Author Topic: What a chain guard is for PART TWO (HELEK SH'TAYIM)  (Read 7504 times)
Offline Lumbee
    • My pics...
Re: What a chain guard is for
« Reply #25 on: March 28, 2007, 05:49:13 AM »
...medic, the plate may only go on one way...make sure u'r trying it both ways...
"I'm not a welder, but I play one on HondaChopper.com"
Offline Raul CB750K1
« Reply #26 on: March 28, 2007, 10:41:15 AM »
Just chuck a cheapl grinding stone into an electric drill and grind down the pin and then punch it out. Should cost uou $5.00
That's pretty dangerous; there is no way to hold the thing in place. For as little as $15 you can buy a cheapo chinese-made angle grinder. A chain-breaker will surely be more expensive and maybe you will never use it again.
Raul
P.S. I would love to see a pic of the chain guard...
Offline xtalon
« Reply #27 on: March 28, 2007, 11:37:58 AM »
Me too.  I would also like to know what kind of chain you were using that broke.
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
Offline medic09
« Reply #28 on: April 01, 2007, 01:15:06 AM »
--xTalon
I'm overseas just now.  Should get back in about 2 weeks, and straight back to clinical duties a day later, soooo....I'll post a pic, but it'll be a while.  Actually, I straightened the chain guard a little by hand taking it off.  It was properly mangled though; bent back and in towards the tire.  Good thing it didn't slash my tire in the process.
The chain was a fairly new O-ring chain with maybe 2000 miles on it.  :-(
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #29 on: April 01, 2007, 01:29:01 AM »
Hey, I would like to thank ya for relaying your story about the chain mishap. It sucessfully motivated me to get off my bum and put a guard on my bike, finally.
I kept trying to find a metal, chrome one on eBay but finally realized only the black plastic ones were offered on the earlier CB500. The chrome metal ones I did find were all for CB550s and had different mouting hole thingies.
I ended up taking a CB750 chrome metal guard I got from my friend and made it work. . .lol. Actually, it all but bolted up - I did have to drill/tap one hole on the swing arm and make a couple brackets but it turned out real well and looks almost stock.
Anyways, thanks for the tale because that sounds too scary for my tastes, to have a broken bike chain flailing behind you! yikes   :o
« Last Edit: April 30, 2007, 10:26:08 PM by MoTo-BunnY »
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline medic09
« Reply #30 on: April 01, 2007, 08:01:37 AM »
Shucks, just glad to be of help m'am...
Now, if I can just get that master link closed when I get home, and get the shifter case correctly back on...
Mordechai
'78 CB750K
Santa Fe, NM
Offline medic09
Re: What a chain guard is for PART TWO
« Reply #31 on: April 29, 2007, 05:13:14 PM »
So today I notice my left rear signal doesn't work.  I pull in to the nearest auto parts place to buy a bulb.  When I open the signal, the bulb inside is just shards of shattered glass.   Hmmmm, how did this happen?  And the square dent in the signal stem?  And the little bit of aluminum bitten out of the stem.  Oh, never mind.  Fix the signal and ride on.
When I get home, I tell my wife.  She right away says "the chain".  When the chain broke and mangled the chain guard, it whipped back and up all the way to the rear turn signal, denting the stem and breaking the bulb from the shock of the blow, before it went off down the highway.
Someone asked earlier for a pic of the chain guard.  I'm keeping it to remind me to be grateful, careful, and not take much for granted.
Mordechai
'78 CB750K
Santa Fe, NM
Offline heffay
Re: What a chain guard is for PART TWO (HELEK SH'TAYIM)
« Reply #32 on: April 29, 2007, 06:53:52 PM »
well... i'm glad i adjusted the chain before we went on our ride today
sucks to hear what happened.
if you get the motion pro chain breaker you can take the breaker pin out of the threaded shaft.
then, screw that shaft in on top of the link to compress the masterlink... the part where the pin normally goes will just go right over the pin in the chain.
if you think you may have compromised your masterlink w/ the pliers or whatever tool wasn't working... go buy a new master link.
Offline medic09
« Reply #33 on: April 29, 2007, 07:25:38 PM »
That's a great tip, thanks!  I think I posted somewhere that in the end one of the old pros at Motorsport in ABQ said to use a nut and a C-clamp over each rivet/post.  It worked like a charm!  Your tip will be great if I ever need it on the road.  Less tools to carry.
As far as the thrown-chain incident, alls well that ends well.  The broken signal just emphasized how fortunate I really am in this case.  And I learned a few things...  ;)
Mordechai
'78 CB750K
Santa Fe, NM
Offline CB750R
  • 77 CB750F
« Reply #34 on: April 29, 2007, 08:19:22 PM »
hmmm bike looks cool with no chain gaurd, but  I look cool without a severed foot, tough call... guess that rusty chromed gaurd is goin back on again untill I figure something else out to save my bacon!
Offline edbikerii
    • Gallery
« Reply #35 on: April 29, 2007, 08:26:55 PM »
What the heck does HELEK SH'TAYIM mean?
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline medic09
« Reply #36 on: April 29, 2007, 08:40:21 PM »
Part Two, of course.  Geesh, I thought everyone speaks Hebrew around here.   ;D
Mordechai
'78 CB750K
Santa Fe, NM
Offline mrbreeze
  • Not your average
« Reply #37 on: April 29, 2007, 11:05:09 PM »
You're wrong!!! Everyone here doesn't speak Hebrew!!!!! So what does that mean????
MEMBER # 257
Offline heffay
« Reply #38 on: April 30, 2007, 08:38:44 AM »
mr breeze... did you wake up on the wrong side of monday... i've now read two of your posts in separate threads that put out an air of irritability.
if you'll actually read medic's response you would see that it means part two... you even quoted it.
Offline Leemata
« Reply #39 on: April 30, 2007, 09:00:38 AM »
You were lucky.
I was riding a '77 Yamaha 250 enduro to work one morning when the rear tire locked up at 50mph.  I rode it out but it was plenty scary.  Can't imagine it happening at 90.  It turns out a tranny bearing wanted out of the left case.......real bad.  Left a hole in the case you could stick your hand through on edge.  Must have been at least 4" tall and 2" wide.
Terry
'78 CB750F, '72 Honda Z50, '74 Honda Z50, '78 Maico MC250, '98 Yamaha YZ250, '75 RD350B
"Ah yes, Harley Davidson.  You really have to give them credit.  They've managed to create a market in which they can sell yesterday's technology at tomorrow's prices." (Michael Kasmirsky)
Offline mrbreeze
  • Not your average
« Reply #40 on: April 30, 2007, 09:29:37 PM »
Whatever do you mean Heff? I just didn't know what it meant.....thats all!!!!
MEMBER # 257
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #41 on: April 30, 2007, 09:49:38 PM »
...............wait for it.....................
and get a Scottoiler when you are done.
Nick now scurries off to hide from the many groans and "oh my God, not again" comments.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline Kamal
  • "..but, how did it make you FEEL?"
    • MotoTherapy
« Reply #42 on: May 01, 2007, 09:39:38 AM »
Somehow, I don't think the chain "broke".
I am willing to bet that it was simply loose, and jumped off the sprocket, causing it to get caught up at speed, thereby breaking.
Chains these days are SUPER STRONG.  These guys with 160HP run 520 chains on the street drag racing...they don't break under power, but a loose chain, all caught up at 90 MPH, well thats a different story.
Kamal
CB750K6
CB750K2 Drag Project
IT465 Yammie
KMX250 "Kawazuki" (or was it a "Suzusaki"?)
