Author Topic: What's the difference between early and late transmission?  (Read 1104 times)
Offline Scott
  • 72 CB750
« on: August 30, 2018, 06:13:33 PM »
Hi there
I'm wondering what the difference is between early model and late model transmission and cush drive please for a CB750.
Thanks
Scott
Re: What's the difference between early and late transmission?
« Reply #1 on: August 30, 2018, 06:16:12 PM »
For one, the gear on the sprocket shaft and its mate, are different than early ones.
 Can be changed as a set.
Offline Scott
  • 72 CB750
« Reply #2 on: August 31, 2018, 02:44:32 AM »
G'day Frank
I have nothing to start with but empty cases.  Does it matter what year model as to what I put in them?
Cheers for all and any thoughts
Scott
« Reply #3 on: August 31, 2018, 05:42:23 AM »
I believe that you can put any year set in the empty case, hopefully somebody will confirm it.
I will be assembling bottom half for Dorothy this winter - her 2nd is gone - and I have a later set of gears I hope can use.
Offline rotortiller
« Reply #4 on: August 31, 2018, 01:40:56 PM »
I  know the later xmission/engine cases require a different rear wheel hub assy build to match up if transplanted to an earlier bike so I'd advise a close look at that area as being prudent.
