Author Topic: Headlight fuse blowing, battery hitting 15.5v, regulator bad?  (Read 6096 times)
Offline jorwesflow
  • we're not schizophrenic
« on: February 18, 2019, 03:22:15 PM »
I've recently been blowing a lot of headlight fuses, and noticed that charging is hitting between 15-16v at idle to 4k rpm.
I'm about to go through TT's tests http://forums.sohc4.net/index.php/topic,1012.msg8345.html#msg8345 but wanted to see if there are any initial thoughts from anyone. Are the fuse and overcharging related? Bad regulator?
Gonna go through those tests and report back.
1977 CB550K
Offline jorwesflow
Re: Headlight fuse blowing, battery hitting 15.5v, regulator bad?
« Reply #1 on: February 18, 2019, 04:22:56 PM »
First off, I’m pretty far removed from stock.
Begin with problem verification and characterization with recorded data.
A -- Fully charge a known good battery.  Let it rest for 2 hours, off the charger, and measure the battery voltage.  (Target is 12.6-12.8V.)
I'm getting 14.7v on a rested battery  :o This is a fairly new—probably less than 10hrs riding—Antigravity 4-cell LIFEPO4. It's my second one. The first lasted me almost 4 years!
B -- Start the bike and measure the battery voltage at idle, 2000, 3000, 4000, and 5000 rpm.
This is where I'm getting 15v and higher. I know that Antigravity does states they do not want their batteries charging at anything higher than 14.6v. So hopefully I haven't fried this battery already.
C -- Repeat the measurements of B with lighting off.
Part B was with no lighting, since I have the headlight disconnected.
Worth noting: i've got the same voltage reading between the battery terminals, and then between the black wire and ground with the ignition switch on.
The above tests identify charging system success, failure, or degree of "faulty".  The success voltages are listed in the Shop manual.
D -- Assuming the above indicates faulty, do check the RECTIFIER diodes with a diode tester or ohmmeter capable of testing diodes and uses more than .7 volts to make the test(s).
Of the twelve test made in D, six must read low ohms and six must read very high ohms.
Not totally sure how to do this with my combo reg/rect
E- assuming no faults were found in D,  Measure the white and green wires disconnected from the REGULATOR.  CB750s should 6.8 ohms - ish,  CB550s/350s/ and 400s should read 4.9 ohms- ish.
I’ve got 4.2ohms here with the multimeter switch on 200.
F- If there are no bullet holes or road rash/divots on the alternator case, the stator is probably good.  But, you can check for yellow to yellow continuity (.35 ohms) among all the wires, and that no yellow wire has continuity to the engine case.
I’ve got 1ohm between all the yellows. That too high?
No yellows have continuity to ground.
G- Assuming no faults found in D, E, and F, measure the disconnected terminals of the REGULATOR.  The black and white terminals should measure zero ohms (subtract meter error if there is any).  Higher than Zero ohms, indicates internal contact contamination needing cleaning and attention per shop manual.
I’m getting 9 on the 20k setting on the multimeter (sorry, not sure how to express this in the proper way). I assume this is not good? Again, this is an aftermarket reg/rect that cannot be opened and serviced.
I'll just stop there since I seem to have hit a bad result. I'll wait for any feedback.
« Last Edit: February 18, 2019, 04:29:49 PM by jorwesflow »
1977 CB550K
« Reply #2 on: February 18, 2019, 04:29:22 PM »
Lloyd's procedure is more geared towards under charging, not over charging. You have a regulator problem.
« Reply #3 on: February 18, 2019, 04:34:01 PM »
This assumes a stock mechanical regulator.
« Reply #4 on: February 18, 2019, 05:01:25 PM »
If the Vreg is not getting a true report of  actual battery voltage, it can overcharge, even if it is working correctly.
When using a multimeter, set to lowest range and note the display when the probe touch each other.  This reading must be subtracted from all future resistance readings.
I recommend you measure the voltage lost between the battery terminals and the Vreg voltage input terminals.  Normally this is the black wire and the green wire and both paths back to battery should be measured.
Voltmeter probes on Batt POS terminal and Vreg Black input.  (With ALL Lighting ON).  Write down V reading.
Voltmeter probes on Batt NEG terminal and Vreg green connection.  (With ALL Lighting ON).  Write down V reading.
Sum the two readings and you have the error voltage the regulator is seeing compared to actual battery voltage.
You can repeat the test with lighting off, which will likely show less error.  But, voltage report errors over 0.5 V indicates wiring , connectors, fuses, or switch contact issues.
My test procedure was intended for stock vehicles with a mechanical regulator.  The B/W resistance test results will not be the same for aftermarket components, as silicon devices behave differently than a switch contact.
« Reply #5 on: February 18, 2019, 06:27:08 PM »
 According to Murphy's law a headlight will usually protect a fuse by blowing first. You got lucky.
« Reply #6 on: February 19, 2019, 09:21:43 AM »
Murphy was proven to have poor engineering skills.
But really, headlights are more prone to filament failure with inertial shock application than over voltage.  Though over voltage will make shock vibrations more effective at filament breakage.
The stock headlight mounts had vibration isolation for reliability reasons.
« Reply #7 on: February 19, 2019, 09:52:47 AM »
McGinties 3rd law is the real #$%*e
"If something can physicaly be fitted backwards, no matter how stupid it looks, some idiot some where will do it"
« Reply #8 on: February 19, 2019, 10:10:49 AM »
Very often problems with the aftermarket (hot?) running regulator/rectifier combos.
I have never heard about problems with stock charging setup except for corroded connectors, broken/shorted wires, damaged battery and not serviced charging system according to Honda CB750 shop manual ch 8.
Offline Spanner 1
« Reply #9 on: February 19, 2019, 06:50:09 PM »
Meh, I know my regulator is allowing about 15.5volts to the battery on my K1 750, don't care . My headlight is nice and bright  ;) Some day I'll clean all the connectors on the bike and try to reduce the  1.5v voltage drop at the Black terminal on the regulator. Common on these old bikes  but not a ride killer unless you fell victim  to an ill advised ' electronic' 'update ' where a steady 14v is necessary for ignition function  ;D
« Reply #10 on: February 19, 2019, 08:20:30 PM »
That is batterycide. :o
« Reply #11 on: February 20, 2019, 03:31:46 AM »
My stock CB750 charging system gave occasional too high voltage ( LED supervision alarmed 1 minute or less). I adjusted the screw on the regulator and it was sorted. About 1/4 turn out, maybe a little bit more. I had adjusted it to maximum before due to 3 ohm coils I later replaced with 5 ohms.
Constant voltage supervision with a LED is very convenient. My latest build got one too.
https://www.ebay.co.uk/itm/LED-Motorcycle-Battery-Alternator-Charge-monitor-level-indicator-warning-bike-G/200826330214?hash=item2ec22e9c66:g:QWIAAOxyY9VROzRz:rk:25:pf:0
« Last Edit: February 20, 2019, 08:42:08 AM by PeWe »
Offline pjlogue
« Reply #12 on: February 20, 2019, 06:50:08 AM »
I would make sure all your wiring connectors are giving solid connections and make sure the wiring harness is in good condition.  A bad corroded connection between the battery and regulator sensor wire can give a high voltage output because the regulator is seeing a false low voltage.
-P.
« Reply #13 on: February 20, 2019, 09:30:32 AM »
On the original mechanical regulator, the adjustment is a safety level to prevent the battery from overcharge.
It is NOT, I repeat NOT a system level adjustment for voltage.  The system voltage level is the domain of the battery charge condition.  The Vreg is adjusted so that the battery will never get above 14.5 14.7 V, and that saves the battery from cooking, losing large amounts of electrolyte, which would in turn allow alternator voltage spikes to cook diodes, etc.
If you can't resist mucking with things you don't understand and must tweak the Vreg, do so with minimum load on the electrical system and have the alternator revved to make as much power as possible, with a known fully charged battery.  Under these conditions, adjust for 14.5-14.7 V at the battery.
Now, if lighting is on and and the battery voltage goes too low, you either have placed too much load on the system, or something is broken besides the regulator.  If the voltage is too high and the regulator does not see actual voltage of the battery, you have a reporting path to fix on the bike.  The vreg can't do it's job with lies reported to it.
The Vreg adjustment is the point where the alternator is told to back off it max ability to charge the battery, which varies with RPM and electrical load.  Tweaking that screw changes that safety level.  It does not make the alternator put out any more than ever capable.   It is the wrong way to compensate for system connection losses, and has the potential to damage batteries, and the diodes in the charging system.
I still think the "Voltage Regulator" was misnamed, as it is, in reality, a battery protection device.  The Battery charge status is what actually controls the system voltage.  And even in stock form, the alternator cannot meet max system demands at its lowest RPM.  And, the Vreg can't do anything about that condition but ask the alternator to do more (which the alternator cannot do until it's revved up).
FYI
Offline jorwesflow
« Reply #14 on: February 20, 2019, 01:58:50 PM »
Thanks, TT. Got some readings.
0.39v
Quote from: TwoTired
0.23v
Sum the two readings and you have the error voltage the regulator is seeing compared to actual battery voltage. voltage report errors over 0.5 V indicates wiring , connectors, fuses, or switch contact issues.
That would be 0.62v  :-\
I assume this should more or less be equivalent to the difference between these readings:
Battery reading with lights on, bike not running, switched on = 12.52v
Regulator Black and Green reading, bike not running, switched on = 11.92v
So the reg is getting an underreported voltage. I know there is a process to tracking down the culprit with a multimeter—I remember doing it years ago—I just need a refresher.
1977 CB550K
« Reply #15 on: February 20, 2019, 02:36:55 PM »
Consider a path from battery to regulator, there are a number of wires and devices in that path, fuse switch wire, etc.  The voltmeter probes placed on each side of the any chosen device will report the voltage difference in to out on the display.
I guess I am most surprised to see that much loss on the  ground return path.  It's double what I would accept.  Can you define that route?
You will never get zero loss in any pathway, as all components have some resistance.  Everything usually works ok if the total error report to the Vreg is  under 0.5V.  But, if your battery needs 14.6V max to survive or keep warranty intact.  You will have to beef up connectors, switches, fuses, and wiring to get to those engineering specs.
Offline Bodi
« Reply #16 on: February 20, 2019, 03:25:04 PM »
The ground drop is surprising, the battery ground cable should be rather heavy gauge (roughly 6AWG I think) and, since it's a short cable, resistance and voltage drop should be very very low. Have you relocated the battery and run long cables? Once the ground connection is in the frame, resistance is also quite low. So the drop is probably coming from the wiring harness... where is it grounded, how much wire and how many connections are between there and the regulator?
For the "+" voltage drop, an easy fix is to add a relay switching directly (through a fuse!) from battery + to the regulator power input. Relay gets switched on via a black wire - switched power from the keyswitch.
But: with a lithium battery that's not to be fully discharged or be forced into overvoltage, your regulator - designed for lead-acid batteries - may be a problem. I think that models designed for lithium batteries are available. The problem of voltage drop - making the regulator think the battery voltage is lower than it really is and allowing overvoltage - affects any regulator. I would solve that first and see what your max battery voltage is (fully charged battery, lights off, ~4000RPM).
There is no good way to prevent deep discharge in these bikes (other than making sure there is no electrical draw when off, and avoiding use of the parking light). Well designed devices that use lithium batteries will have controllers that disconnect the load when voltage gets dangerously low: that is not an easy modification to our bikes' electrical system and I have not heard of any home mechanics doing it or anyone marketing a protection system to do it.
Offline BenelliSEI
  • 1969 cb750
« Reply #17 on: February 21, 2019, 06:02:54 AM »
Just read this. In response to your very first question: “ blowing head light fuses”, have you checked the fuse box? In my experience, these are the worst culprit. Fuse mounting clips weaken, overheat, melt the actual case, get looser, overheat more, blow constantly..... an endless circle of events. They can be the cause of intermittent misfires, sudden death shut offs and flashing lights! Watch out. They get hot enough to burn fingers, before they pop.
Offline jorwesflow
« Reply #18 on: May 09, 2019, 08:26:16 PM »
I know it's been a couple months, but I wanted to close this out. I finally got around to working on this and just finished buttoning everything back up.
I threw out the old fuse panel, which I had attempted to salvage and re-solder many times through the years—but finally just tossed it. I used some inline ATM style fuses instead. I also rewired a few things, and removed some unneeded lines since I don't use the starter and I'm kick-only (my 4cell Antigravity battery can't handle the cranks). I also redid a bunch of bullet connectors.
No more overcharging, and the headlight fuse has been fine. The regulator is operating as it should as well.
I don't know exactly wha the culprit was causing the increased resistance—although it could have been a sum of several bad connections. Regardless, all good now!
1977 CB550K
Offline Deltarider
  • I'm back
« Reply #19 on: May 10, 2019, 07:41:38 AM »
Yeah... and all that time you've managed to conceal what bike it was about. Anyway, owners of a CB500 that happen to have the airfilter case removed, can easily access the regulator from under the seat (see pic) and perform precautionary maintenance. The second pic shows what state of the connectors you can expect to see on a 45 year old bike.
CB500K2-ED Excel black
Offline rotortiller
« Reply #20 on: May 10, 2019, 08:44:46 AM »
The voltage regulator is called such for a reason. It seeks to maintain a specified system maximum voltage. Anytime the battery is being charged (when current is flowing into it) means the alternator is supplying all electrical demands-lights, ignition and battery replenishing. Easily proven with an amp-meter. The battery is simply a reservoir called upon as intended when alternator rpm is low or nill. The only difference with this system over say that of a car is the under-sizing of the alternators lower rpm output. So basically the regulator  maintains system voltage while it has the capacity to do so. So at that time the battery simply goes along for the ride like a good load bearing device would, drawing what it wants. My stock CB750 alternator typically supplies all load demands after 2800 rpm. People try to make it out to be something else for some reason.
« Reply #21 on: May 10, 2019, 09:20:58 AM »
Philosophical difference, I suppose.
The battery (if it is big enough), and as long as it is well charged, will run the bike safely forever and maintain a system voltage all by itself.  No voltage regulator needed, as never will it provide more voltage than the system can safely handle.  The smaller the battery the faster it will decrease its voltage as the chemicals complete their conversion.
On the other hand, the alternator CAN make more voltage than the system can handle, especially the battery.  The Voltage regulator only limits the alternator output when the battery voltage gets too high in voltage.  It does so by sensing the system voltage, which is dominated by battery charge status.  In it's depleted state, the battery limits the system voltage, no matter if the alternator is going full output.  The battery absorbs all the alternator power it can make, protecting any device from over voltage.
Yes, the Alternator can supply all the bike needs if it is spinning fast enough and has the field excited.  It doesn't do that at idle, and the battery state still dominates system voltage level.  The regulator can't do anything about that, no matter what it tells the alternator to do, it can't make enough power to keep the instantaneous voltage at the set-to-limit state...until the alternator revs.  Then, and only then, can it limit the alternator output to maintain a safe battery charge state and therefore system voltage level.  In practice, it is far more a battery protection device, and nothing else on the stock bike needs a precise voltage operating parameter to survive.  By design, the battery can never make components burn out from over voltage.  And voltage regulation is not needed for that purpose.
The voltage regulator, imo, is rather misnamed.  It is an over voltage protection device.  As that is the only condition where it's activity is needed.   But, it's probably a distinction lost on the average garage parts changing mechanic.
Offline jorwesflow
« Reply #22 on: May 10, 2019, 02:15:31 PM »
Ha oops. 1977 CB550K
1977 CB550K
Offline jorwesflow
« Reply #23 on: July 07, 2019, 01:36:52 PM »
Sorry to dig this one back up, but I've been traveling and have had little time to work on/ride the bike. As of my last post, everything appeared to be working fine in my garage—i.e. charging system working right with 14+ V up around 4000rpm (sitting stationary in the garage). So I took it out for a 20 mile ride and it all seemed great, but as I pulled back up the driveway, she started sputtering out and died and I took the remaining momentum up to the garage door. Seems I barely made it back.
I checked the battery and it read 9v. Looks like something happened during the ride and the charging system stopped working, and drained the battery out. Luckily it charged back up and is holding nicely.
So I went through TT's A to L test ( http://forums.sohc4.net/index.php/topic,134836.msg1515431.html#msg1515431 ) and got hung up on D. Here are my results from the rectifier test using the diode setting on my meter (which uses ~2.4v to test diodes)—I also am not sure what the number value is being displayed on the diode setting, so I'll just write it as I see it... Reminder, this is an aftermarket combo reg/rect I bought from Dime City https://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-electronics-parts-honda-cb350f-cb400f-cb500-cb550-cb750-rectifier-864218.html
POS lead to Red, NEG lead to:
Yellow 1: beep, 0
Yellow 2: beep, 0
Yellow 3: no beep, 1
NEG lead to Red, POS lead to:
Yellow 1: beep, 0
Yellow 2: beep, 0
Yellow 3: no beep, 516
POS lead to Green (ground?), NEG lead to:
Yellow 1: no beep, 487
Yellow 2: no beep, 487
Yellow 3: no beep, 511
NEG lead to green, POS lead to:
Yellow 1: no beep, 1
Yellow 2: no beep, 1
It would appear I've got some bad diodes? But any help deciphering these results is appreciated!
1977 CB550K
« Reply #24 on: July 07, 2019, 08:41:25 PM »
The reported results say you have one bad diode.  If you can't replace that one, you have to replace the whole unit.
