Author Topic: Weird, relentless, cb750 starter button/wiring issues  (Read 3668 times)
Offline cshanek
    • ahuiz.com/shane
« on: October 04, 2017, 03:53:51 PM »
Greetings SOHC friends,
I have a 76 cb750 that a friend gave me last year. I replaced the entire wiring loom (it had a major short), rectifier, ignition switch, and handle bar switches this year. I bought both handlebar switches from VintageCB750 (http://www.vintagecb750.com/products/5/electrical/90/handlebar-switches). I also have a nice 73 CB500 that I rewired at the same time (and installed the same switches). So now down to the problem. I have wired, rewired, checked connections, checked diagrams, tested, and rewired, and for the friggin life of me I cannot get any action out of the starter button. I spent so much time on this that I actually assumed the switch was bad and sent it in for another, and whalla, same problem. Everything else works (though the winker isn't blinking either which is weird, and I am 99.9% sure the winker is fine. I can kick start the bike just fine and she purs like a kitten. I can also run the starter solenoid connections to the battery and the starter moto immediately turns. So my questions to you, the salty, savvy SOHC masses are:
How do I narrow down the problem? Should I run alligator clamps across the 2 sets of wires for the started switch assembly to bridge the "on" and "run" switches in case they are never engaging? Should I hook up my multi-meter to the rats nest (currently exposed) where the switch connects and look for power when I hit the start button? I am almost out of ideas here. I would use some of my older switches (which worked) for testing, but the soldered piece inside became detached, and apparently my shotty soldering job didn't fix it that well.
I will post rats nets pictures also if that helps. it is getting late in the season here in CO, and I just want to ride my bike.
« Last Edit: October 04, 2017, 04:02:47 PM by cshanek »
Offline Desert-SOHC
  • It's old
Re: Weird, relentless, cb750 starter button/wiring issues
« Reply #1 on: October 04, 2017, 04:45:29 PM »
From what I can tell from the wire diagram, the switch grounds the solenoid for the starter.  I would say bad ground at the handle bars.  Take the switch apart and scrape the paint off where it contacts the bars and see what happens.  Had the same thing happen with my horn switch, and that was the issue.
But I'm a K8 guy and mine is a completely different wiring setup
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Keith
« Reply #2 on: October 04, 2017, 06:01:35 PM »
Clutch needs to be pulled on later models...Bad switch?
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #3 on: October 04, 2017, 06:48:00 PM »
The 76 k6 has the headlite off during cranking feature. The wiring harness and controls are different and exclusive from any years before or after, (I think).... Your harness and controls are correct for the k6?
« Reply #4 on: October 04, 2017, 06:52:41 PM »
Clutch safety?
« Reply #5 on: October 05, 2017, 01:54:55 AM »
Easy to miss that small switch and its wiring into the headlight bucket. This is when the neutral switch  does not indicate neutral so the bike can be started with gear in as long as the clutch is used. Neutral lamp is lit when gear is in neautral?
« Reply #6 on: October 05, 2017, 03:44:16 AM »
The 1976 F model 750 has that headlight feature but I do not believe the K model 1976 does.
Offline cshanek
    • ahuiz.com/shane
« Reply #7 on: October 05, 2017, 08:20:42 AM »
I will take a look, though the would have been a problem on the new switch I initially got, and its replacement.
« Last Edit: October 05, 2017, 08:22:31 AM by cshanek »
Offline cshanek
    • ahuiz.com/shane
« Reply #8 on: October 05, 2017, 08:23:39 AM »
I ordered them specifically for my bike (year, make, model, K6) from a place that only sells parts for old 750's so I assuming that is all fine.
Offline cshanek
    • ahuiz.com/shane
« Reply #9 on: October 05, 2017, 08:28:40 AM »
Interesting. I road this bike around a few times last year before rewiring it and I don't remember the clutch feature though I might have forgotten that from continually using my 73 500. I will run home and test this tonight. Seeing that I have spent about 2-4 hours testing parts (replacing them from my working 500), and continuity, I will feel like a complete idiot if this works.
Offline magnum56
« Reply #10 on: October 05, 2017, 12:50:06 PM »
You're not a complete idiot ... unless you give up !
Patience grasshopper.    ;)
'74 CB750K
Offline cshanek
    • ahuiz.com/shane
« Reply #11 on: October 09, 2017, 07:12:28 PM »
    UPDATE .... >:(
    So the #$%*ing nightmare continues. I again rewired and tested everything tonight, and the following were my takeaways:
    • It is not a neutral issue. The bike was in neutral, and neutral indicator light was on when I attempted to start. I also tried engaging the clutch, and tried in gear as well
    • The battery is charged and happy
    • The coils get hot when the ignition is on
    • Other than the indicator lamps, the brake light, and the horn, absolutely nothing happens when the ignition is in the middle position. Tail light is not on, though front light was.
    • When the ignition switch is in the full-on position (what the hell is this position called?) the indicator lamps, the brake light, and the horn works. The turn signals are solid when switched, and the headlamp and taillight worked
    • There are a couple of connectors that aren't being used (don't match with anything). A blue brown connector to the buzzer on the fork, and a brown/red connector from the harness.
    • I tried another ignition switch (the original) and that didn't change a damn thing, so perhaps I have narrowed it down to everything else electrical on the bike.
    • At this point I am thinking long and hard about taking the #$%*er in somewhere. I have spent a ton of time on this and at some point of time or another replaced the whole harness, ignition switches, solenoid, rectifier, fuse box/assembly, handlebar switches, turn signals, and headlamp.
« Last Edit: October 09, 2017, 07:14:48 PM by cshanek »
« Reply #12 on: October 09, 2017, 07:25:22 PM »
    UPDATE .... >:(
This sounds like bad fuseholder clips. VERY common.
Disconnect the battery (at least the (+) terminal) and/or unplug the fuseholder from the main harness. Remove teh fuses and take a small penknife and scrape the insides of the fuse clips. If they are dark (and probably are), the chromate has let go of the metal clip and is acting as an insulator. This can heat up and melt fuses, or it can prevent them from passing current at all. That's why I started making the ATC Blade fuseholders for these bikes. Also, the glass fuses (SFE automotive type) have not been made since the late 1990s, so any fuse you have in it today will not survive road shocks very long, and will fail while riding. The glass fuses we can get today are not shock-rated: they are merely instrument fuses.
The keyswitch may also be a problem, if you have not replaced it, or if it is the EMGO replacement switches commonly (and incorrectly) sold as the switch for this bike. The EMGO switch can only carry about 8 amps, and the 750 uses 12 amps when the lights are on. This destroys the EMGO switches, often by melting the wires right off the back of the switch! Mine did it on I-25, just north of Centennial airport, in morning rush-hour traffic at 75 MPH.
Offline cshanek
    • ahuiz.com/shane
« Reply #13 on: October 09, 2017, 07:29:15 PM »
I tested the ignition switch tonight (it is new), with the original and the behavior didn't change. the fuse box is also new (because the connectors had broken off the original box) so I replaced that as well earlier in the year (along with handlebar switches, loom, rectifier, solenoid, winker, and turn signals).
Offline Gene
  • Chat enuf you too can be a
« Reply #14 on: October 09, 2017, 07:32:45 PM »
The brown/red goes somewhere and should be used, but I don't have a diagram in front of me. The buzzer lead should be taped off so it doesn't ground out.
When you replaced the harness were you sure to make the ground to bare metal on the frame? Forgive me if you've already stated that.
*1973 CB750K3 (Bow)
Offline cshanek
    • ahuiz.com/shane
« Reply #15 on: October 09, 2017, 07:37:34 PM »
On second question, I have not stated that, but yes there is a ground on the left side I believe on the frame behind the side cover. It is pretty large. Not necessarily apples to apples but I redid my 73 500 at the same time, and though I am having charging issues currently, everything else seems to work great, and the are very similar.
Offline Gene
« Reply #16 on: October 09, 2017, 07:43:36 PM »
You need to be sure that ground is to bare metal and not painted metal. That was my only concern.
*1973 CB750K3 (Bow)
Offline cshanek
    • ahuiz.com/shane
« Reply #17 on: October 09, 2017, 07:46:11 PM »
ah, I understand. I will check but the frame was not powder coated.
Attached are some pics from tonight, the buzzer connector, the mysterious brown/red female from loom, and the winker.
Offline cshanek
    • ahuiz.com/shane
« Reply #18 on: October 09, 2017, 07:54:09 PM »
Just tested the ground and it's good. Ran clips from battery to frame also.
« Reply #19 on: October 09, 2017, 08:00:15 PM »
Br/R is headlight power, fuse to bar switch
Winker connections should be black and grey.
Offline cshanek
    • ahuiz.com/shane
« Reply #20 on: October 09, 2017, 08:02:03 PM »
I have black, white, and green for some reason.  I have been using (or attempting to use black and white)
Offline Gene
« Reply #21 on: October 09, 2017, 08:04:49 PM »
Black and white is to the coils
*1973 CB750K3 (Bow)
Offline cshanek
    • ahuiz.com/shane
« Reply #22 on: October 09, 2017, 08:07:04 PM »
Interesting, the harness connection for the winker has black, white, and green, which I think (just by memory) is the only three connectors of those kind.
« Reply #23 on: October 09, 2017, 08:09:15 PM »
The only white wire on the wire diagram is for the headlight connection, in the headlight bucket for low beam running to/from the Hi Lo switch on the bars.
Where is your white wire located?  Is it dirty white?  I.E. grey?
The green is used when three terminal flashers are installed.
Black with white stripe is for the coils.
Offline cshanek
    • ahuiz.com/shane
« Reply #24 on: October 09, 2017, 08:12:26 PM »
I have a white wire, along with blue and green (I think all from memory) to the headlamp. It is possible the non-OEM harness I bought, again from VintageCB750 is just colored weird. In fact I think if you look at the white, it has little, hard-to-see red lines at points on it.
