Author Topic: 1977 CB750A Aluminum Rims Swap to CB750K8  (Read 1574 times)
Offline teamtiger21
« on: March 02, 2018, 11:16:42 AM »
I have the opportunity to obtain some very nice 1977 CB750A aluminum rims for use on a CB750K8 Cafe project. Are there any direct swap issues? Are there any issues with the 17" vs 18" rear tire for handling? Thanks Barry
Offline Bankerdanny
  • Endeavor to persevere
Re: 1977 CB750A Aluminum Rims Swap to CB750K8
« Reply #1 on: March 02, 2018, 01:04:18 PM »
Your K8 should have come with a 17" rear originally if I recall correctly.
At any rate, there should be no fitment or handling issues.
Offline Desert-SOHC
  • It's old
« Reply #2 on: March 02, 2018, 03:31:32 PM »
They bolt right up, I have a set on mine.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline teamtiger21
« Reply #3 on: March 03, 2018, 07:58:58 AM »
Thanks, it's a plan!
Offline beemerbum
« Reply #4 on: March 04, 2018, 02:25:25 PM »
750 A front on my K7. No issues whatsoever. Now I have matching wheels. I'm thinking of going to somewhat heavier fork oil to compensate for the much lighter new wheel. ATF in the forks now./
Offline DV Red Herring
  • Army RETIRED
« Reply #5 on: March 04, 2018, 05:34:06 PM »
What would be the benefit, if any, to putting these wheels on my K4? I like the aluminum look. I'm not sure if there may be a performance difference though.
« Last Edit: March 06, 2018, 06:29:49 PM by DV 750 Red Herring »
« Reply #6 on: March 04, 2018, 06:43:15 PM »
What would be the benefit, if any, to putting thsee wheels on my K4? I like the aluminum look. I'm not sure if there may be a performance difference though.
pretty nice weight savings gets you better acceleration, handling, and braking.  Plus those rims are just way better quality so your wheels should be rounder.  That is something you can really feel.  The chromed steel wheels found on most 70's jap bikes were really just built to a cost.
Offline fireman1073
« Reply #7 on: March 05, 2018, 04:05:32 PM »
Here’s my 75 k with Hondamatic rims
Offline Desert-SOHC
  • It's old
« Reply #8 on: March 05, 2018, 09:57:32 PM »
I did 10wt and was MUCH happier with the ride.
11 Ranger S/C 2wd
Offline beemerbum
« Reply #9 on: March 06, 2018, 07:46:16 AM »
Thanks, sounds like a plan. 10 weight it will be. Another thing I learned with this new wheel: To make sure the tire is seated properly, I reduced the pressure and rode the bike for a mile. I then pumped it to the correct PSI and rode the bike again. Before I did this, I had an up and down vibration in the wheel. Someone suggested the above to let the tire seat itself better. It worked.
