Author Topic: 1971 CB500 rebuild.....  (Read 19844 times)
Offline DarkRider
Re: 1971 CB500 rebuild.....
« Reply #75 on: December 04, 2008, 03:28:32 PM »
http://www.benjiescaferacer.com/euroheadlightbucket.html  Perhaps this piece may just set you up with the look you are going for.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
« Reply #76 on: December 05, 2008, 08:09:12 AM »
There ya go!  that's what I was looking for....  thank you!!!!!
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #77 on: December 05, 2008, 08:31:45 AM »
That does indeed look the dogs bol***ks!
Bit expensive though (I know he has a business to run), would you make your own?
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #78 on: December 05, 2008, 08:53:38 AM »
Not sure... I could take an extra bucket and hole saw for the speedo... If memory serves correct...there wasn't much room behind the lamp (with all the wiring stuffed in there).  I wonder how he got around that issue with his bucket?
    • TVAM
« Reply #79 on: December 05, 2008, 12:11:47 PM »
If you look closely at his bucket, it's elongated to accommodate the body of the speedo. That's why you need the replacement headlamp ears that he supplies.
All in all, good value.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline papp101
« Reply #80 on: December 16, 2008, 11:51:41 PM »
Looking great man! My project has stalled due to unemployment. You would think it would provide MORE time, but in reality provides less.
I would think you could make a hole in the top of your headlight bucket, put the speedo in there as far as it will go, and bondo/fiberglass a cowl up to the rim to make it somewhat seemless, then attach some mounting points inside the speedo housing to match up with the original mounts on the speedo, perhaps? Paint to match and hopefully it looks cool.
« Reply #81 on: December 17, 2008, 07:14:53 AM »
Supp' PAPP!   sorry to hear about your situation... kinda scrounging for stuff to do as well...
The project's kinda been on hold waiting for my drilled rotorsend back from Anubis...  It's in the mail..just stuck somewhere between WI and WA.
I drilled the holes big enought (top and bottom) for the speedo... but I didn't check the direction of the headlight.  the speedo cable is straight..but my aim is about 2 feet infront of the wheel.  I have a spare that I'll use...( I should have used that for the test).
I'm gonna redrill untill i get the right...then measure off and drill the spare..  I'm contemplating bondo or rubber grommets...
Kinda sucks waiting for a part....  the whole project looses wind...   Lately, I've been playing with mod's for my KLR650..
Re: 1971 CB500 rebuild..... Master cylinder rebuild
« Reply #82 on: December 26, 2008, 09:28:19 PM »
ok....another dumb couple of questions.... but I'm stumped...
#1  I'm confused... how do I get the clip out?  where the heck is it? I've moved back the boot but can't seem to find it...
I have reviewed the exploded view....but can't seem to find...#3...
#2
when I put this pad in...it seemed to wobble...
does this need to be ground down?
#3
does this look correct? I'm guessing this little while spacer goes here???
« Reply #83 on: December 29, 2008, 09:54:38 AM »
Well... got the engine mounted yesterday.... still haven't found an easy way to do that.... a whole lot of cursin and bruises...
Here's what it looks like now....  still haven't figured out the brake questions...
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #84 on: December 29, 2008, 11:51:43 AM »
This is what I've found on this site and will soon be trying.
Place the engine on the ground laying on it's side.
While standing over the engine, position the frame and lower, taking care not to bump the freshly painted frame.
Once in position fasten in place and right frame. Install suspension and go ride.
Bike looks good. Keep it up.
FJ
« Reply #85 on: January 19, 2009, 06:53:47 AM »
been kinda slow on the cb500 project... have had a few things going on....  here's where it's currently...  still working on the brakes... next is the carb rebuild...
« Reply #86 on: January 19, 2009, 07:11:53 AM »
I know this is probably old hat to most.... but has anyone ran into the problem of the rubber "cap" curling over when you try to put the whole assembly back into the MC?  Should it be sprayed with lubricant?
it almost seems like the "cap" should be the other way around.... but I think I had it right, according to the manual.
« Last Edit: January 19, 2009, 07:22:13 AM by oldhondarider »
Offline papp101
« Reply #87 on: March 24, 2009, 08:28:25 AM »
Not sure, I know when I took mine apart it was completely disintegrated. Another 30$ gone. . .
« Reply #88 on: April 20, 2009, 01:02:13 PM »
Well.. I've rec'd some info from Papp.... Thanks man...
so I'm wrapping up the carb work... and on to the rewiring....  Here's where it's sat for too long.....
I've been trying to get this resurrected from a long winter  ( it doesn't want to kick over)
but none the less, i'm recommited to getting the 500 rebuilt and on the road as well as making the 750 a weekend rider....
« Last Edit: April 20, 2009, 01:04:32 PM by oldhondarider »
« Reply #89 on: April 21, 2009, 07:46:09 AM »
well.... with a helpful PM from Papp....  it think i've completed my first bench sync..... or at least I think i've completed it..
I stuck the 1/8" bit into the airbox side
and then adjusted the main screw
Then moved to the next one....#2
and then the adjuster....?
and continued to work my way down...
and shazam.... bench sync'd?
« Reply #90 on: May 12, 2009, 07:17:00 PM »
I think I might have something wrong here.... Is this backwards?
Offline MMICAFE
« Reply #91 on: May 12, 2009, 08:21:36 PM »
man what i would do is tap the races in with a dead blow hammer but dont hit one side a couple times then the other side a couple times to compensate just tap from one side to ther other and  make sure you dont damage the inner cup that the race sits on
1974 Honda CB450 super sport (sold sniff sniff) (my first bike)
1979 Honda CB650 (we have a love hate relationship)
2008 Honda metropolitan (sold kinda miss it for the gas mileage)
« Reply #92 on: June 01, 2009, 06:45:52 AM »
Well Papp.....  you got me motivated to get my 500 finished....   I think you're too far ahead of me....but I'll at least finish......
Here's some updated pics..
« Reply #93 on: June 01, 2009, 06:48:48 AM »
few more ;D
« Reply #94 on: June 23, 2009, 07:16:23 AM »
might be going another direction on the tank...
