Author Topic: best way to check for oil pressure?  (Read 947 times)
Offline izaleth
« on: February 22, 2023, 07:06:18 PM »
im looking to do a first start up of my new cb 750 project and want to make sure it has good oil pressure, not looking to spend 80$ right now, ive got some pressure gauges laying around, mainly need to know whats a good way to check oil pressure on these bikes? (no lights or anything this bike is motor and frame more or less no wiring at all)
Offline denward17
Re: best way to check for oil pressure?
« Reply #1 on: February 22, 2023, 07:19:06 PM »
Probably remove the oil pressure switch behind the cylinders and connect a gauge there.
« Reply #2 on: February 22, 2023, 07:42:44 PM »
  When I do a first start on a new 750 project bike I leave the oil cap off the tank and peek down inside with a flashlight and look for bubbles and circulation when I first start it. Most of the time I have done an oil change too so I see a drop in the level/volume. All mine though have had the light which is reassuring.
Offline newday777
« Reply #3 on: February 22, 2023, 07:55:36 PM »
Have you done anything to the motor? Have you had it running before now?
Hackaweek has a oil pressure test. He rigged up a pressure gauge in place of the pressure switch as well as checked the rocker shafts for oil flow.
« Last Edit: February 22, 2023, 07:57:20 PM by newday777 »
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #4 on: February 22, 2023, 08:02:41 PM »
Stu
My current rides
Prior bikes....
Offline Mark K
« Reply #5 on: February 22, 2023, 08:31:29 PM »
I wanted to do the same thing, check for oil psi after reassembling engine. I basically did it the way Dino did in his hack-a-week videos, which Newday quoted above. I bought an engine oil psi gauge kit from Harbor Freight, was not super expensive and worked great. I had issues initially of not getting oil psi because I did not prime the oil pump correctly, had to pull the oil pump out and reprime the pump.
https://www.harborfreight.com/engine-oil-pressure-test-kit-62621.html
'13 Yamaha FJR1300, '73 Honda CB750K3 (current project), '19 Kawasaki KLX 140G, '72 Honda CL70K3, '70 Honda SL350 (next project)
Former bikes
'74 Yamaha 60, '72 Maico 250, '74 Kawasaki 250 S1, '82 Kawasaki KZ550, '84 Honda VF700F Interceptor, '99 HD FLSTS Heritage Springer, '97 HD FLHTCUI Ultra Classic '05 HD FLHT Electraglide, '9? Buell Lightning, '03 FLHTCUI Ultra Classic,'14 Honda CRF250L
« Reply #6 on: March 03, 2023, 03:43:42 PM »
Oil gauge permanently in the plug on the right side is the way to go - IMHO.  I have a habit of checking oil pressure at traffic lights and other times when idling.  It also tells me if the engine is fully warmed up.
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: March 03, 2023, 04:49:10 PM »
+1 to that. I set them on the end of a short, 90 degree 1/8 NPT fitting and then screw the guage around until 60 PSI is “straight ahead”. Occasional glances are reassuring. I also carry a spare oil gallery cap should the bike ever “fall over”. If you look closely, that are on most of my bikes.
« Last Edit: March 03, 2023, 04:50:46 PM by BenelliSEI »
