Author Topic: Rebuilding Koni shocks  (Read 23232 times)
hajaj
« on: November 03, 2007, 08:40:09 AM »
Hello! I've got a pair of 76K 1302 "D"-Special Konis. I would rebulid them, but I'dont know how should I dismantle them. ??? One of them has the threaded collar off. What's next? Thanks! ;)
Offline dave400
  • Super Lamb Banana
Re: Rebuilding Koni shocks
« Reply #1 on: November 03, 2007, 10:18:29 AM »
I rebuilt the same model shocks, once you get the plug out of the the body of the shock it's all easy work from then on.
hajaj
« Reply #2 on: November 03, 2007, 11:56:53 AM »
So, just pulling out the whole thing under the collar with force?
Offline dave400
  • Super Lamb Banana
« Reply #3 on: November 03, 2007, 01:10:02 PM »
When the main plug is removed the job is easy getting the plug is the hard part, I made a tool for the job that worked well.
hajaj
« Reply #4 on: November 03, 2007, 02:05:55 PM »
Thanks Dave, especially for the picture. ;) I had a hard work with the main plug too. :o
Offline dave400
  • Super Lamb Banana
« Reply #5 on: November 03, 2007, 03:03:20 PM »
I f you need parts for the shocks  I got this break down diagram from Koni it’s a car assembly but they used the same parts on bike shocks and worked well for me..
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #6 on: November 04, 2007, 01:13:56 PM »
http://www.ikonsuspension.com/content/ikon_solutions.shtml some good information here too including details of the the correct springs to use.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
hajaj
« Reply #7 on: January 28, 2009, 07:06:47 AM »
Hi again! Could you tell me what type of oil and how much I need to rebuild these shocks?(Koni 76K 1302)
Offline Bird76Mojo
« Reply #8 on: January 28, 2009, 10:07:41 AM »
I'm interested in this info as well. From that picture at least, I have the same model Koni's and want to rebuild them myself if possible.
Where are you guys finding the model number?
GB  ;D
Offline dave400
  • Super Lamb Banana
« Reply #9 on: January 28, 2009, 10:49:11 AM »
I managed to get approx 65ml into each unit but the person I spoke with at Koni recommended 75ml  but some oil came out when I put the piston back into the shock body, the oil I used was ATF.
Cheers
Offline dave400
  • Super Lamb Banana
« Reply #10 on: January 28, 2009, 10:52:06 AM »
GB  ;D
The number is stamped into the body of the main shock unit once you remove the spring you will see it, its behind the white plastic shroud.
Cheers
hajaj
« Reply #11 on: January 29, 2009, 01:08:07 AM »
Thanks a lot!
Offline dave400
  • Super Lamb Banana
« Reply #12 on: January 29, 2009, 12:08:09 PM »
Thanks a lot!
The Koni's are working great even with not quite the recommended amount of oil in them, filling with oil is almost as hard as getting the plug out…..good luck.  ;)
Cheers
Offline Bird76Mojo
« Reply #13 on: February 01, 2009, 06:30:48 PM »
GB  ;D
Cheers
Thanks Dave!
Say, does anyone know an approximate amount for just the parts alone necessary to rebuild these shocks?? Mine are exactly the same.
GB  ;D
Offline fasturd
« Reply #14 on: September 22, 2009, 09:54:50 PM »
Koni no longer supports these shocks. IKON will sell a seal but that is all they have for the aluminum shocks.
13 in the garage and counting...
Link to my link...   http://forums.sohc4.net/index.php?topic=58422.0
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #15 on: July 21, 2018, 12:19:05 PM »
This is no longer the case, Ikon does not have a seal or other parts to service these KONI 76-series shocks.
Ikon do continue to make 76-series shocks under their own brand, those in fact ARE rebuildable using most of the same service parts as the Ikon 7610 series.
Ikon 7610 are in nearly all respects identical to the Koni 7610 from which they were derived, in nearly all cases we CAN completely service Koni 7610 shocks to a near new working condition, including springs if needed.
Nils Menten
Ikon Shocks USA
www.ikonshocksusa.com
Use discount code SOHC4 for 10% off a purchase of new Ikon shocks.
I have a motorcycle problem.
Offline Ericcb750
« Reply #16 on: July 24, 2018, 01:54:12 PM »
Let me say I had Nils re-build an aluminum bodied set of Koni 7610 "D" shocks and they are literally brand new and actually way better looking than they were new. His attention to detail is second to none... Give me a shout and i'll send you pictures... I may have posted them somewhere...
Now I just need to get to building mine....but if you're wondering...send em out to Nils... you won't be disappointed.
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
