Author Topic: How do you lace a wheel?  (Read 1822 times)
Offline Jbosma
« on: July 01, 2020, 09:13:21 PM »
Can someone reference a video or a thread or publication that explains how to lace a wheel for dummies???
Yes I took it apart without knowing how to put it back together. Good thing is I do have some extra free time right now.
I own a 1981 CB650 but any general material on this subject would be useful.
Offline dazemc
Re: How do you lace a wheel?
« Reply #1 on: July 01, 2020, 09:48:58 PM »
Before you get into putting all the spokes back on you better also be prepared to true the wheel. I'm not saying that you can't do it, just that I'd be careful with something as important as your wheels if you haven't done it before.
This is a pretty easy to follow guide and it's even a cb wheel that's used in the pictures.
https://bikebrewers.com/lace-motorcycle-wheel/
annnnnd here's a better video than the one they attached to it.... start the video at 29:24
1971 CB500
Offline AlekStooge
  • can't afford cheap stuff
« Reply #2 on: July 01, 2020, 10:02:02 PM »
Seperate your inners and outers. Start with the hub. Put all your inners in or outers in and then do the other. They go in opposite directions. Carefully flip the hub over and do the other side. Make sure whatever you plan on doing to the hub is done before you do this. Good if you have pictures from before, if not someone will.
+1 on truing. Never trued myself so I can't help you there.
This should help explain with pictures.
http://www.rrrtoolsolutions.com/articles/motorcycle-wheel-lacing-for-hub-spokes-and-rim/
« Last Edit: July 01, 2020, 10:13:25 PM by AlekStooge »
Offline pjlogue
« Reply #3 on: July 02, 2020, 01:39:51 AM »
As mentioned above, separate your inner and outer spokes.  Inner spokes are put into the hub from the outside and they have a shorter bent leg on the end.  Put all the inner and outer spokes on one side of the hub.  Have your pattern in your mind and start lacing all the inner (or) outer spokes.  For a 40 spoke wheel each inner (or outer) spoke will skip 3 rim holes and all will go in the same direction.  Then do the inner (or outer) spokes on that side of the rim.  Start your spoke nipples with 1.5-2 turns only!  Be careful with this.  Flip the wheel over and do the other side.  Again be sure to turn the nipples on with only 1.5-2 turns.  Once all the spokes are installed put the wheel on a stand and make a starting point with a piece of taps on the rim.  Proceed to tighten each spoke one right after the other with only 1 turn.  This is time consuming but will pay for its self when you go to true the wheel.  After ~4 complete revolutions of the wheel the nipples will become snug.  make one more go around of tightening.  You are now at the point of being tight enough to start truing the wheel.  No spokes should have a dull/no twang when tapped with a wrench.  If you tightened the nipples like I mentioned above the wheel should be in a state where hop and run out are minimal and truing should be fairly easy.  I do the hop first, then wobble.  This will take 2-3 passes for the wheel to be finished.
-P.
Offline Doobie
« Reply #4 on: July 02, 2020, 02:03:01 AM »
Search here. There are 2-3 extensive how-to write ups. I used them when I laced a set a wheels a few years ago.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline EraZor
« Reply #5 on: July 03, 2020, 08:46:39 AM »
Not sure if your Dutch is up to par (your name sounds Dutch at least ), but I used this many times:
https://www.oudebromfiets.nl/pagina100.html
Offline Jbosma
« Reply #6 on: July 06, 2020, 09:31:01 AM »
All great suggestions thank you!!
This is a huge help!
