Author Topic: Fork leaking oil- can I put in new oil while the fork is still on the bike?  (Read 410 times)
Offline tommygunxs
The front fork on My Honda nighthawk 1983 is leaking oil.
I wonder if I can remove the cap upp on the fork and put in some new oil whit some seal fixer? (omega 917).
The thing is the fork will still be attached to the motorcycle- and I now that if I open the top bolt there will be some airpressure that I have to handle, and there is a big spring in the fork.
Se the pictures, can this be done?  Otherwise I have to take the fork of and apart och put on some new seals but my knowledge to this is limited
Offline tommygunxs
Se picture of the motorcycle
Offline tommygunxs
And this picture. I wonder if I can put oil in the fork while the fork is still attached to the motorcycle
Online newday777
In a word, yes you can but you need to clean out the bug guts in the seal, use a Seal Mate or make your own.
Then you need to empty out the old oil before refilling.
Stu
My current rides
Prior bikes....
Online rotortiller
Support the bike under the frame etc forward of the center stand making the front wheel leave the ground. Take the front wheel off, remove fender, caliper etc, loosen the fork tube top cap nut, loosen the triples and pull that sucker off. Then fix the leak by replacing the seal. I typically remove the spring and the seal circlip, fill the thing up with oil, install cap and press the seal out hydraulically. I use a press but ratchet strap may work but have not tried it. You can also do it the way the shop manual suggests.
You can also support the bike forward weight from the bars using two step ladders and a board with ratchet straps.
Offline tommygunxs
Do you know it I can put a jack a lift the bike in the oilpan? Will it hold? I also have the center stand
Offline willbird
on the center stand there is not a lot of weight on front wheel, when bike has luggage rack putting as little as 50lbs on the luggage rack can lift front wheel off ground. so using jack probably less than 100 lbs pressure will lift front wheel until rear wheel touches floor….pivoting bike on center stand. I just put a board under my 4:1 header and jack there to make the bike pivot.
probably could use ratchet strap pulling on ceiling joist too
Like Rotortiller says: if it is leaking then you'll need to change the fork seal. Fluids to 'reseal' those seals don't work very well, if at all.
But how much will you know to add?!
Replace the seal and put in the proper amount so that your forks don't work differently
Offline Kelly E
  • Geriatric Hooligan
We always rebuild both sides at the same time. First inspect the tubes for any nicks or dings. If it has never been done there will be a bunch of sludge in the bottom.
The hardest task is breaking loose the bottom bolt without spinning the piston. An impact gun works the best.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
A leaking fork seal needs replacing, it will not "fix" with any aditive plus most times they leak the fork chrome is compromised
