Author Topic: Dwell meter  (Read 4786 times)
Offline 6adan
Dwell meter
« on: September 06, 2007, 07:28:23 PM »
  Just got a dwell meter off ebay with no manual,never used one before. How do you use it? Thanks Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
eldar
Re: Dwell meter
« Reply #1 on: September 07, 2007, 06:29:49 AM »
Well what brand and model is it? different models work differently. You can also search the net for an online manual.
Offline 6adan
Re: Dwell meter
« Reply #2 on: September 07, 2007, 08:08:14 AM »
  It is a Sears model 161.216500. It two leads a black and a green with a switch for RPM Dwell and Volts. Dannie
Re: Dwell meter
« Reply #3 on: September 07, 2007, 09:47:00 AM »
Dwell meters are clipped across the point contact set.
Interpreting their reading is the tricky part.  They can be calibrated for 8 Cyl, 6 Cyl, 4 Cyl, 2 cyl, etc.  Technically, you would use a one cyl, setting as the four cylinder Honda ignition fires  once per revolution.  The auto dwell meter is expecting 4 pulses for two revolutions.
You can still use your dwell meter regardless of scale indication.  Just use new points, set the gap mechanically as accurately as you can and note the dwell reading on a scale that looks "sensitive" or sensible to you.
That will be your goal the next time you wish to adjust points.
My Dwell meter on the car 4 cyl scale, reads 46-49 degrees.
The specified dwell angle for the SOHC4 is 190 +/- 5 degrees of crankshaft rotation.
Divide 190 (specified dwell) by 2 Cylinders = 95.
Divide 95 by 2 (doubled firing pulses) = 47.5
Hope this helps,
Offline Jonesy
  • Shop Rat
Re: Dwell meter
« Reply #4 on: September 07, 2007, 11:01:54 AM »
Very well done, TT!
I've asked this question before, but have never gotten any sort of good response. I knew how to get a reading, but no idea what to do with it or what it meant. This was the kind of answer I have been looking for.
This is something that interests me despite that fact I now run a Dyna-S module...
Offline mark
Re: Dwell meter
« Reply #5 on: September 07, 2007, 12:15:18 PM »
Black lead to ground and Green lead to points.
Happy trails.
F you mark...... F you.
Offline 6adan
Re: Dwell meter
« Reply #6 on: September 07, 2007, 12:46:04 PM »
  Thanks a lot T T. That is what I was looking for,like I said have never used one before. Dannie
