Author Topic: Wiring harness  (Read 5080 times)
holdfastgreg
Wiring harness
« on: June 26, 2008, 09:12:18 PM »
Well I finally finished wiring my buddies k1 cb750.  I suppose the next step is to figure out how to A) get a new harness or B) make a custom harness.  Any suggestions or comments?  I thought about using a painless wiring block like I've done on my SCCA cars.  I'm open to ideas and suggestions......
troppo
Re: Wiring harness
« Reply #1 on: June 27, 2008, 03:14:47 AM »
sounds like you know your way around the wires, i dont see why you cant build your own harness. Get a wiring diagram and you should be able to lay one up on a bike easy enough....
You`d only need coloured wires (make sure you label the colours and what they are for lol) plenty of connectors (buy a kit) and plenty of beers ;)
holdfastgreg
Re: Wiring harness
« Reply #2 on: June 27, 2008, 09:53:34 AM »
Yeah, thats gotta be the hardest part because some parts have wirings built into them.  I was hoping someone knew of a custom harness that already had the fuse block and relays wired in sorta like Painless.
Offline eastoak
Re: Wiring harness
« Reply #3 on: June 27, 2008, 10:05:45 PM »
Offline David
Re: Wiring harness
« Reply #4 on: July 08, 2008, 08:06:30 AM »
I am working on my CB750 K4 and  need to disconnect some of the wires leading to the rear end.  Is there an easy way to disconnect these wires at the connectors where it joins to the harness?  It feels like I will break the wires if I try to pull the connectors apart.
David
74 CB750
fuzzybutt
Re: Wiring harness
« Reply #5 on: July 08, 2008, 06:12:22 PM »
you can get a NEW oem harness from david silver spares for that 71 http://www.davidsilverspares.co.uk/parts/genuine-spares/part_7761/
