Author Topic: 1976 550F almost got it perfect.  (Read 1294 times)
Reavis_99
« on: July 16, 2008, 07:31:51 PM »
OK, just finished my bike and took it around the block.  It is a 1976 550F with stock 4-1 with an Emgo megaphone and Emgo pod filters.  I changed the main jets to 105's and reset the air/fuel mixture to 1 1/2 turns.  I started the bike and it idled great (around 1100rpm) I rode the bike up the road and everything was going great (choke was alittle on) once it warmed up I took the choke off and it wanted to die... so I put the choke back on alittle.  I made it to the 4th stop sign when the rpms started climbing????  It acted as if it was running with a high idle, but when I pulled the plugs they were black.  I cleaned them and then started again.  This time it acted as if it was starving for fuel surging up then down.  I know I am very close to getting the carbs and everything lined out, but I am still off alittle.  I have not raised my needle jets. What do you all think? I think I am running rich.  What should be my next thing to do?  Adjust the idle mixture or just raise the needle jet one notch? Should I run a hotter plug?
martino1972
Re: 1976 550F almost got it perfect.
« Reply #1 on: July 16, 2008, 07:47:50 PM »
fuel delivery to carbs is not obstructed???
Reavis_99
« Reply #2 on: July 16, 2008, 07:49:39 PM »
That was my next thought actually.  I am going to pull the carbs off again tomorrow.
martino1972
« Reply #3 on: July 16, 2008, 07:50:48 PM »
then check for fuel flow from the tank..
Reavis_99
« Reply #4 on: July 17, 2008, 06:37:05 PM »
Well I pulled the carbs off today and #3 cylinder was dry.  Now I am going to go through them again and then bench sync them.  While I have them apart I am going to raise the needle jet up one notch to lean the carbs out I am still running rich and I dont have enough idle air screw play to lean it out using it.  I hope this will fix all of my problems any other ideas?
martino1972
« Reply #5 on: July 18, 2008, 12:18:46 AM »
idle/air screw=0 to 1/4 trottle
needle         =1/4 to 3/4 trottle
main jet       =3/4 to wot(wide open trottle)
when you clean the carbs,read the carb forums here first,theres some well written info on how to do it right,make sure you pull the idle jets out aswell,as they are really hard to clean when they are in the carb...
Reavis_99
Re: 1976 550F got it perfect.
« Reply #6 on: August 01, 2008, 07:40:01 PM »
I have been able to ride my bike now and it is running great!!!!  I am so excited I will post some pics soon!
martino1972
« Reply #7 on: August 01, 2008, 08:54:42 PM »
thats good news......and,yeah....pictures...more pictures...lot's of pictures... :P :P :P
