Author Topic: Replace head gasket, now crankshaft won't turn  (Read 894 times)
Offline neudl
« on: May 27, 2008, 07:15:30 PM »
I replaced the rings, base gasket, and head gasket, and just finished torquing down the head.  I have not reinstalled the cam shaft yet, but tried turning the crankshaft to make sure the pistons were moving alright in the cylinders, and nothing - it won't turn more than a hair.  Any thoughts?
Offline olds-cool
  • Choppa Guy
  • Choppa
Re: Replace head gasket, now crankshaft won't turn
« Reply #1 on: May 27, 2008, 07:24:32 PM »
Is the cam chain still in?  If so, it may be bound up at the bottom.  Can you turn it the other way?
Offline neudl
« Reply #2 on: May 27, 2008, 07:37:55 PM »
I'm thinking the same thing and am taking the head back off
« Reply #3 on: May 27, 2008, 07:40:56 PM »
Of course the chain must be surrounding the roller between the case and cylinder and be in front of the slider. Other than that, you should be able to retrieve it easily with a pencil magnet.
Offline neudl
« Reply #4 on: May 27, 2008, 08:50:32 PM »
Thetensioner seems to have pinned the camchain.  I pulled the head off, removed and reinstalled the tensioner, and now it turns clockwise.  Is it supposed to be able to turn counterclockwise?
