Author Topic: Lowering the guages - part II  (Read 1747 times)
Offline KB02
« on: April 06, 2007, 05:38:55 AM »
Okay, so I have successfully lowered the gauges and headlight on my bike from the stock position. Here is the before picture:
and here is the after picture:
I'm trying to decide now if I want to lower the gauges just a bit more, or if I want t bring the headlight up just a touch to be a little closer (as you can see there is a little less of a gap in the before picture... I like the closer look). Also, the headlight is now low enough that I'm a little worried about hitting it with the front wheel if I hit a good bump.
It was fairly simple, I just took the mount plate for the gauges and flipped it upside down and remounted the speedo and tach. Then it was just a matter of a coupler, some spacers and some longer bolts and down she went. I just replaced the headlight and blinker bracket with the cheapies I got from Z1.
Now my only question is what to do with my top tree clamp. right now I have a plate that I made up to cover the bar mounts (since I am using clip ons). That worked fine with everything at stock height, but now it just kind of blocks things and looks out of place.... Hmmmmm... what to do, what to do, what to do... after I get the timing figured out...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Gordon
  • 750K1, 550K2
Re: Lowering the guages - part II
« Reply #1 on: April 06, 2007, 06:27:39 AM »
I like the look of the lower headlight and agree that the guages need to be closer to it.  You should definitely measure the total travel of the forks and make sure the bottom of the headlight is above that, or you'll be shopping for a new headlight and bucket and fender in the near future. :o
Offline KB02
« Reply #2 on: April 06, 2007, 09:26:23 AM »
 :D ;D ;D ;D ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline zanzara
    • the hall of photos
« Reply #3 on: April 06, 2007, 12:11:22 PM »
That lower look is what I was tryuing to do also. I made my bracket and carriage bolted it to the bottom of the top tree. It is spaced down about 3/4" with big aluminum cable clamps. The bend below the gauges gave me just enough clearance for the tach cable to miss the banjo bolt on the master cylinder. Came out a little lower than before. There is one route.
nuke
« Reply #4 on: April 06, 2007, 01:02:55 PM »
KB02....I like...I like alot....but where's part I of this project.
Offline KB02
« Reply #5 on: April 06, 2007, 01:58:44 PM »
http://www.sohc4.us/forums/index.php?topic=18465
This is where I started anyway.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
