Author Topic: bottom Air  (Read 9688 times)
Offline thrownchain
Re: bottom Air
« Reply #50 on: May 02, 2007, 06:08:25 AM »
Bought a box of stuff at the swap meet the other day, but the guy wouldn't let go through the box. He said you get what you get. So if anyone needs some of this stuff let me know.
I can of brake squeel and two cans of brake fade.
A bottle of chain whine.
Half a case of clutch slip.
A small bottle of pre ignition, and a tube of spark plug grease.
There's an empty box that had chain slack in it , boy I could have used that!
And two empty cans that just said "air", didn't specify top or bottom.  Sorry guys.
Offline medic09
Re: bottom Air
« Reply #51 on: May 02, 2007, 09:19:55 PM »
What happens if you just try the air, but it's topsy-turvy and you got bottom top and top bottom?
Is it too risky?
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline Gordon
  • 750K1, 550K2
Re: bottom Air
« Reply #52 on: May 03, 2007, 07:22:42 PM »
Is it too risky?
Not a problem.  Just rotate your wheels 180 degrees and you're set!
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: bottom Air
« Reply #53 on: May 07, 2007, 09:46:38 AM »
Actually this will only work if your front and rear tyres are exactly the same size... like on my Norton.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
