Author Topic: Question for those with stock 4 into 4 exhaust system,  (Read 2690 times)
Offline DesertKyorugi
  • '87 GS450 '86'87 ZL600 '73 CB500 '70 '71 '71 CB750
« on: January 16, 2021, 11:10:15 PM »
Do you run them with or without the diffusers/baffles? If you don't run them please comment the reason(s). Thanks
« Last Edit: January 16, 2021, 11:47:15 PM by DesertKyorugi »
US '71 CB750K1 Stored for 39 years, currently running
US '71 CB750K1 Currently running
JDM '71 CB750K1 Stored for 21 years, currently running
US '70 CB750K0 Stored for 28 years, currently in restoration
US '70 CB750K0 Stored for 43 years, currently in restoration
US '70 CB750K0 Currently waiting to be restored
US '73 CB500K2 Stored for 40 years, currently running
Offline Deltarider
  • I'm back
Re: Question for those with stock 4 into 4 exhaust system,
« Reply #1 on: January 16, 2021, 11:41:40 PM »
What's a diffuser?
CB500K2-ED Excel black
« Reply #2 on: January 16, 2021, 11:45:14 PM »
What's a diffuser?
I guess I should edit it to include baffles. Diffuser is the db killer/silencer insert in the muffler
Offline gtmdriver
« Reply #3 on: January 17, 2021, 12:06:12 AM »
Stock system with baffles. CB 350F.
« Reply #4 on: January 17, 2021, 01:15:37 AM »
Honda call them for diffusers.
I'm sure it depends on which bike and exhaust model.
-My CB750 K2 has Yamiya no number 4-4 which is same as  HM300 (K0-K1).
It has the diffusers in, restrictive sound muffling "wool" removed.
It work fine with nice sound.
(My K6 with loud Hindle 4-2-1 with long pipe sounds less when crusing in 80-120 kmh. Different when open the throttle!)
Remove the diffusers completely, too loud. Fun for 15 minute ride.
- Same with Lotus Root pipes (Yamiya replicas of the first pipes on the earlier Sandcasts.)
No diffusers way to loud. Diffusers in which I drilled a ring of 5mm holes in each diffusers bottom to improve flow.
- My CB750 K6 had its original very restrictive HM341,  no end plugs in when I bought the bike January 1979. ( Quickly replaced by 4-1)
I doubt it will affect sound much, just a design thing to look like the earlier bikes. HM341 is so restrictive so needles must be in the middle, main 105 while no numbers ends up with needles one step richer, main 115.
This with stock engine, airbox.
This has been repeated on a friends bike with HM341 that could not use my K2 settings last year.
« Last Edit: January 17, 2021, 01:17:52 AM by PeWe »
Offline Deltarider
  • I'm back
« Reply #5 on: January 17, 2021, 03:56:49 AM »
My experience is limited to the OEM 4-4 on the oldstyle CB500 and CB550. These pipes will become louder over time. There's not much you can do about it. To prolong life, avoid short rides and make sure the drain holes at the bottom where the wider mufflers begin, are always free. Owners of K3s may even consider to drill holes in the same spot, since Honda didn't. Realise that most exhausts will rust from the inside! The K3s exhausts were very silent indeed. I love that turbine sound. I hope the repro's, nowadays on offer, are just as good. I hate loud bikes and admire bikes that only have the air intake audible. Yamaha has some fine examples. They hiss. Wonderful! A tip if you - for whatever reason - remove the 4 OEM pipes. Make sure you have pillows, cushions, mattrass or whatever under them, when you do it. I always had at least one exhaust drop to the concrete. There's a serious risk the internal damper, which is no doubt already rusty, falls apart, which will result in a louder pipe.
« Last Edit: January 17, 2021, 03:58:37 AM by Deltarider »
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #6 on: January 17, 2021, 07:05:18 AM »
hm341s i used to run them without the diffusers because that's how i got it.  loud as hell.  bought the diffusers a couple years ago and love the sound now.
cb750 k6 - ugly
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: January 17, 2021, 07:25:22 AM »
My cb750s are on standard HM300 and HM341 pipes. They all have original baffles. My K0 and K1 sound great on the stock pipes. My K4 (on HM341) sound anemic by comparison.
« Reply #8 on: January 17, 2021, 08:16:23 AM »
Your HM300 have the padding around the baffles/diffusers?
Really thick restrictive stuff.
White before use
They muffle the sound some extra, bike a little bit slower.
https://www.ebay.de/itm/221569795096
« Last Edit: January 17, 2021, 08:22:18 AM by PeWe »
Offline BenelliSEI
  • 1969 cb750
« Reply #9 on: January 17, 2021, 08:38:27 AM »
PeWe..... my KO and K1 have an NOS set of HM300’s I found many years ago, in their original cartons. I had to install a few baffles/diffusers in one set. I bought them from JTMarks and from memory, they were very short, no padding of any kind. Those pipes ar a lot louder than any new replica pipes or HM341’s!
« Reply #10 on: January 17, 2021, 09:06:03 AM »
In 09 I drove all night to pick up a 4 pipe bike , to then ride to Bonneville.. a 300 dollar 750.
Iasked if they had pulled the baffles they  said no.. when I went towee it I had a 10mm wrench in hand, before I rode it, I pulked them out.. Them 341,s  then sounded much better, and never went back in...
Offline Johnie
« Reply #11 on: January 17, 2021, 09:57:08 AM »
My KO has the stock HM300's as they came from Honda. With already some hearing loss I left them stock and even wear some hearing protection from wind and exhaust noise.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #12 on: January 17, 2021, 10:06:41 AM »
 I have the Yamiya no number pipes on two bikes, run the baffles in both. I tried running without them once and wasn't that impressed with the difference.  I didn't do any drilling like we used to. I did coat the insides with Eastwood inside the pipe exhaust coating, not sure if it has any effect on sound, probably not. I have a spare baffle with a 1/2" hole in the end that I used to insert the probe for an O2 sensor. I'm not sure it made a big difference in sound either.
« Reply #13 on: January 17, 2021, 10:15:56 AM »
Thanks guys for your answers and opinions. The reason I started this poll is because I am having some doubts about the HM341s that are on my K1.
I purchased my K1 with an almost straight through 4 into 1 exhaust. I added the HM341s and the bike feels like it is holding back when going full throttle from 5k RPM. Since I have never owned or rode any other CB750s, I don't really know how it is supposed to be like.
I have read about the Hondaman mod and have seen most YouTube videos are without baffles/diffusers. I have tested the sound levels with and without diffusers and it is about 2+ DB louder without at idle.
I think at this point I will have to break out the 10mm wrench and take the diffusers off and go for a ride.
« Reply #14 on: January 17, 2021, 10:57:18 AM »
It only takes a few minutes to pull them, won't be as loud as pulling them on 300,s.
What I found with stock pipes is performance  below 3500 rpm , seems better..
« Last Edit: January 18, 2021, 05:21:25 AM by 754 »
« Reply #15 on: January 17, 2021, 12:13:00 PM »
That's strange. Yamiya no numbers look exact as the NOS diffusers I linked to, Honda bagged units for HM300.
Sure HM300?
I saw another old open version, stamped CB750 a friend has.
My Diffusers did not fit as I can recall.
My Lotus Root pipes have really fat ones, as small bombs. No padding around them except for a thin fabric not removable .
« Reply #16 on: January 17, 2021, 01:19:06 PM »
Ig only taies a few minutes to pull them, won't be as loud as pulling them on 300,s.
That's my thinking as well, the straight 4 into 1 is definitely softer under 4000 rpm compared to the HM341s. I regret not riding the 4 into 1 exhaust longer before swapping in the 4 into 4. I never rode it passed 5000 rpm because the bike was still new to me and I was still in the careful first start/run stage after reviving it from 39 years slumber
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #17 on: January 17, 2021, 02:11:49 PM »
My Yamiya “no number” pipes have the diffusers in. They sound very healthy but not too loud. Best 4cylinder bike sound ever.. but that’s just me.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #18 on: January 18, 2021, 04:02:35 AM »
If you did not change jets, richer needle and mains,
a more open exhaust will have bad midrange if carbs are jetted for HM34I that's for sure.
I tried that on my no numbers as initial setup, my old K6 stock setting for 341. Very dull midrange and top.
Same setting as a friends bike with HM341 must have and opposite, he tried my well working setup for my no numbers, too rich for HM341.
4-2-1 often mentioned to give midrange while 4-1 has more at the top.
Later upgrade : (same carb setup)
CI K7 +0.5mm pistons bumps up the compression in a stock K6 head. (K2 1975 need that head design).
K7 cam. Bike is fun to ride and nice sound from the no numbers.
See the graphs, dyno after piston change. Torque horisontal.
The bumpy graphs might have been the dyno that soon after blew a sensor.
My K6 got more stable graphs at higher rpms after Dyno repair.
The torque start at 3500 rpm, 2nd vertical line
« Last Edit: January 18, 2021, 06:11:11 AM by PeWe »
« Reply #19 on: January 18, 2021, 10:03:40 AM »
@PeWe,
I am assuming my K1 bike's carbs were set up for the 4 into 1 exhaust that it came with. I didn't make any changes to it when I swapped in the HM341s.
Two possible scenarios here, one is the carbs were left unchanged when the PO installed the 4 into 1, the other is the carbs were changed from HM300 setup to whatever it is on the carbs now to run the 4 into 1.
I am leaning towards carbs set up unchanged and is the stock set up for HM300. That means the carbs are running richer than what it needs to be for the more restrictive HM341s. I guess I will find out if running without the diffusers would help make it less restrictive and less rich
« Reply #20 on: January 18, 2021, 12:27:54 PM »
My friends K2 running HM341 with my setting for Yamiya No numbers ran obviously rich wich he found out at first ride and changed needles from 4 to 3, main jets from 115 to 105.
Plugs looked sooty too.
« Reply #21 on: January 18, 2021, 02:32:46 PM »
Well, I just pulled the #3 and #4 plugs from my 30 miles ride the other day and the plugs looked fine. Probably can go richer but I don't really want to pull the carbs at this time.
« Last Edit: January 18, 2021, 02:36:42 PM by DesertKyorugi »
« Reply #22 on: January 18, 2021, 02:47:52 PM »
 You could easily drop a bowl and unscrew an emulsion tube with the main jet in it and see what size it is and if its a stock Keihin. Every K1 I have always had a stock #120 in it and as they switched up to HM341's it went down to 110 then 105 by 1975-76.
« Reply #23 on: January 18, 2021, 03:45:16 PM »
  IF I saw that , I would try one step up on the mains..    leaving everything else alone to try it.
 I had an original  set of no numbers,  baffles were quite big... Not sure but think they looked like what the early parts book showed.
« Reply #24 on: January 18, 2021, 05:04:10 PM »
I pulled the main jets and just as I thought they were 120s. What should I go up to if I was going to run the pipes without diffusers? 125? 130? Thanks
