Author Topic: The Norda- cb750 powered featherbed  (Read 11021 times)
Offline ratranger
« on: June 20, 2025, 11:56:33 AM »
I haven't been on here in a long time, but thought my current project might be appreciated here.  It started with a norton slimline featherbed I was going to build a triton with.  Decided not to because the unit motors just don't fit right and finding an affordable pre-unit is hard.  So I ended up finding a $200 cb750 in a box and decided that was going to be my swap.
 Progress so far has been building motor mounts, making triples and stem to use cbr600f4i forks with a gt750 front brake, and geting a mini manx tank from TAB classics.  I still need to make lower mounts,  and modify the breather cover for a head steady.  I'm not planning any big performance mods for the engine other than a good rebuild.
Offline Dime
Re: The Norda- cb750 powered featherbed
« Reply #1 on: June 20, 2025, 12:08:12 PM »
Been following elsewhere. Love this build!
Offline ratranger
« Reply #2 on: June 20, 2025, 02:55:47 PM »
Thanks! I don't know how long it'll take me to finish.   Saving for parts can take a while.  The tank was a little over $1k after shipping, wheels will be similar to lace, the engine I think will be the most expensive part.  Even if I buy less expensive pistons and have it bored locally that'll be around $500, new chains and tensioners, gaskets, bearings, etc will all add up.  I won't buy anything on credit so it might take a bit.
Offline newday777
« Reply #3 on: June 20, 2025, 03:08:51 PM »
I'll be following along.  That looks cool.
Stu
My current rides
Prior bikes....
Offline Dime
« Reply #4 on: June 21, 2025, 04:18:47 AM »
I am building mine the same way. Cash only. I am on disability so there is not much to put towards the bike. Piece by piece, it will get done. Much appreciate your build.
Offline ratranger
« Reply #5 on: June 21, 2025, 07:14:47 AM »
 It's the only way to go when you aren't doing it for a business.  It's too easy to dig a deep hole when you just throw everything on credit.
Offline bek1966
« Reply #6 on: June 21, 2025, 07:17:07 AM »
Very cool.  Following, with interest!!!
Nice work,
Brad
1971 CB750 K1 - Candy Gold
1971 CB500 K0 - Star Light Gold
1974 CB350 F1 - Glory Blue Black
Pleasant Prairie, Wisconsin
Offline ratranger
« Reply #7 on: June 21, 2025, 04:07:03 PM »
Working on the head steady, I've read that it is a bad idea not to have one on the featherbed.  When it's not so hot I'll weld the piece to the breather cover.  I'll also time-sert where the cover mounts.
Offline Dime
« Reply #8 on: June 22, 2025, 06:15:20 AM »
Very cool idea
Offline ratranger
« Reply #9 on: June 23, 2025, 04:00:58 PM »
Head steady is now permanent.  Welding aluminum when it's 90* and humid sucks.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #10 on: June 24, 2025, 07:00:53 PM »
What welding process are you using? Mig tig or stick?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline ratranger
« Reply #11 on: June 25, 2025, 03:30:43 AM »
TIG for pretty much everything.  I have a MIG, but it's a basic one so only really good for steel.  Since I got the TIG I've used it as much as I can.  Can't get better without practice.  I will say the protig 205 from harbor freight is good value for the money.  I know it's gone up some but I got it with a coupon for $800, not going to get a better ac/dc machine without spending double to triple.
Offline BenelliSEI
  • 1969 cb750
« Reply #12 on: June 25, 2025, 05:29:37 AM »
Neat project! Will follow along.
« Reply #13 on: June 25, 2025, 08:00:54 AM »
Offline ratranger
« Reply #14 on: June 29, 2025, 01:27:53 PM »
I'm debating how I want to do the exhaust on this. I have 3 options, 4-4, 4-2, or 4-1. Off the shelf isn't going to work since it's not in the stock frame. 4-1 is tempting just because it'll cost less, mufflers are spendy. 4-2 would look more balanced and easier to make headers for. But 4-4 is just classic cb750, headers about the same as the 4-2 to make, but 4 mufflers. I could probably make mufflers, but I'd spend almost as much as just buying them to do that. I'll probably wait until I have it on the wheels to decide, but I have to start thinking/saving now.
Also do I want to just buy mandrel bends and piece it together, or attempt filling the pipe with sand and bending it to get a more flowing look.
Offline ratranger
« Reply #15 on: July 15, 2025, 01:37:04 PM »
While I wait for rims and spokes I started on the air filter set up.  The stacks are the same length and radius as the stock airbox rubbers.  Filter is from walker engineering for a micro sprint with r6 engine.
Offline Dime
« Reply #16 on: July 16, 2025, 01:12:59 PM »
Interested to see how this turns out. More and more I want to be rid of the stock air box. Is this your own design and fabrication?
Offline ratranger
« Reply #17 on: July 16, 2025, 01:53:18 PM »
Yes.  I used the stock airbox rubbers for length and radius on the stacks.  The plates I cut and machined to line everything up and hold the filter.  Stacks started as 2.5" dia .5" wall tube.
Offline Dime
« Reply #18 on: July 16, 2025, 01:57:08 PM »
If you decide that you would like to build another once you have it all sorted out I would be interested. Just need to get the cash together. Great work. I think using the filter you are will eliminate some of the issues common with pods or a breadbox.
Offline ratranger
« Reply #19 on: July 16, 2025, 03:32:40 PM »
 I'm not sure it would fit in a stock frame.  I can't use the stock airbox, bare stacks are bad for a daily, pods aren't great and the cognito air filter seems like it wouldn't flow very well.  I figure if this filter flows enough for a R6 engine it'll flow more than enough for the CB.  I figured this would be the best compromise.
Offline Dime
« Reply #20 on: July 16, 2025, 03:55:45 PM »
I will keep watching as you go along. I am very interested in your build, especially this breather setup. It is pretty much what has been kicking around in my head as an idea.
Sent from my SM-S721W using Tapatalk
Offline ratranger
« Reply #21 on: July 19, 2025, 05:09:53 PM »
Rims and spokes got here from Buchanan.  A little more work before I can install the outex tubeless kits and tires.  Once that's done I can start thinking about seat and foot controls.
Offline ratranger
« Reply #22 on: July 21, 2025, 03:25:45 PM »
Here's the bike with wheels mounted,  and the finished intake without the filter.
Offline BenelliSEI
  • 1969 cb750
« Reply #23 on: July 26, 2025, 05:18:32 AM »
Nice work. Unique project and I like it! Will you ultimately punch some holes in those rear engine mounting plates?
Offline denward17
« Reply #24 on: July 26, 2025, 06:38:03 AM »
+1, nice project !
Following progress.....
