Author Topic: Gearbox problems CB750 F1 1976  (Read 1184 times)
Offline olasek18_18@o2.pl
« on: October 01, 2019, 06:32:55 AM »
Hello Guys,
18 000 miles ago I was rebuild engine, checked Gearbox, all sprockets and selectors...
In the end of this sezon after 10 000 miles riding I observe my gearbox started working strangely.
Namely, almost every time I change gear, I feel a slight resistance, sometimes I have the impression that it jumps in 2 stages of "click-click"
Gears do not fall out, it is very rare to switch between gears 2-3 ,3-4 ,4-5
I changed oil from 10w50 to 10w40
can oil affect this?
I Have CB550 too and this beauty changes gears very smoothly always.
Do You have the same? Any Suggestions?
Kind Regards
Re: Gearbox problems CB750 F1 1976
« Reply #1 on: October 02, 2019, 04:24:17 AM »
Maybe it's normal in CB 750?
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: October 02, 2019, 11:00:38 AM »
After the rebuild and 10k miles a clutch adjustment is probably a good idea. If the clutch isn't completely releasing when you pull the lever in then you will get extra resistance when changing gears.
I would not think that the weight of the oil will make a difference.
My '76 750F shifts easily, but you can definintely feel it changing gears as you move the lever
Offline halllzy
« Reply #3 on: October 02, 2019, 06:16:31 PM »
I’m not a huge fan of change.
If 10w50 worked, I’d say start with an oil change back to it and see if that makes a difference.  It’s a pretty low cost/time troubleshooting step.
+1 for clutch adjustment
« Reply #4 on: October 03, 2019, 03:19:55 AM »
How are the bolts on the cover?  Did you use paper gasket?
« Reply #5 on: October 03, 2019, 04:51:10 AM »
Ok, so should I regulate bolt/nut inside clutch cover?
Because pulling up the clutch cable only changes the handle position, yes?
« Reply #6 on: October 03, 2019, 04:57:19 AM »
I did use oryginal gasket, You mean regulate bolt inside cover?
Offline Bankerdanny
« Reply #7 on: October 03, 2019, 08:27:37 AM »
Adjusting at the handle does affect more than the lever. You are basically taking out or adding slack to the cable, so too little adjustment at the lever will mean the cable doesn't pull the lever at the engine side as far. But a proper adjustment should start at the engine side, then finish at the lever. If you don't ahve it you can download the factory manual here at the forum with the correct  instructions.
« Reply #8 on: October 03, 2019, 04:59:37 PM »
My 78F motor was sensitive to how tight was the bolt right next to the shifter.   Later on it went away with paper gasket - turns out just Hondabonding the cover influences shifting.
If there is a change in shifting, I would pull the cover and check on the linkage, you might lost or broke a spring for instance.
Offline maxheadflow
« Reply #9 on: October 03, 2019, 08:30:02 PM »
I'll bet it does. You kill the endplay in the shift shaft and cause it to stick.
To OP, Check you shift detent rollers.
Offline brianc
« Reply #10 on: October 04, 2019, 12:39:14 AM »
I have an F2 750 which I had changing gear issues. Not quite the same as you describe, but sluggish, crunchy and generally un- Honda. Oils? Chain? Adjustment? Free play? nope all around. The clutch centre splines that the steel plates run on was worn, preventing full release. A new one would be nice, but I carefully cleaned off the dents and bingo nice clean changes!
Offline Tracksnblades1
« Reply #11 on: October 04, 2019, 02:52:27 PM »
You've must have a few dirt bikes too.
Age Quod Agis
