Author Topic: tail light mods  (Read 4079 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
tail light mods
« on: March 14, 2024, 10:09:21 PM »
never been super thrilled with the stock tail light.  i bought a "british style" looking aftermarket tail light from 4 into 1 some years back thinking the screw holes were close enough.  not quite.  please share your tail light mods.  looking for ideas that are close to stock but more sleek.  not into led strip lights across the grab rail or major mods.  i've installed smaller turn signals which i like.  shooting for something that compliments them.  preciate'cha
photo of bike attached
cb750 k6 - ugly
Online newday777
Re: tail light mods
« Reply #1 on: March 14, 2024, 10:47:57 PM »
Have you looked at the 69-71 taillight which is smaller than yours is?
Yamiya has smoked lense and clear lense for them.
https://www.yamiya750.com/index.php?main_page=index&cPath=246_251_185_117
« Last Edit: March 14, 2024, 10:55:25 PM by newday777 »
Stu
My current rides
Prior bikes....
Online newday777
Re: tail light mods
« Reply #2 on: March 14, 2024, 11:05:02 PM »
Stu
My current rides
Prior bikes....
Re: tail light mods
« Reply #3 on: March 15, 2024, 12:51:39 AM »
To fit the earlier light you need the bracket as well as the hole spacing is different, the UK ones had the small light through til 77 i think, check uk ebay and if seller wont ship i will be middle may for post cost
Re: tail light mods
« Reply #4 on: March 15, 2024, 05:11:13 AM »
My K6 has the early light, K1 style.
Bracket and license plate holder and fender needed.
It got the K1 blinkers too.
Europe never got the "brick stone" rear light. ;)
Find a good looking K1 fender with rear light.
Offline BenelliSEI
  • 1969 cb750
Re: tail light mods
« Reply #5 on: March 15, 2024, 06:13:18 AM »
My son fitted the early style light to our K3. The chrome on the bracket was gone, so he tossed it in with some other stuff I was getting powder coated black. I think we used an early fender, to avoid the extra holes.
These lights are available as inexpensive aftermarket units and will work on a “rear fender eliminator” as well (see vintagecb750.com). Personally, I think they are ugly, but seem to sell well.
Offline CycleRanger
  • No comment about being an
Re: tail light mods
« Reply #6 on: March 15, 2024, 06:31:33 AM »
That's neat. I did not know Yamiya offered clear and smoked lenses.
Re: tail light mods
« Reply #7 on: March 15, 2024, 07:22:51 AM »
I like the look of the smaller K1 style tail light but the safety aspect of the larger light!
Wondering if that is why Honda increased the size?
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: tail light mods
« Reply #8 on: March 15, 2024, 07:56:35 AM »
I used the K1 light and fender on my K3. I just like the look better.
I found a NOS setup still wrapped up on Ebay.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
Re: tail light mods
« Reply #9 on: March 15, 2024, 10:55:11 AM »
North American DOT Regs for minimum tail light sizes. The bigger turn signals in ‘75/‘76 for the same reason.
Offline Deltarider
  • I'm back
Re: tail light mods
« Reply #10 on: March 15, 2024, 02:40:57 PM »
Another example of this childish and deeply rooted stupidity that bigger is better.
CB500K2-ED Excel black
Online Don R
Re: tail light mods
« Reply #11 on: March 15, 2024, 04:49:23 PM »
 Here's my K1, I drilled the fender brace welds out, moved the fender up to where I wanted it, cut off the excess and re-welded the fender to the bracket. I was able to hide two welds under the Lucas type taillight, the rest are under the seat. The bolt holes are also covered.
Offline grcamna2
Re: tail light mods
« Reply #12 on: March 15, 2024, 09:57:08 PM »
Do you run that same one on the Rat Race now Don ?
75' CB400F/'bunch o' parts'
Online Don R
Re: tail light mods
« Reply #13 on: March 15, 2024, 11:42:30 PM »
 Yes that's the one, it's a copy of one that came on a drag bike I bought but it didn't have a brace under it, the bolt holes were wobbled out. I liked the look but needed it stronger.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: tail light mods
« Reply #14 on: March 16, 2024, 07:55:54 AM »
I think I'll try to get an LED to fit in the light, it may be a lot brighter.
1973 CB 750 K3
Offline Oddjob
Re: tail light mods
« Reply #15 on: March 17, 2024, 05:57:43 AM »
This may offend some Honda people but I fitted the rear light off an 1980s Yamaha RD250/400. It seems to suit the back end quite well on my 500/4 but the real reason I did it was for safety. Back then I was almost living on my bike, typically 25000 miles a year was put on my engines back then, my 1971 500 has over 260000 miles on it and my 1972 500 has just short of 150000 miles. I found that the rear bulb was constantly failing on both bikes, as it was behind the rider and just a single bulb sometimes you didn't notice the rear light going out until cars were beeping you and you did risk getting rear ended. For a quick fix I'd pull up the rear brake light switch so it sat on top of the frame bracket, that meant at least some light was showing at the back to get me home at night. Eventually I decided a twin bulb setup was a better solution and the Yam light fitted without any modifications except in the wiring and that was simple enough.
As I said this may upset some purists but I'd sooner be safe and avoid unwanted police attention than stick to stock.
I am considering going back to stock on my restoration this time but I'm going to modify the light and fit an LED plate in there instead of the bulb, used to make a decent living on doing LED conversions on car dashes a few years ago and still have hundreds of them lying around. Thinking maybe 30 leds for the tail light and maybe the same for the brake light but of a higher lumen rating, might work might not but sometimes you don't know until you try.
Offline BenelliSEI
  • 1969 cb750
Re: tail light mods
« Reply #16 on: March 17, 2024, 06:02:49 AM »
Good points above! Last time I took a cb750 for a really long ride (over 20 years ago), I had the tail light from  a later cb (900 maybe?). I picked it up at a flea market and liked it because it had two bulbs, doing the same jobs. Makes total sense.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: tail light mods
« Reply #17 on: March 17, 2024, 07:55:51 AM »
Maybe and LED is the answer.
1973 CB 750 K3
Offline jgger
Re: tail light mods
« Reply #18 on: March 17, 2024, 08:25:42 AM »
They make L.E.D.'s that flash like 5 to 7 times ( I think)  when the brakes are 1st applied. Good if you are commuting, plus brighter than incandescent.
Re: tail light mods
« Reply #19 on: March 17, 2024, 08:26:27 AM »
I hope LED bulbs are better today than ca 5 years ago when I tried LED bulbs in the K1 style rear light my K6 and K2 have.
The 2 models of LED bulbs I tested had bad brake light, not much difference when braking plus poor licence plate illumination.
So the old style 5/21W bulb is still used.
Brake light is important to be seen when lit.
General about rear light, not that important as headlight. If cars are closing up, you ride too slow!! ;D
LED H4 front is OK.
Offline Oddjob
Re: tail light mods
« Reply #20 on: March 17, 2024, 09:51:11 AM »
Not strictly true Pewe, you stop at junctions, traffic lights and roadworks, cars close up at all of those, tail light just as important as headlight, traffic should be on the other side of the road so headlight whilst very useful and important isn't as critical to safety as tail lights IMO. Mate of mine was killed when he was rear ended on a motorway, only 18 at the time, car was doing over 100mph at the time, most SOHC Hondas from the 70s would struggle to cruise at that speed.
Re: tail light mods
« Reply #21 on: March 17, 2024, 10:02:42 AM »
Yes, I know. I could not resist a little fun. ;D ;D
I had never thought that stock rear lamp is too weak.
But, in city riding today when most cars have blinding white LED lamps, smaller red rears might drown in all light, I'm sure  when raining.
I rode long distances in the 80's in heavy rain and darkness. No problems then. This was before the blinding LEDs most cars got +25 years later.
« Last Edit: March 17, 2024, 10:07:13 AM by PeWe »
Offline grcamna2
Re: tail light mods
« Reply #22 on: March 17, 2024, 10:43:17 AM »
I want to switch to a set of 4) bright LED turn signals;I want to install a pair of double filament front turn signals from a VF500C Magna in the rear.
The idea is to have 3) rear taillights,including each turn signal;I will use 1157 bulbs on each rear,inside(space/length is limited in there)the turn signals.
I have 1156 bulbs in the front and want some bright ones up there.
Do they make good LED 1157 bulbs now? I bought a set of flat LED's and tried installing them into a double bulb rear taillight a few years back;no improvement,rather a lot less light and I couldn't see the bulbs in bright sunlight(and no license plate illumination)so I went back to incandescent.
I still want to use them in the taillight.
I want to switch-over to LED's,but don't want an LED bulb that's lame;I hope the LED bulbs are strong enough to press them into the sockets.
Yeah,I've got No experience at all on LED's  ::)  Need to learn how to retro-fit them onto an older light socket.  :)
« Last Edit: March 17, 2024, 10:58:44 AM by grcamna2 »
Offline BenelliSEI
  • 1969 cb750
Re: tail light mods
« Reply #23 on: March 17, 2024, 10:51:44 AM »
The idea is to have 3) rear taillights,including each turn signal;I will use 1157 bulbs on each rear turn signal.
Assuming you do, I have a few sets of red turn signal lenses (1969-75 style), if your state requires red on the back?
Offline grcamna2
Re: tail light mods
« Reply #24 on: March 17, 2024, 11:01:44 AM »
I bought some reflectors and installed the lenses into the VF500C double filament turn signals.
I'm running  #P21/5 bulbs in both these signals along with the stock Honda taillight;LED's wanted.
I hope the local constabulary isn't offended.
« Last Edit: March 17, 2024, 11:23:18 AM by grcamna2 »
