Author Topic: smoke and oil from breather tube (cb350f)  (Read 1725 times)
thirdman
« on: June 29, 2005, 08:13:09 AM »
One day while riding home, I started to lose top end power.  By the time I got home, I had lots of smoke and oil spraying out of my breather tube...  What causes this?  I have a 1973 CB350F.  What do I need to do to diagnose the problem?  I figured I would start with a compression test... but what else?
(p.s. I did a search on "breather" and found suggestions that it might be bad rings or a bad valve seal... can anyone confirm?  )
« Last Edit: June 29, 2005, 11:13:54 AM by thirdman »
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: smoke and oil from breather tube (cb350f)
« Reply #1 on: June 29, 2005, 08:22:14 AM »
Smoke from the breather means you have excess crankcase pressure (usually caused by rings or valve seals as you say)
If you have oil "spraying" out it sounds serious!
Start with a compression test but check valve clearances first.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
thirdman
« Reply #2 on: June 29, 2005, 11:13:32 AM »
I had the full-on James Bond smokescreen and oilslick action.  My rear wheel got coated in oil, and the smoke was thick
Worst case, what does this mean?  If rings are toast, does that mean a re-bore?  If it is a valve issue, what all is involved with that?
