Author Topic: cb500 air filter clip  (Read 2311 times)
Offline dave the welder
  • dave the welder
« on: March 27, 2019, 09:48:55 AM »
a couple years ago someone posted alternative clips that will work to hold air filter in place as original clip is no longer available thanks stock part# 17216323020
« Last Edit: March 27, 2019, 09:51:31 AM by dave the welder »
don't buy it build it
Offline jakec
Re: cb500 air filter clip
« Reply #1 on: March 27, 2019, 10:17:15 AM »
I'd be interested in an alternative to the 400F clip as well so I don't have to pay $30 for one on ebay.
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
« Reply #2 on: March 28, 2019, 01:43:38 AM »
For the 500 go to UK site a member there was making them. For the 400 i think you are stuck with the expensive ones
Offline Little_Phil
« Reply #3 on: March 28, 2019, 02:16:12 AM »
Offline RustyF
« Reply #4 on: March 28, 2019, 04:36:40 AM »
I am missing the clip on my 550 - so far the air filter has stayed in place.  would be nice to have the clip but I would not worry to much about not having it
1978 CB 550 K
Offline jakec
« Reply #5 on: March 28, 2019, 09:57:38 AM »
On the 400 the air filter "leans back" from the airbox opening if you don't have the spring.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline mattsz
« Reply #6 on: March 28, 2019, 10:29:18 AM »
Jake, I'm gonna make one myself... out of heavy coat hanger wire if I have to...  ;)
Offline jakec
« Reply #7 on: March 28, 2019, 12:39:02 PM »
I may have to do the same!
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #8 on: March 28, 2019, 12:39:56 PM »
for the 500/550 I just made a wedge shaped rubber strip that fits in that slot,too easy.
Offline mattsz
« Reply #9 on: March 28, 2019, 12:54:39 PM »
Someone else said they used clothes pins - I'm guessing there's a variety of inexpensive home-made alternatives...
  • dave the welder
« Reply #10 on: March 28, 2019, 01:38:31 PM »
thanks everyone was hoping for the factory clip but no go. plan b
Offline Deltarider
  • I'm back
« Reply #11 on: March 28, 2019, 02:37:35 PM »
If the steel spring that fixates the filter element is not available, you can make one yourself. I have seen that steel used in packaging, to keep cargo together like on on pallets. I was lucky to find some of those steel strips just lying around in the streets. You can also use it for homemade piston ring compressors.
CB500K2-ED Excel black
Offline mattsz
« Reply #12 on: March 28, 2019, 03:31:14 PM »
Good idea - that stuff shows up at my work regularly... keeping cargo together on pallets...  ;)
Offline Jore
« Reply #13 on: March 28, 2019, 09:15:32 PM »
that's what I did
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
« Reply #14 on: March 29, 2019, 01:14:47 AM »
the filter body itself also has a sort of spring bar to it,just wedge anything that's gonna hold it all square and not let the filter vibrate out of position,i chose rubber as its a bit springy and I made it fit that slot so it cant slip out,that steel band you find on brick packs aint springy at all its too soft cheap disposable steel.
Offline mattsz
« Reply #15 on: March 29, 2019, 03:13:01 AM »
Or, as it's commonly known, "spring steel"...
« Reply #16 on: March 29, 2019, 03:15:03 AM »
i don't know what you have where you are but it aint no #$%*ing spring steel!itll just fold.
Offline mattsz
« Reply #17 on: March 29, 2019, 03:25:39 AM »
Just having a bit of fun...  yeah, it folds, but it still has some springback to it and could possibly be made to work, especially if Deltarider has already done it - although he didn't explicitly state that in his post.
Anyway, it's off the subject, but jakec, here in the USA Dave Silver offers clips for the 400 for just $11.  Shipping will bump it up to closer to $20, but if you're ordering from them anyway...
« Reply #18 on: March 29, 2019, 04:37:58 AM »
bit of rubber cost you nothing?
