Author Topic: 1973 cb350F valve job question  (Read 733 times)
Offline epicracer
« on: June 20, 2018, 01:33:57 PM »
Am working on a 1973 cb350f for a friend of mine. We rebuilt the carburetors , new spark plugs, rebuild front forks. Then that's when it got interesting.
She started right up but had a weird idle. At first I imagined a sync was needed, so we proceeded to attempt a CARB sync. It showed cylinder 3 with an erratic vacuum. After starting it again I noticed fuel blowing back out of the carburetor. This meant 1 thing to me. Valve adjustment must be way off. Starting with a cold motor I adjusted the valves and performed a compression check. All cylinder checked out except piston 3. tried putting a little oil to diagnose bad rings and was not able to improve the compression.
So the question. Can I perform a Valve job with out removing out the cylinder jug? I will inspect the cylinder once I am in there, but would prefer to not have to change the base gasket . Or should I just plan on removing everything including the cylinder jugs?
thanks in advance for the comments and advice!
Offline innovativems
    • Innovative MotoSports
Re: 1973 cb350F valve job question
« Reply #1 on: June 20, 2018, 02:00:16 PM »
Yep you can pull the head without the jugs.  But its probably not a bad idea to replace the base gasket and rings with a home while in there
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline cjespersen
« Reply #2 on: June 26, 2018, 10:35:50 PM »
