Author Topic: Billet Crankshafts  (Read 14653 times)
Offline gschuld
Re: Billet Crankshafts
« Reply #50 on: April 16, 2022, 10:29:04 AM »
George, you're thinking a "retired guy" like Mike should be trying to go faster? He needs to slow down man!
Not nice 😃
George
« Reply #51 on: April 16, 2022, 11:12:29 AM »
It was intended to be nice. He needs to slow down & smell the flowers for a change.
Offline gschuld
« Reply #52 on: April 16, 2022, 02:18:16 PM »
One can easily ride a stroker big bore engine slow, you just have the option of going faster…
George
Offline Tracksnblades1
« Reply #53 on: April 16, 2022, 08:16:43 PM »
George
Nah….it’s not an option. You’ll have to grab a handful, no matter what age.
L, my granddad was still laying rubber down in an old 70 caprice classic 427 before he gave up the ghost😇
Age Quod Agis
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Billet Crankshafts
« Reply #54 on: April 17, 2022, 09:17:55 AM »
Paladin333 on hondachopper runs a turbo and NOS on his amen savior. He always says twist your throttle until you smell 5hit, or see God
« Reply #55 on: April 17, 2022, 03:48:02 PM »
Back in the end days of Funnybike I know guys were running nitrous with the turbo. The nitrous would get you off the line hard and then the turbo would kick in. I can't even imagine what cylinder pressure was at that nitrous/50lb boost overlap period.
« Reply #56 on: April 18, 2022, 08:40:37 PM »
Did it ever come out the bottom..?
Age Quod Agis
« Reply #57 on: April 19, 2022, 05:52:55 AM »
All I saw were a couple of rods bent in the shape of a boomerang.
Offline dragracer
  • CB750F Dragbike
« Reply #58 on: April 30, 2022, 07:21:17 AM »
Keith, when can we expect to see one of your products in an engine and running??
Offline dragracer
  • CB750F Dragbike
« Reply #59 on: April 30, 2022, 08:10:56 AM »
Offline kmb69
« Reply #60 on: May 01, 2022, 05:11:22 AM »
Frank, I hope to have one finished this year.
My current Customer backlog in the shop should be finished in about 30 days at which time I can put some of my own parts in the machines.
Material and tooling are on hand waiting for an available machine. Lots of machine work to be completed for the complete engine build.
I have all my models and programs ready to go, I think. A few pictures attached to show what I am working on.
Offline kmb69
« Reply #61 on: May 01, 2022, 05:13:53 AM »
The main shaft will be spinning faster so the oil pump speed has to be reduced to prevent cavitation.
  • Gusto mo titi ko?
    • project
Billet Crankshafts
« Reply #62 on: May 01, 2022, 05:35:14 AM »
Those are enough crumbs to make a grown man drool! I hope you’re doing good Keith!
Offline kmb69
« Reply #63 on: May 01, 2022, 05:37:40 AM »
This cylinder head should flow about 11% more than Brent's DOHC Super Head according to my calculations.
Straight intakes and straight exhausts. Exhaust pipes barely clear the frame.
Aluminum billet for 7 of each, cylinders and heads, is in house ready for machining.
Offline kmb69
« Reply #64 on: May 01, 2022, 05:39:48 AM »
Thanks Angelo. Doing good here. Hope the same for you.
Offline kmb69
« Reply #65 on: May 01, 2022, 06:30:07 AM »
The DOHC frame provides plenty of head room.
Frame is already completed.
« Last Edit: May 01, 2022, 06:50:56 AM by kmb69 »
« Reply #66 on: May 01, 2022, 08:16:30 AM »
VERY impressive indeed!  ;D
Offline Old Scrambler
« Reply #67 on: May 01, 2022, 08:39:12 AM »
I am now MORE honored to have had dinner with you ;)
Do I see roller rockers?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #68 on: May 01, 2022, 09:09:59 AM »
Very interesting work Keith. VERY!
Offline kmb69
« Reply #69 on: May 01, 2022, 09:18:48 AM »
Thank you, it was my honor and pleasure.
Yep, the rockers have rollers on the shafts and rollers that replace the tappet screws.
Valve adjustment is made with varying thicknesses of valve stem lash caps.
The rocker arm geometry is a thing of beauty if I do say so myself.
Less than 1mm sweep across the lash caps at 11mm lift.
« Last Edit: May 01, 2022, 09:33:45 AM by kmb69 »
Offline kmb69
« Reply #70 on: May 01, 2022, 09:22:55 AM »
Thank you Spanky.
Thank you Brent. 100's of hours "invested"  ;)
« Reply #71 on: May 01, 2022, 09:53:06 AM »
Valve angle?
Offline gschuld
« Reply #72 on: May 01, 2022, 09:56:25 AM »
Impressive Kieth.  May I inquire about valve sizes and intended bore?
George
« Reply #73 on: May 01, 2022, 10:04:29 AM »
Valve angle.....its got some. Valve size...larger than stock. ;D
Offline kmb69
« Reply #74 on: May 01, 2022, 10:04:42 AM »
Valve angle?
Intakes 23.75
Exhausts 24.75
