM »
Looks like my shop sucks compared! ;D
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline kghost
« Reply #5 on: December 26, 2006, 06:57:06 PM »
I use that green stuff people use to put flower arrangements together.
Dirt cheap and really easy to sand.
If I can't walk across my shop in white socks its time to clean it  :D
Stranger in a strange land
Offline paulages
  • 1976 cb735
« Reply #6 on: December 26, 2006, 07:04:03 PM »
i started off in that shop with 6 or so hondas crammed between a boat, a VW squareback "arts car," and a pile of my landlord's other crap in about 100 sq. feet. now, 2 years later, i share the entire 1400 sq. ft. with 7 other friends---most of whom are members on here (mr. blasty, southbound, billdramp, whodareswins, and toddthreat)---and have shared welding equipment, blasting cabinet, grinder/buffer, parts washer, etc. i'm pretty lucky. oh yeah, and the rent is $200.  ;D ;D ;D
kghost--the main thing i like about the expandable foam, is that the base can be formed right around the frame or whatever else you are working around. also, if you shave too much, you just add more and wait for it to set up. i tried 2" rigid foam glued together at first, but it was too much of a pain getting the underside cut out to fit the frame.
« Last Edit: December 26, 2006, 08:13:55 PM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline kghost
« Reply #7 on: December 26, 2006, 07:08:31 PM »
Yeah I sure know what your saying.....
Had that exact same issue.
The green flower foam you can even carve with your finger. I just make a block by gluing a bunch of 2 inch pieces together then push it on the frame.
Where ever it makes an indentation I carve it away with a spoon.
Its like butter that stuff.
Offline pddpimp
« Reply #8 on: December 26, 2006, 07:56:16 PM »
Which kind of fiberglass matting are you going to use? Just wondering if one works better than the other. And how many layers are you going to put on?
I can picture it done and it looks great in my head.
Have a good one ;)
When the majority of the United States population get to be 70 years old, they will finally realize what is really important. And by then it'll be too late.
-'77 CB750 Cafe/Muscle bike (early clone)
Soon to have a hopped up 836cc *sold*
-'75 CB750 with a little bit of character
Offline paulages
  • 1976 cb735
« Reply #9 on: December 26, 2006, 08:09:02 PM »
i'm going to lay fabric on top, then remove the foam and lay several layers of chop mat beneath it for strength. that way, i won't have to visualize the whole thing 1/8 thinner than it will actually be.
for the seat, i'll finish the exterior exactly how i want it to be with body filler or polyester glazing putty, then use this as a plug to make a mold. this will allow me not only to make a couple more, but to have a nice thick, smooth layer of resin as the top layer of the finish product.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #10 on: December 26, 2006, 08:42:18 PM »
         Paul,
                Judging from your previous work, I'd say that it is going to look fantastic!
                                                           Later on, Bill
Member # 1969
Offline paulages
  • 1976 cb735
« Reply #11 on: December 26, 2006, 09:14:55 PM »
thanks, bill. don't curse me though!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #12 on: December 26, 2006, 10:40:10 PM »
Is that a Yammy XS triple rear wheel/caliper?
If so, I'm curious how you managed to get around the shaft drive issue.
CB750K4
Offline paulages
  • 1976 cb735
« Reply #13 on: December 26, 2006, 11:46:01 PM »
i'd never let a yamaha anywhere near my stand! the only non-honda guy in the shop (with two old trombone-company yamahas) is sequestered clear in the back corner! ;D ;D
the bike in the picture is actually a 1976 cb750F,  with stock rear brake and wheel.
« Last Edit: December 26, 2006, 11:47:40 PM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline puppytrax
« Reply #14 on: December 27, 2006, 03:49:39 AM »
Hold your head up to the monitor so we can all see it.   ;D
Offline bill440cars
« Reply #15 on: December 27, 2006, 06:40:40 AM »
                                         Sorry Paul :-[, I'll try to refrain from that. ::) ;D ;)
        Later on, Bill :) ;)
Member # 1969
Offline dusterdude
« Reply #16 on: December 27, 2006, 01:28:16 PM »
yea bill,why you cussing at him? ;D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline tramp
« Reply #17 on: December 27, 2006, 03:08:28 PM »
i see something there
rough,dirty,unfinished yet refined
1974 750k
Offline bill440cars
« Reply #18 on: December 27, 2006, 04:36:11 PM »
            Couldn't help yourself could you duster. ::) You've been showing good restraint and then, you just can't take it can you? ??? ;D I figured that you'd been doing some cat napping and that's why I hadn't heard much out of you lately. :D Back up and read the post just before yours dude. ;D
            Seriously duster,
                          You take care and I do hope that you and your family are doing well and get into the New Year with a breeze. ;)
Member # 1969
Offline dusterdude
« Reply #19 on: December 28, 2006, 08:21:08 AM »
yea,ive been jonesing to lay a zinger on ya,thanks for the opportunity ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline paulages
  • 1976 cb735
« Reply #20 on: March 11, 2007, 05:05:29 PM »
got sidetracked with other projects, but got back at the tank this weekend. next stage: bondo...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline scunny
  • don't call me expert
« Reply #21 on: March 12, 2007, 01:26:02 AM »
I wish I  did mine that way, getting a good finish with glass seems a pain in the butt. I have just applied "fairing compound" on mine, and will be covered in crap when it gets sanded, hopefully that will give the desired look.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline jonbuoy
    • My rebuild:
« Reply #22 on: March 12, 2007, 03:00:56 AM »
Great tip thanks
Offline paulages
  • 1976 cb735
« Reply #23 on: March 12, 2007, 10:59:46 AM »
i've found the absolute easiest route a combination of sandable spray foam and a DA sander. i was using an electric orbital sander at first, and when i switched to the DA set as a grinder, it became incredibly easy to sand (using a 40 grit).
note: none of the spray foams i have tried seems to be dissolvable by anything i can find. this would be a clear advantage to stacking rigid or using the flower stuff (no idea if it dissolves either though). also, i highly recommend going with the glass cloth instead of chop matt. it's really easy to work around corners and curves, and is really thin. i layed up three solid layers over the whole thing, and three more towards the front where i won't be able to access the back side if it's not strong enough, but the whole thing is rock solid--no chop matt backing seems necessary.
more pictures tonight..
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline gtyler5
« Reply #24 on: April 29, 2007, 10:28:15 AM »
How then do you get the foam out of the tank? I am doing the same process here and thought acetone would dissolve the stuff but was dissapointed with my "test" blob...
1976 CB750F cafe
1978 CB750F (in progress)
1993 CB750 Nighthawk
