Author Topic: 1975 CB550F Levers and Brake Light Switches  (Read 1155 times)
Offline ceebee
« on: January 09, 2018, 06:14:18 PM »
Hey guys, quick question on brake light switches from the lever.
For some reason, and I guess it must be by design, there are two ways my bike does it. I have a hardware switch on the lever itself, AS WELL AS a pressure switch from on the banjo. Both work fine independently of each other.
Is this commonplace and necessary? From what I can tell in other threads, it is either one or the other, not both. Perhaps it's a redundancy thing!? Because to clean up the front end and perhaps swap out the levers I am thinking of just letting the pressure switch do its job and be done with it.
Thanks all!
CB
Re: 1975 CB550F Levers and Brake Light Switches
« Reply #1 on: January 10, 2018, 07:08:50 AM »
Wondering if your '75 model has a later model master cylinder?
Offline ceebee
« Reply #2 on: January 11, 2018, 02:01:27 PM »
Thanks for the replies guys.
MC may well be aftermarket although it looks about right for the age and others I have seen. In any case, confirms suspicions so may leave out the wires for the hardware switch in future.
Cheers!
