Author Topic: Dumb float question  (Read 1189 times)
Offline zoo mob
Dumb float question
« on: August 29, 2008, 07:49:13 PM »
So, there's a thread below describing my woes, but when adjusting float height, would the mixture be richer with the floats sitting lower or higher in the bowl? In other words would a distance of over or under the recommended 26mm cause a rich condition? I feel dumb asking, but I can't wrap my head around this one. Thanks.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
ja_blur
Re: Dumb float question
« Reply #1 on: August 29, 2008, 08:45:29 PM »
float height only adjusts the amount of fuel in the bowl.
25mm would allow more.
27mm would allow less.
Offline OakBehringer
« Reply #2 on: August 30, 2008, 10:55:23 AM »
Not necessarily true.
If the fuel level is adjusted over a millimeter too high, this makes it easier for the engine vacuum to suck gasoline out of the float bowl.
The engine runs "soggy", it gargles on too much fuel at idle.
If the fuel level is adjusted over a millimeter too low, it's harder for engine vacuum to pull fuel out of the float bowl, so the engine
tends to surge and has an unstable idle RPM.
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
