Author Topic: CB500 Clutch question  (Read 1046 times)
Offline winnipeg550guy
« on: September 15, 2008, 08:38:49 PM »
When it comes to clutch tech I'm a little unsure of alot of things, main thing I'm unsure of is when bike is IN gear and I grab a handle full of clutch(engaged) should it still cause the rear wheel to spin slowly, If not (which I'm thinking it shouldn't), what could be the the issue.?
74\' 550k., 1965 Suzuki K15, 1978 BMW R80/7
Re: CB500 Clutch question
« Reply #1 on: September 15, 2008, 09:21:57 PM »
The clutch plates are in an oil bath.  Viscous coupling will make the tire rotate.  Should be able to stop it with the sole of your boot.  If the clutch is dragging more than that, then it needs servicing.
Cheers.
« Reply #2 on: September 15, 2008, 09:26:51 PM »
Cheers.
 Yes Indeed it does stop easily, thank you for clearing that up for me.
