Author Topic: Carb rebuild kits.  (Read 7578 times)
Offline gkw120649
Carb rebuild kits.
« on: June 02, 2008, 12:24:49 PM »
I have a 1977 K bike.  I replaced the 77 carbs with early model carbs K4 or K5?  It's time for a rebuild.  I need a suggestion as to what brand of rebuild kits to go with and also is there any way to tell what model bike these carbs came off.
Thanks in advance.
Greg Williams
Chicago Metro Area.
1977 CB-750 K
1978 CB-750 K
Offline greenjeans
  • 1972 CB750K2
Re: Carb rebuild kits.
« Reply #1 on: June 02, 2008, 01:05:08 PM »
Everybody says to use the original Honda jets etc.
I used some aftermarket kits that I got at Z1.  Gaskets were shaped to fit the bowls (some are just large o-rings) and they work like a champ.
Jets and needles look good enough to me....seem to run pretty good.  look identical to what I pulled out of my carbs - except clean
Less than half of what my Honda shop was charging
« Reply #2 on: June 02, 2008, 02:08:05 PM »
If the metal components of the carbs aren't damaged, the Honda Gasket set is all you need.  Then you don't have to worry about after-market manufacturers' quality control program being up to snuff.
If they are cheaper, why do you suppose that is?
Offline Frankenkit
  • Industrial Strength
« Reply #3 on: September 23, 2008, 01:34:28 PM »
But the honda gasket set is for just one carb, isn't it?  so at $41 each, for 4, it comes to around $164?  Isn't that kind of steep?  The downside here is I can't find *anyone* *anywhere* that is supplying the rebuild kits for my bike.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline WFO
  • Will work for powerbands
« Reply #4 on: September 23, 2008, 03:57:42 PM »
No if you buy a rebuild kit for a CB/ 4 carbs it's all together it's not per carb.
82 cb650 sc nighthawk - 78 kz 650 b
Offline Frankenkit
« Reply #5 on: September 23, 2008, 04:00:58 PM »
Really? last time I bought one, I only got the stuff for one carb, and that was the OEM gasket kit.  ???
1973 CL350- Lola?
Stuff for sale
Offline Frankenkit
« Reply #7 on: September 23, 2008, 04:10:17 PM »
sorry, should've said I'm looking for a set for my '80 650.  I can find them anywhere for the 81-82s, with their CV carbs, but nothing for the mechanical slide ones
1973 CL350- Lola?
Stuff for sale
Offline WFO
« Reply #8 on: September 23, 2008, 04:20:54 PM »
Ahhh that makes sense i wonder if a 1979 kit is the same? (just thinking)
http://cgi.ebay.com/ebaymotors/HONDA-CB650-KEYSTER-CARB-KIT-1979_W0QQitemZ380061795021QQcmdZViewItem?_trksid=p4506.m20.l1116
Offline Frankenkit
« Reply #9 on: September 23, 2008, 04:24:01 PM »
sirius has the same for $32. ;)  says one kit/one carb, so still stuck at $120 somethin.  ah well, looks like I'm stuck.  Is OEM  that much better than keyster?  Does OEM come with the little float needle etc?
1973 CL350- Lola?
Stuff for sale
Offline WFO
« Reply #10 on: September 23, 2008, 04:32:49 PM »
Heck for that money you might be able to buy a set of used VBs and a carb kit for all three  ;D i wonder if they would work? i saw a set on ebay for 20 bucks.
« Last Edit: September 23, 2008, 04:52:54 PM by WFO »
Offline Dunstall_74
« Reply #11 on: September 23, 2008, 04:49:40 PM »
I bought these oem rebuild kits ($60 for the set of 4)for my K4 a few months ago, but have since put a set of Mikuni Smoothbore carbs on my bike.  I've kept them around because I still have my Keihin Carbs, But would be willing to let the kits go to a forum member for what I've got into them.  The kits come with every rubber gasket, a fiber washer, and an aluminum washer. Everything but the hardware i.e. Jets/Needles
« Last Edit: September 23, 2008, 04:51:29 PM by Dunstall_74 »
''It is clear our nation is reliant upon big foreign oil. More and more of our imports come from overseas.''
—President George W. Bush, Beaverton, Ore., Sep. 25, 2000
Offline mikethejeepguy
« Reply #12 on: September 23, 2008, 06:51:34 PM »
Am also curious of the difference between the Keyster and Honda OEM... I think they pretty much work out to cost the same price last time I checked for my CB550F. (sorry if I'm hijacking) The dealer here charged me $25/kit straight from Honda.
Maybe these guys would know? http://www.myhonda650.com/cb650mods.htm There is a forum.
I also found this... https://www.partsnmore.com/motorcycle-carb-rebuild-kits.php?make=honda&category=carb_kits
Selected CB650 80-82 and got the price of $12/carb... hope it helps
Mike
'76 Honda CB550F, Dana-S'd, Uni filtered, HID'd, LED'd, and mildly cafe'd with many plans still.
Offline WFO
« Reply #13 on: September 23, 2008, 06:57:34 PM »
Mike
Good news for Kitsune ..
Offline Frankenkit
« Reply #14 on: September 23, 2008, 07:23:02 PM »
unfortunately, that one is for the cv carbed 650s  :-\
1973 CL350- Lola?
Stuff for sale
Offline WFO
« Reply #15 on: September 23, 2008, 07:36:43 PM »
poop
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #16 on: September 23, 2008, 07:56:49 PM »
I used Kester rebuild kits for the PD50B's on the '79 650 engine that is currently in the frame.  I found that these kits had a variety of o-rings, but not all of the o-rings.  I had to reuse the small o-rings in the air cut off valves.  I used the jet-needle from the kits because I needed to be able to adjust it since I was putting pod filters on (there was no air box present when I bought it).  After 6 months, here is the condition of the Kester jet-needle (bottom), after I cleaned off the crud compared to the stock needle (top) that came out of the bike:
The engine was not run much durring those 6 months but run even less previous to me puchasing it.  There is a notch that can be felt like the brass has been eaten away.  The original jet-needles are fine.
Here are the stock needle-jets that came out of the carbs:
Nice and clean.
Here are the Kester needle-jets and the stock main nozzles after 6 months:
Cruddy.
Like TT says, I wonder about the quality of these after market kits and I also wonder what Oxygenated fuel does to brass.  While cleaning out the carbs this last time, I re-installed the stock PD50B needle-jets and jet-needles from a set of PD50A carbs.  These gave me the mixture that I was looking for.
« Last Edit: September 23, 2008, 08:00:03 PM by kslrr »
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline juan_carlito
  • Lost & Lovin It!
« Reply #17 on: September 04, 2014, 05:42:09 PM »
You said you used parts from pd50a and from pd50b in the same carb and it worked? Just curious as I have a set of each but the pd50a's were missing parts, so I picked up the b's to steal from. Got the air cut off valves, some non stripped screws, choke linkage spring etc… all work fine. But I have two possible changes now.
The #3 body on the A's has a stripped out bolt hole for the float goal so curious if I can sub the #3 body from the B set if I use all the jets etc from the A to keep things constant? Secondly I was wondering if I can use the slide/needle sets from the PD50Bs in my PD50As (except the #3 which would hopefully be the B body anyway)
Any feedback is appreciated. And sorry for jacking the thread, been reading online for days now looking for answers and got excited when I read you mixed parts lol. Maybe I'll start my own thread as well.
I bought a bike that didn't run to force myself to learn the ropes! She runs now ;)
Join me as I take my first ever bike and turn her into what I picture in my head!
https://www.youtube.com/juancarlitoonline
My Build Thread: http://forums.sohc4.net/index.php?topic=140963.0
-1979 CB650 (First bike-Bobber Project)
Offline kslrr
« Reply #18 on: February 21, 2015, 08:36:34 PM »
I used a combination from both carb types to get the mixture results that I wanted.  If you'r still interested, I can send you the details.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
  • Lost & Lovin It!
« Reply #19 on: May 14, 2015, 12:35:47 AM »
I am still interested as I am in the tuning phase now and having a hard time lol
Offline kslrr
« Reply #20 on: July 21, 2015, 07:00:44 AM »
Here is the progression of the carburetor setups that I used and settled on v2.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
