Author Topic: 78 Intake Boots vs. 75 Intake Boots?  (Read 1780 times)
Offline jrrobertsjr
  • If you aren't scared, your not going fast enough.
« on: January 04, 2007, 12:57:38 PM »
Due to a potential solution for another problem I may have (vacuum leak), I started doing a bit of research on intake boots.
I called my local Honda Dealer and they can get the boots. The question is which set to get.
I have a 78K motor and carbs off a 75K.
16211300030 INSULATOR,A.CARB
16212300030 INSULATOR,B.CARB
When I looked up the part numbers, I found that the 75 boots were 2 different part numbers for 1-4 and 2-3. No problem there. That is the setup that I have now.
The 78 boots however were 4 different part numbers.
16211405000 INSULATOR 1,CARB.
16212405000 INSULATOR 2,CARB.
16213405000 INSULATOR 3,CARB.
16214405000 INSULATOR 4,CARB.
The ones for the 78 look completely different. Is this due to the updated carbs?
Offline dusterdude
Re: 78 Intake Boots vs. 75 Intake Boots?
« Reply #1 on: January 04, 2007, 12:59:54 PM »
from what i understand the 78 carbs have a larger throat inlet,but im not sure of the inlet on the head.someone more versed than me on the almighty k8 would have to answer this better.good luck
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline jrrobertsjr
« Reply #2 on: January 04, 2007, 01:06:07 PM »
Cool.
Thanks, Duster.
I hope he sees this and gives it his input.
Johnny out.
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: January 04, 2007, 01:15:20 PM »
   The 75 boots will fit both the carbs and your '78 motor. The '78 carbs are larger diameter, as Duster' points out, so the '78 boots are larger on the carb side, but the intake manifolds on the '78 K engine/head are the same size as a '75 engine.
   Not sure why there are 4 different part #'s for the '78 boots. The ones I have(78 F) are two types, 1&4 or 2&3, just like the setup you have now.
Offline jrrobertsjr
« Reply #4 on: January 04, 2007, 01:30:13 PM »
Excellent. Thanks again for the second time today, Scondon.
100 bucks for the 4. WOW.... Ramen noodles for another two weeks. Again!
« Reply #5 on: January 04, 2007, 10:06:39 PM »
Ramen noodles are great. 17ยข per meal from King Soopers (Krogers, etc) this week still allows for cheap beer and motorcycle parts too!
ajames86
« Reply #6 on: September 14, 2010, 01:37:21 PM »
any idea if I can get a different year to fit my 78 F? cant find the damn things anyplace.
Offline mick750F
« Reply #7 on: September 14, 2010, 03:43:33 PM »
   You can try here...http://www.classicmotorcyclesolution.com/1_7_Products.html
Mike
Glosta, MA
