Author Topic: 72 CB500 Restomod - *Update* Sold!  (Read 57247 times)
Offline Scramps
  • Luke Warm, maybe. Not quite a
Re: 71 CB500 Restomod
« Reply #175 on: July 14, 2018, 08:46:58 PM »
Also there’s some really good documentation on this site like original shop and parts manuals. The exploded diagrams have helped me immensely on this project.
This is my first 500, but it’s also my first project like this that I’ve ever dug into.
I’ve learned a lot over the past 7 months or so, and this dude is just about ready to test drive.
Back to the matter at hand, though; I dropped off my tank with a local reputable body shop a couple weeks ago. I have a pretty good rapport with the owner, we give him a lot of business at my day job. I asked if they could smooth out the dents and prime it for me, which they did. I went back to check on the progress yesterday, not expecting it to be ready, but it was done. No charge, which was very kind. I wasn’t able to bring it home though, since I was on my Suzuki.
In preparation for the newly refinished tank, I took some time this evening to reassemble everything. Repainted the engine side covers that had been removed, reinstalled the clutch plates after an overnight oil soak, mounted up the chain guard, fixed some electrical connections, adjusted the clutch, moved some wiring around, and basically did a bunch of things. You get the idea.
I wanted to ask about hardware for the gas cap. The original pins are a little pricey, and I don’t think I have an appropriate tool to install it. I vaguely remember reading about tiny bolts that could be used? Like M3s, maybe? I’m probably gonna go that route.
I replaced my handlebar switches with the ones I was advised not to buy, they’re 1000x nicer than the ones that I had. Very small, very utilitarian.
I finally found a store that has the front turn signal stems in stock, ordered some of those and some dust boots for the front forks.
I’m glad to have had an opportunity to tear into this again, it’s therapeutic.
Offline Scramps
« Reply #176 on: July 15, 2018, 11:09:32 AM »
I drew myself a new profile avatar
Sent from my SM-P580 using Tapatalk
« Reply #177 on: July 15, 2018, 12:03:04 PM »
Nice job...you an artist or merely talented with the pen?
« Reply #178 on: July 15, 2018, 12:07:08 PM »
HondaMan has replacement screws available along with lots of other cool kits for plug amnd play upgrades like the electronic ignition and his switch saver and control saver relay kits and fuse box kit.
David
Offline Scramps
« Reply #179 on: July 15, 2018, 12:54:34 PM »
I’d like to consider myself kind of an artist, but it’s just a hobby. Thank you, either way!
As for these Hondaman pieces and parts, does he have a website for that stuff? Or do I just need to seek him out on the forums here?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #180 on: July 15, 2018, 07:34:26 PM »
Love the avatar!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #181 on: July 15, 2018, 10:16:41 PM »
Mark has a website sohc4shop.com, our HondaMan denizon of the SOHC4 forums and a great guy.  Mark Paris.  Mark is a former Honda Master Mechanic, now pursuing engineering line of work ...but he builds motors and repairs and modifies them for many list members.  Unfortunately, Denver does not have much of a classic bike scene or very many sohc4 bikes from what Mark tells me.
Contact Mark and tell him why you want and he can tell you if he has it on hand or will need to build a new batch...if something is out of stock.
A tool you should plan on buying if you stay in classic Hondas is a ratcheting electrical crimper, they are the best method of wire termination, far superior to soldering.
David
« Reply #182 on: July 15, 2018, 10:23:29 PM »
You have artistic talent Scramps.  Best to not turn something like that into a business as it sucks much of the enjoyment from it.  Your drawing show good balance, symmetry, proportions and not overdone on detail with good use of shading.  Is it computer, pen, pencil, or other media?
I took art classes in school from Jr High through High School...I enjoyed it very much.  I like pencil, colored pencil, and watercolors... And some mixed media with watercolors.
David
Offline Scramps
« Reply #183 on: July 16, 2018, 05:20:09 AM »
I can’t take credit for the symmetry, the app I used “Painter” on my galaxy tab has a mirroring function. I appreciate the compliments though!
I’ve sketched and doodled and drawn as long as I can remember.
This particular one was from memory. I’ve spent so much time staring at my bike, I know it like the back of my hand.
I took a few art classes in high school as well, it was a good experience.
Offline Scramps
« Reply #184 on: July 19, 2018, 07:32:00 PM »
I got some parts and did some things
Also I never showed you guys my tank after I got it back, it looks so nice
At any rate, I’m nearly done with the lighting (front brake switch doesn’t seem to want to work) Those stalks for the front turn signals were kind of elusive there for a while.
If I’m not careful, I might end up with a real motorcycle one of these days!
Remaining items for getting it ready to test drive:
- new battery
- fix leaky carburetors
- bump stop for center stand
- finish the tank
- fuel filters
I think that’s basically it. I’m not excited about pulling the carbs for the 40th time, but c’est la vie.
Offline Scramps
« Reply #185 on: July 20, 2018, 06:04:27 AM »
10-4. I can fix them when I put the carbs back on
Offline Scramps
« Reply #186 on: July 21, 2018, 04:32:00 PM »
So I scratched up my fork tubes a little bit during reassembly. It’s not enough to freak out about, but it got me thinking; is it possible to have fork tubes resurfaced and rechromed in the same manner that hydraulic rods are restored?
Offline Scramps
« Reply #187 on: July 23, 2018, 07:03:07 PM »
Two of my air screw springs are missing :/
Offline Scramps
« Reply #188 on: July 28, 2018, 09:33:49 PM »
Put the carbs back on tonight, filled them with a little gas and fired the bike up for the first time in a good while. Nice to hear it run, even if it is with crappy rusted out exhaust
Offline Scramps
« Reply #189 on: July 30, 2018, 07:34:08 PM »
Probably not valid, since it didn’t want to idle. Anyway I figure I probably should quit farting around with it until I get the whole intake and exhaust system sorted out.
Offline Scramps
« Reply #190 on: August 04, 2018, 06:43:26 PM »
Put the old rusty 4 into 2s that were on the bike when I bought it back on, since they’re at least intact and comparable to what I want to end up with. Did another plug chop. It idled a lot better with this exhaust, and didn’t smoke anywhere near as much, but it doesn’t look like #3 was burning at all
I think I’ve probably had enough carbon monoxide for one day, so we’ll try to do something else tomorrow.
Oh yeah, I keep forgetting to show you guys my cool shirt that I found at Old Navy, believe it or not
Did I mention it’s super hot out here tonight? Anyway, happy trails
Edit: wrong department store attribution for the shirt, whoops!
« Last Edit: August 04, 2018, 06:51:29 PM by Scramps »
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #191 on: August 05, 2018, 07:14:03 PM »
Was 3 wet when you pulled it?
Offline Scramps
« Reply #192 on: August 05, 2018, 08:10:04 PM »
yeah, I think #3 is flooding
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #193 on: August 07, 2018, 01:51:16 PM »
Check fire. If its got heat it's def flooding. PO had my carbs all out of whack when i got it. Mine cb500 carbs are sitting on a 74 550 atm
Offline Scramps
« Reply #194 on: August 10, 2018, 10:54:16 AM »
Offline Scramps
« Reply #195 on: August 10, 2018, 07:41:04 PM »
I made some nice rudimentary sheet metal side covers, inspired by Born Motor Co. I'm gonna have them painted to match the tank and headlight bucket. Looking back at the pictures of my progress so far, I'm sticking with yellow. A yellow-orange with a white strip and pinstripe along the bottom.
Whoosh!
Offline Scramps
« Reply #196 on: August 15, 2018, 01:05:37 PM »
Nope, scratch the side covers, not happening.
Offline Scramps
« Reply #197 on: August 17, 2018, 03:37:39 PM »
I got the bike running well enough to brave a short jaunt around my front yard last night, which was exciting, first time the bike has moved around under its own power since god knows when.
Clutch doesn’t release until the lever is almost all the way out, but that seems to be a common thread with these.
#3 is still flooding. Read some threads from people who had similar issues. I need to borrow my friend’s timing light and get a GOOD battery, since the one I’ve been forcing to work should have been recycled 2 years ago.
Either way though, exciting times! Got to actually RIDE the thing!
Til next time,
Keep on Sohc-ing
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #198 on: August 18, 2018, 06:32:23 AM »
Throw some coka a cola and a asprin in the old case might get more life out of it. Beennthere done that a few times.
Offline Scramps
« Reply #199 on: August 22, 2018, 03:54:31 AM »
Finally got my hands on a compression tester, and after some fully open choke, fully open throttle testing, I was able to confirm all four cylinders are close to 150psi cold. I didn’t have time to do a warmed up test last night, but I’m reasonably satisfied that I do have at least decent compression.
