Author Topic: Tonights project - Kerker exhaust bracket  (Read 3438 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: September 24, 2007, 06:27:53 PM »
Tonight I fabbed up a exhaust bracket for my Kerker exhaust.  Here are the results:
I made the bracket from bar stock aluminum and bent it to my specs.  I polished it up after a wet sanding first with 400 grit, then 800 grit, then 2000 grit and hit it with the buffing wheel I just bought.  I will polish it up some more tomorrow.
1972 CB750 K2 Cafe' Style
Offline sparty
    • Gallery
Re: Tonights project - Kerker exhaust bracket
« Reply #1 on: September 24, 2007, 06:29:03 PM »
More pics:
Offline sparty
    • Gallery
« Reply #2 on: September 24, 2007, 06:45:53 PM »
Another pic:
« Reply #3 on: September 24, 2007, 06:49:19 PM »
 Nice work Art. That's a good size hole on the end of that pipe. ;)
Offline sparty
    • Gallery
« Reply #4 on: September 24, 2007, 06:53:44 PM »
Thanks Mike.  I wanted to make you proud.  That is the 1.5 comp baffle.  It should help get all of the ponies out.  Tell Alister that he now has polishing competition.
« Reply #5 on: September 24, 2007, 08:16:14 PM »
OK Art.....if you really think so. ;) ;D
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #6 on: September 24, 2007, 11:28:16 PM »
I don't want to sound like Mr Negative here, but are you sure that'll work?
Looks to me like it could do with some triangulation back to the frame.
1978 CB550 K3
1985 H100S
« Reply #7 on: September 25, 2007, 04:39:57 AM »
 I wouldn't worry about that to much. The megaphone clamps to the mid pipe with a large clamp. It's pretty solid without the strap.
Offline sparty
    • Gallery
« Reply #8 on: September 25, 2007, 05:14:17 AM »
Initially I worried about that also, but I am using a locking washer and nut to mount the bracket and it actually provides some really strong support, I tested it by trying to push it down using my body weight and the bracket didn't budge very much.
Offline CrisPDuk
« Reply #9 on: September 25, 2007, 06:16:46 AM »
Fair enough, I was just thinking that it's one hell of a lever load to be putting on that sparkling new cylinder head's exhaust clamps
1978 CB550 K3
1985 H100S
Offline CrisPDuk
« Reply #10 on: September 25, 2007, 06:18:33 AM »
Ps; We're always looking for ally and stainless steel polishers in our factory here in Bangkok if you're ever over here and in need of a job ;)
1978 CB550 K3
1985 H100S
Offline Steve F
« Reply #11 on: September 25, 2007, 06:33:04 AM »
+1
Offline dagersh
    • Photos
« Reply #12 on: September 25, 2007, 08:07:30 AM »
Nice work Sparty,
That is just the ticket I need to do on my Kerker!  I can't stand the bar that hangs down from the top of the frame.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Rhonda750F
  • In the Works!
    • Gallery:
« Reply #13 on: September 25, 2007, 08:15:51 AM »
What was wrong with the stock bracket?  Did you modify your frame(lose stock mounting point?)
Paul Z.
1978 CB750 F rolling chassis for sale. PM me.
Offline sparty
    • Gallery
« Reply #14 on: September 25, 2007, 09:02:35 AM »
The original Kerker bracket hangs from the upper shock mount.  I don't like that look.  Hence my fabbed bracket.
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #15 on: September 25, 2007, 09:17:36 AM »
Looks nice Sparty. For forum members' information, your fabbed fabrication is fabulous!  A shiny symbol of SOHC4 stimulating synthesis. ;D
« Reply #16 on: September 25, 2007, 09:45:13 AM »
Another good job Art.
For all the guys that haven't fabbed a bracket for their Kerker, it will work just fine and definitely looks better.
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #17 on: September 25, 2007, 01:06:41 PM »
Would anybody know what would be the fix for a high vibrating feeling in the right foot peg after installing a Mac muffler?
It's much louder than stock, and the vibration only comes on, as you would say, after 4200rpm.
It still uses the oem bracket location.
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline sparty
    • Gallery
« Reply #18 on: September 25, 2007, 06:11:39 PM »
LL
You could mount rubber washers between the bracket and bolts like the Kerker uses.  That is what I would do.
fuzzybutt
« Reply #19 on: September 25, 2007, 06:55:37 PM »
i may have to try that at work tomorrow if i can find some more aluminum bar stock
