Author Topic: 400F Frame - Steel type/filler rod recommendation  (Read 1215 times)
Offline bootalini
« on: July 27, 2019, 02:41:15 PM »
I've searched this forum (and the net) looking for this info. I apologize in advance if my questions has been addressed elsewhere.
I purchased a 400F frame that needs most of it's tabs welded back on, including the side stand tab. Luckily, whomever cut the tabs kept them. Seems like the frame was going to be used for a cafe project...although I can't figure out why someone would leave the centre stand tabs but cut off the side stand tab.   :o ??? ::)    Regardless, what type of tubes are used on the 400F? I suspect mild steel and not chrome moly. Any recommendations on a filler rod to use, I'll be TIG'ing.  Thanks in advance.
Jeff
