Author Topic: Has anyone used toilet bowl cleaner to clean carbs?  (Read 8698 times)
Offline fmctm1sw
« on: November 25, 2007, 08:08:23 AM »
I picked up the tip here about using "The Works" toilet bowl cleaner to clean the inside of my gas tank.  That stuff did a number to the inside of my tank (AND the outside).  That stuff was pretty cheap as well.   I would have never thought it would work like that.  It made me wonder if I could use Berryman B12 on the inside of my tank.   Basically is anything caustic good?   I also know Berryman dip is rather expensive compared to this toilet bowl cleaner.  So...  If I yanked my carbs apart and dunked them in a vat of toilet bowl cleaner, would that be a good idea?  Would it clean them like B12?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: Has anyone used toilet bowl cleaner to clean carbs?
« Reply #1 on: November 25, 2007, 08:40:22 AM »
I'd use caution when using toilet bowl cleaner on the entire carb. I've used "bowl brite" to clean the jets, but that stuff will disolve aluminum entirely :o I've actually used it to take off melted piston bits of a cast iron cylinder, it fizzes up the aluminum and you can wipe it off with a rag. I'd make sure it's not doing that to your poor carbs  :(
 Matt.
Gallery at:
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #2 on: November 25, 2007, 01:35:42 PM »
SnoBol (toilet cleaner like others) is a mild solution of phosphoric acid. It will do wonders for the rusted steel tank, but don't use it on aluminum. It will cause damage as it corrodes it quickly.
Regards,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline JLeather
« Reply #3 on: November 25, 2007, 01:56:03 PM »
Best stuf to clean carbs is boiling them in lemon juice.  Only thing is you gotta do it outside.  Get a hotplate, run an extension cord, fill a sauce pan with a bottle or two of lemon juice and boil each carb in the lemon juice for a while.  It will bubble and smell awful, but it works wonders.
« Reply #4 on: November 25, 2007, 03:13:13 PM »
Check the tread on Simple Green. Does a real nice job with no drama.
Offline bill3749
  • Remember, Some people are alive only because it's illegal to shoot them.
  • Honda 1978 CB750K, 1979 Corvette ZZ4 Crate
« Reply #5 on: November 25, 2007, 04:42:57 PM »
I'm with the simple green. WD 40 all around, in and out, and then soak in simple green solution, and clean and polish til your're out of beer.
Offline Steve F
« Reply #6 on: November 26, 2007, 01:51:16 AM »
What do you mean by "That stuff did a number to...."  doesn't sound good.  ???
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #7 on: November 26, 2007, 05:13:56 AM »
Uh, No. :o
Simple Green and an ultrasonic cleaner for 20/25 min. I had my carbs apart last week and was still impressed by how clean they remained after year.
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline 6adan
« Reply #8 on: November 26, 2007, 05:24:36 AM »
Yamaha carb cleaner is very good. These carbs are easy to clean compared to the later CV carbs. Dannie   PS What happened to the spell check?
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline rhinoracer
« Reply #9 on: November 26, 2007, 10:14:05 AM »
Just because a carb looks like s**t doesn't mean you can use toilet cleaner on it.   :P  Sorry, I had to say it.
Baja native.
pollpegj
« Reply #10 on: November 26, 2007, 10:56:40 AM »
+1 for Simple green, plus it is reusable.
Offline mark
« Reply #11 on: November 26, 2007, 11:30:26 AM »
If you do use toilet cleaner in the carbs, at least be sure to flush!
F you mark...... F you.
Offline fmctm1sw
« Reply #12 on: November 26, 2007, 03:54:09 PM »
Pinhole city...  Since I was typically unprepared, it flash rusted almost immediately since I didn't coat it with anything.  Now I developing solution for the holes...
...and some good word play on the whole toilet thing...  After it stripped the inside of my tank, it turned my driveway brown too when I dumped it!
« Last Edit: November 26, 2007, 03:56:37 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
