Author Topic: Perished rusty warning light bulb holders  (Read 2090 times)
Offline 58webbing
« on: December 09, 2018, 06:43:32 AM »
Some of my warning lights didn't work, the reason was clearly age related, replacements were not available apart from overpriced replica boots which woud have involved removing all connectors etc to assemble. As I have some hobby CNC machinery I came up with the following solution which might be of interest. First off I removed the old boots and cleaned up as best as possible the corrosion. Without disassembly the holders were pickled in an acid bath to remove the old plating and rust. Next, into the zinc plating tank and passivation, so far so good as the holders now looked new. I designed a similar looking replica boot in 2 parts made from 3mm ABS (DXF files attached) and after about 15 minutes machining its time for assembly using acetone to bond the joints. As the original boots had the push in part still flexible I cut that part off and slid it over the bulb holder. I now have a visually similar and more importantly working light cluster. The attached photos show the whole proceedure.
Re: Perished rusty warning light bulb holders
« Reply #1 on: December 09, 2018, 06:53:21 AM »
slick work!
Offline JamesH
« Reply #2 on: December 09, 2018, 07:35:50 AM »
That really clever work. Love it...
Sent from my iPhone using Tapatalk Pro
Offline Scramps
  • Luke Warm, maybe. Not quite a
« Reply #3 on: December 09, 2018, 10:25:13 AM »
very nice, I'd imagine those will hold up better than the originals.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #4 on: December 31, 2018, 11:20:33 AM »
This should get a better write up amd be moved tonthe #$%* that works section of the forum!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
