Author Topic: Weird Engine Sound Please help  (Read 1423 times)
Shiftredline
« on: August 23, 2007, 05:06:47 PM »
Well I was out riding the Cb today. Everything was going great. I finally got rid of the high idle issue. anyway after being off the bike for an hour I go to start it up (Kick Start) and it starts making a sound like a scraping sound (High Pitch) as if there was no oil in the chambers. The bike then idles fine and i ride off. After I get home. I let the bike cool off. I go out about an 30min later to start it again to find out what made that noice and now I hear it with every kick of the pedal. Also was having trouble getting the bike to start. I could not get it started the final time trying. I checked the oil level. It was fine. I alway kick the pedal before turn the key and starting to move the oil around. before this issue the bike has been starting on the first or second kick. I'll take any help on this issue
Offline 750goes
  • it will live
Re: Weird Engine Sound Please help
« Reply #1 on: August 23, 2007, 07:10:56 PM »
I could be really wrong but a high pitch squeal sounds like.......drum roll..............siezed camshaft or something else quite nasty...............maybe a bit of a look with the tappet covers removed might help pinpoint the squeal ??
type of bike ??
Shiftredline
« Reply #2 on: August 23, 2007, 07:26:33 PM »
type of bike ??
Its a 76 550k. The moter still turn over freely. When it first happened the bike started and the sound last two seconds and the bike rode like a champ. Pulled throught all the gears. I did not hear it again til later when i tried to restart it to see what the sound was.
Offline 750goes
  • it will live
« Reply #3 on: August 23, 2007, 07:48:34 PM »
have you checked the camchain for adjustment - but it could well be a bad cam journal...can you check the end caps of the valve cover ? for signs of wear??
Shiftredline
« Reply #4 on: August 23, 2007, 08:04:54 PM »
I did not check the camchain. Will do tomorrow, Thanks for the help.
Offline jdpas29
  • my bike is 100% sandcast!!
    • My band = white bread
« Reply #5 on: August 23, 2007, 09:23:27 PM »
check for trapped squirrels   :P
sorry i've been drinking i don't know what the hell that could be
cars are gay.
Offline mark
« Reply #6 on: August 23, 2007, 09:46:20 PM »
Does/did the sound vary with throttle.. in gear/neutral.. clutch in/out.. ?? Pull dipstick and look for metal flakes in oil? :( :'(
In the mean time.. please don't park it next to mine in case whatever yours has is contagious :o
Good luck!
F you mark...... F you.
Offline svenD
« Reply #7 on: August 24, 2007, 05:32:37 AM »
hi
could be the elektrickstarterclutch playing up.hope not.good luck with it.svenD.
Shiftredline
« Reply #8 on: August 24, 2007, 05:56:36 AM »
Good luck!
Only hear the sound when the engine is getting kicked over then it last two seconds after the bike is running. I checked for metal flakes in the oil. Nothing clean.
Shiftredline
« Reply #9 on: August 24, 2007, 08:19:51 AM »
Ok this is getting weird. I got it to start again, no noise and starts on second kick. I did check the camchain last night and it was fine. I alsl looked into the tappet covers and could see that oil was making it to all cylinders. I still dont know what made that noise.
« Last Edit: August 24, 2007, 09:05:38 AM by Shiftredline »
Offline 750essess
  • Orleans Cycle Repair & Resto
« Reply #10 on: August 24, 2007, 08:28:11 AM »
Sounds like the kickstart ratchet mechanism is sticking to me.
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Offline dergs713
« Reply #11 on: May 30, 2013, 06:22:55 PM »
I feel that the kickstart ratchet is sticking on mine as well. I have a steady ratchet sound coming from what seems to be my kick starter.
Matt
