Author Topic: 74 cb450 help  (Read 1284 times)
Offline innovativems
    • Innovative MotoSports
74 cb450 help
« on: November 06, 2018, 12:34:45 PM »
So i'm banging my head on a bike i'm working on.  I'm working on a 74 cb450 and it's fighting me.  Guy is on a budget and we are at the top of it already.  Came in with a completely dead battery and a stuck float.  So carbs are spotless, carbs are synced, float level set, oem float needles and when taking it out, when you get to about 1/2 throttle just falls on it's face and won't pull out of it.
Doesn't matter if it's cold/warm, applying choke slightlly, with or without the filters.  I have not done anything with the ignition side as my head kept saying it's got to be fuel related.
So logically ignition is next up right?  i was going to check timing, and that advance is working.
Thoughts?
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline tbpmusic
Re: 74 cb450 help
« Reply #1 on: November 06, 2018, 12:59:08 PM »
By all means set the gap/timing (they're interrelated on a 450).
Make sure that advancer is working even when hot.
Bill Lane
Offline jaytee-nz
Re: 74 cb450 help
« Reply #2 on: November 06, 2018, 01:30:08 PM »
Those are CV carbs IIRC. Check for small splits / air leaks in the carb diaphragms.
Re: 74 cb450 help
« Reply #3 on: November 06, 2018, 01:36:34 PM »
Thanks guys for the tips.  One thing to add is, it's only with a load on it, with no load, it's working fine on the stand.  I'll dig into timing tonight.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline tbpmusic
Re: 74 cb450 help
« Reply #4 on: November 06, 2018, 07:19:42 PM »
What color are the spark plugs showing you?
Bill Lane
