Author Topic: Screen Trim - what to use?  (Read 4002 times)
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« on: March 30, 2007, 10:14:54 AM »
My new Triumph is missing the screen trim. The Triumph boys can only point me to my dealer but I know that you guys will have some terrific and well researched (well tried and trusted) solution to this.
Even better if I can get it in the UK!
I know that this is more of a question that a tip, but a good answer will count as a tip...
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline Ricky_Racer
Re: Screen Trim - what to use?
« Reply #1 on: March 30, 2007, 11:49:12 AM »
Hi Steve.  Here's one.  There are a number of styles out there...
http://www.topoftheline.com/dooredgemolding.html
Just Google "door edge protector."  Good luck!  RR
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #2 on: March 30, 2007, 03:49:17 PM »
an old trick was to get some small bore clear plastic tubing like windscreen washer tube cut down the length of it with a sharp knife and glue it on with clear adhesive.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Wis
« Reply #3 on: March 31, 2007, 01:17:40 PM »
Your local auto parts store will have self adhesive door edge trim in various colors.
    • TVAM
« Reply #4 on: April 01, 2007, 12:24:38 AM »
Went to Halfords (which is the equivalent of my local auto parts store), normally they are crap for bikes.
They had a complete section of bike stuff; manuals, plugs, bulbs and accessories including screen trim, tank protectors etc.
Impressed!
SOHC4 Member #2393
Offline hymodyne
« Reply #5 on: April 12, 2007, 04:06:22 PM »
in
hobby circles, it called combing or piping. it's used to create the cushioned or padded area around an open  airplane cockpit, for example. I use windshield washer line split down the middle and super glue to make combing for the lower seal of my old tank, as well as around the perimeter of mu windscreen on the viper fairing I use to run. I'm planning to put some around the gustaffason screen in my rebuild.
hym
