Author Topic: CB550 Cafe project  (Read 5221 times)
Offline nbcam
CB550 Cafe project
« on: October 06, 2017, 11:45:55 AM »
Decided it was finally time to start a project trend, this is my first trend so take it easy  :D spent weeks looking on craigslist and eventually bought this bike about two months from a local guy here in Boston, he did not have the bike running for about 3 years. I've grown up around bikes and cars so I have always wanted to build myself a cafe racer. Here is the condition of the bike when I bought it, it was in good condition overall.
Before I started any work on the bike  I wanted to get the bike running so I done  the 3000 mile tune up, disassembled the carbs and cleaned them using carb cleaner, carbs were not too dirty so I kept all the OEM brass and just replaced the o-rings and seals. Set the float height on the carbs before I put them back on the bike.
Carb Jets:
Main Jet #98
Slow Jet #38
Float Height 22mm
Changed the Oil and filter, Spark plugs and Changed the points as they were well worn. Also set the ignition timing and valve clearance on the bike. Tested each spark plug for a spark off the frame and noticed that i had no spark on cylinder 2, broke out the multi-meter and tested the coils, all looked good so I narrowed it down to a bad spark plug cap.
Points Gap:
Standard point gap = 0.012in - 0.016in or 0.3 - 0.4mm
Spark Plug Gap:
0.02 to 0.03in or 0.6 to 0.7mm
Valve Tappet Clearance:
Inlet = 0.002in / 0.05mm
Exhaust = 0.003in / 0.08mm
Got 4 new spark plug caps and put them on the bike and had a spark on all 4 cylinders, I then gave the tank a quick clean and put the carbs back on the bike and reassembled the air box. Charged up the battery and hoped for the best !!!
Put the battery in and went to start the bike, I was surprised how easily the bike started  ;D and sounded pretty good too. Everything looked good no major leaks or issues, with that being said i only had the bike running for about five mins !!
 I wanted to have the bike running before I start any work. Next step is to strip the bike down and decide on seat options etc. Sorry for the lack of pictures I will get more uploaded shortly
Re: CB550 Cafe project
« Reply #1 on: October 06, 2017, 01:35:47 PM »
Cursed Photobucket strikes again!
Offline nbcam
« Reply #2 on: October 08, 2017, 04:00:02 PM »
sorry guys only noticed this now, ill see if i can change the settings on photo bucket, not that familiar with photo bucket that this was the easiest way to upload pictures
Offline nbcam
« Reply #3 on: October 31, 2017, 07:50:15 PM »
Being slacking big time on this trend, had a crazy few weeks at work, good news is I've still managed some time to work on the bike. Finally got a work around with the pictures
Bike when I bought it:
Carbs were not too dirty but I ended up disassembling them and soaking them in carb cleaner from auto zone and replaces all seal.
Had issues with no spark, set the timing and checked coil resistance, all looked normal ended up being a bad spark plug cap !!!
I then got stuck into striping the bike down and began the process of bagging and tagging everything, the end result !!
After some advice from site members (cannot remember your name, my bad ) I striped the paint off the tank and frame using aviation paint removal gel, worked a treat !!
Quick wire brush and the end result
Quick sand and polish of the tank, hard to see very bad picture and poor basement lighting
Offline nbcam
« Reply #4 on: October 31, 2017, 07:57:35 PM »
Currently the tank and frame is at a local custom shop, getting a hand made seat installed, going for the round open back style seat
Pictures don't do it justice but I like the style and fits well with no frame modifications
« Reply #5 on: October 31, 2017, 10:41:34 PM »
That's a nice piece.  Can you provide more details? Who made it?
Offline nbcam
« Reply #6 on: November 01, 2017, 06:06:24 AM »
The seat is made by cafe cycles in RI, the guy has a shop there and mainly builds cafe racers, had some nice bikes around the shop when I went to visit, seen a video of one of his bikes on YouTube and really liked his seats
I'm sure he won't mind but these are some of the bikes he has got on his Facebook page
I seen the GT 380 in his shop when I went to visit very nice looking bike up close
« Last Edit: November 01, 2017, 11:51:17 AM by nbcam »
« Reply #7 on: November 01, 2017, 08:44:20 AM »
I assume that seat is aluminum.  Are you relocating your electronics or keeping the side covers?
Offline nbcam
« Reply #8 on: November 01, 2017, 12:00:45 PM »
yes the seat is aluminum, TIG welded on both sides and smoothed to a mirror finish. Yes my plan is to relocate the electronics, I will see when I get the seat and frame back if there is enough place under the cowl for the battery and electronics. I plan to install a slim battery and M-Unit on the bike. If there is not enough place I will go with a small tray under the seat
« Reply #9 on: November 01, 2017, 03:13:37 PM »
+1 that seat looks nice.
The GT380 looks great too, but would've like to see some high performance tires on it rather than Firestone tractor tires!
Offline nbcam
« Reply #10 on: November 01, 2017, 06:21:54 PM »
Yeah I'm looking forward to see how it looks on the frame
You will be glad to hear, he posted he had new tires ordered so the Firestone tractor tires might be going
Offline nbcam
CB550 Cafe project
« Reply #11 on: November 01, 2017, 07:02:23 PM »
While the frame and tank are at the shop I have decided to complete some of the easier tasks
I striped the front and back brakes. Back brakes look in good shape might just replace the springs
Plan to replace both front disk / rotor and pads, both are in poor shape
The brake cylinder piston and seal will be changed also, the piston looks fine do you usually need to replace both or could I get away with changing the seal ??
Learned the hard trying to remove the brake pads as it was near impossible, had to reconnect the master cylinder bleed the brake and push the piston out that way.
Any suggestions on what type of brake disk / rotor, pads and piston rebuild kit to buy ??
« Last Edit: November 01, 2017, 07:05:17 PM by nbcam »
« Reply #12 on: November 01, 2017, 07:20:57 PM »
Piston appears to be fine unless there is pitting that can be felt with your fingernail. Or get a phenolic one [link below].
Def order a new seal, clean clean clean the inside of that caliper, especially the groove. And paint or polish.
The rotor could be sent to Godffrey for thinning and drilling [lighter weight] and I like EBC pads.
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/
Offline nbcam
« Reply #13 on: November 02, 2017, 08:04:06 PM »
Think I will get away with just replacing the seal, I will put the brake calipers in the ultrasonic cleaner ?
Do you guys think this is a good or bad idea, once the seal is out, can I do any damage to the caliper ??
Plan to use the Godffrey thinned and drilled brake disk thanks for the link
Orders a few new parts today:
•Brake calipers seal
•Front pads
•Master cylinder rebuild kit
•Rear shoe springs
•Front fork seal and dust caps
Plan to spend the weekend cleaning and getting the calipers and forks ready for the new parts
Offline nbcam
CB550 Cafe project
« Reply #14 on: November 02, 2017, 08:10:00 PM »
Got pictures from the shop today, they started to mount the seat today, this is it just mocked up, looking forward to see what it looks like with upholstery on it, let me know what you think all feedback appreciated
Offline nbcam
« Reply #15 on: January 10, 2018, 06:49:19 AM »
Slowly getting back at this bike, got the fork seals replaced and painted them gold
Plan to send the front rotor to Godffery and get a thinned and drilled disk for the front
Going to tackle the front wheel bearings next
Offline Chris_Stiles
« Reply #16 on: January 10, 2018, 08:33:37 PM »
HEY good call on Pete, everything he makes is really nice, I just ordered a type 5 seat from him and am waiting to see leather samples.
Offline nbcam
« Reply #17 on: January 11, 2018, 05:33:12 AM »
thanks  :) Pete is a top guy to deal with, I am very happy how the seat turned out, got him to fit it also he done a good job and would highly recommend him.
Offline nbcam
« Reply #18 on: February 21, 2018, 07:48:12 PM »
Have being working on the bike the past few nights, decided I would change the swing arm bushings. Little bit of a struggle to remove the old bushings, ended up using allot of heat and a drift along with an internal bearing puller
Used a hone to clean up the insides of the swing arm
Got the replacement bushings from kenosha_kid on eBay, I know they are not as good as the sets Hondaman makes but I could only afford these for now.
Heat up the swing arm and used a threaded bar to press the bushing back in
Pretty sure I know the answer to this bit the swing arm collar has some wear on it, should I replace this and if so can these be bought original or any good replacements out there ?? Below is a pic of the wear on the swing arm collar
Sent from my iPad using Tapatalk
Offline Mike Something
« Reply #19 on: March 08, 2018, 01:52:34 PM »
What paint did you use for the fork? I wanted to do a GSXR swap and love the gold, this might due until I find a good deal on a new fork!
Offline nbcam
« Reply #20 on: March 12, 2018, 10:33:17 AM »
Hey,
I wanted to do a GSXR fork swap also but did not have the funds so sprayed these with Rust-Oleum Metallic Gold, paint and primer in one and then a few coats of clear coat.
Offline Marissa
« Reply #21 on: March 19, 2018, 08:20:21 AM »
NBcam,
If that's the only worn section, I would measure it with a caliper or micrometer and check to see how worn in it is. If the difference between that and the inner diameter of the swingarm bushings is too much, you should replace it. I forget what the specs are exactly but I think Hondaman has some specs listed on my thread if you'd like to check it out.
Nice project so far!
1984 Nissan 300zx - sold
2016 Ford Fiesta ST - daily
1972 Honda CB500 - infinite work in progress
Instagram- marissasimos
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #22 on: March 19, 2018, 10:39:55 AM »
      I am liking this 550 build. I actually started on one myself, Life happened and I never got back to it. Maybe this time, after I take care of a few things, I can actually get back on mine. And I also like your treatment on the forks. Your attention to detail, says a lot too.  ;)
Member # 1969
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #23 on: March 27, 2018, 07:43:23 AM »
yeah, and bonus points if you don't butcher the frame
I like berries.
Offline Godffery
  • Godffery's Garage
« Reply #24 on: March 27, 2018, 09:39:42 AM »
•Front pads
•Rear shoe springs
Thanks for the recommendation for my parts & services Man!  That link is now defunked, (my web sight went down in Flames) but till I get a new one up & running, you can find me on FaceBook :  https://www.facebook.com/godfferysgarage/
