Author Topic: 1980 cb650 gas line size  (Read 1512 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: June 11, 2008, 10:14:45 AM »
is there a standard size...there is no markings on my current ones wanted to swing by autoparts store but doubt they will know...
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline Gordon
  • 750K1, 550K2
Re: 1980 cb650 gas line size
« Reply #1 on: June 11, 2008, 10:20:51 AM »
5.5mm
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #2 on: June 11, 2008, 10:22:44 AM »
If you can take a sample with you they can figure it out.  If not, measure the diameter of the petcock outlet.
It is either 1/4" or 3/16".  I ended up using both sizes with an in line coupler on my 650 since it is a combo of '79 carbs and '81 tank.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: June 11, 2008, 10:29:08 AM »
It's 5.5mm.  1/4" will work if you use hose clamps.
Offline cb650
« Reply #4 on: June 11, 2008, 04:11:22 PM »
I used 1/4 inch on my with only the spring clamps and it works fine.
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: June 11, 2008, 04:26:31 PM »
Fine, be that way! ;D ;D
Offline cb650
« Reply #6 on: June 11, 2008, 04:33:15 PM »
  I will   :D
