Author Topic: 72 CB750 Cafe build  (Read 38518 times)
Offline captaincrash80
  • I better build something before I'm no longer considered a
  • Member #4842
Re: 72 CB750 Cafe build
« Reply #100 on: October 01, 2010, 03:13:09 PM »
I've got a picture similar to the first one in your last post, my '71 sitting new to a friend's CBR600. I love pictures like that  ;D
« Reply #101 on: October 16, 2010, 09:16:25 PM »
Bike is in the shop .. had to order some new intake manifold boots for it .. was part of the rough running for sure ..
Was also thinking of replacing the clutch plates .. the bike always wants to lurch forward .. slams in gear and won't go into neutral while stopped. .. . I've found a ton of sites that have aftermarket clutch plates but none that carry honda ones ..
Called the stealership and they wanted like 200$ for the set or something ridiculous.. You guys have another source for these or do you know a comparable aftermarket?
Before you spend $$ on new plates, go into the Thoughts of Hondaman and look up the clutch hub mods for these 750s. It makes them work much better. Also, synthetic oils, like Mobil 1 15w50 Diesel, really smooth out the gearbox and clutch, especially if the bike was sitting a long time before you got it running.
Did you install a new O-ring in the countershaft bearing holder when you had it apart? those get brittle and shrink, reducing oil flow to the mainshaft in the tranny: this makes for stiff shifting, too.
Offline 72hondacb750
« Reply #102 on: October 17, 2010, 01:04:14 AM »
I haven't done either of those things but after some research as usual you're advice seems fantastic.
Is the o ring in question the one in this diagram under number 16?
Also when you do your hub mod do you drill every level of the steel plates ? can only see a few levels of plates in this picture ..
Thanks.
I'll try and post more pic's tomorrow of the bike .. its has a new tail light and 1k more miles on it !
72 CB750 cafe project
« Reply #103 on: October 17, 2010, 09:32:17 PM »
That's the right O-ring.  :D  They are typically rock-hard and flat, leaking quite a bit.
The holes: you only need to add 4 new holes. Also chamfer the holes that are already there (on the inside of the hub). The new holes should go into the deep part of the spline so a clutch plate's tooth does not rest against a weakened rib at the site.
On the Pre-K4 bikes, the existing holes were a bit smaller and rough inside, so they plugged easily with crud over time. Although the K4-later holes were smoother in the bores, the ones at the back wall of the hub often were too high, well above the oil level in the spinning hub. If yours are like either of these, smooth the holes with a fast drill bit, and cut down the "wall" that prevents oil from entering the ones at the back wall of the hub. I also cut little oil-capturing grooves in front of each hole (from having roadrace tracks starve the plates from too much RPM), but you'd have to look in my book to see a picture of that trick.  ;)
« Reply #104 on: October 17, 2010, 10:41:23 PM »
Drilled it today .. Haven't ridden it much since but can already tell the difference ... the plates looked fine .. I'm so glad I didn't order new ones .. Thanks Hondaman for the $120 savings !
How do you recommend do it your self hole chamfering?
Here is a sample pattern of how I drilled it .. its not exact but seems right ? I made sure to drill where the steel disc where.
« Reply #105 on: October 17, 2010, 10:56:47 PM »
picture time .. here's some pictures of my new tail light .. its a honda 1000rr aftermarket light off ebay trimmed some and hung under the seat. You'll notice that I trimmed the fender bolt holes from the end of the frame and capped it to smooth things over. Just welded shut and painted with a rattle can.
This is a track stand I made with some scraps I had and some  $3 harbor freight wheels.
 Was thinking about getting a new tattoo .. :)
« Reply #106 on: October 18, 2010, 12:58:30 AM »
This is a audio clip of the bike from 0 to indicated 100mph .. probably more like 80mph real life ... ... This is carpy's yosh replica exhaust.. I like.
had to put pictures to it to make it work as a video on youtube.
« Last Edit: October 18, 2010, 12:07:56 PM by 72hondacb750 »
« Reply #107 on: October 18, 2010, 12:51:03 PM »
finally got the video added .. its just pictures with the audio of the exhaust but there it is ! ..
was thinking of pulling the baffle material out of it and doing another run to see the noise difference.
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #108 on: October 18, 2010, 12:56:05 PM »
Sounded damn good to me man
1975 CB750K
Project Back in Black
Offline Zig
« Reply #109 on: October 18, 2010, 01:21:25 PM »
sounds eggcellent!!
« Reply #110 on: October 20, 2010, 08:00:36 PM »
so today I replaced the o-rings in the oil pump and in the countershaft oiler. the difference is night and day. The shifting is smoother than ever. It goes right into neutral with no fighting at stop lights .. And my oil pressure is steady around 65lbs even at idle where it was close to 10lbs at idle before.
I'm going to do a full write up in the tips and tricks section on what all went down.
  • 1975 CB750K
« Reply #111 on: October 20, 2010, 08:35:41 PM »
Very cool glad u got that fixed
1975 CB750K
« Reply #112 on: October 20, 2010, 08:57:33 PM »
« Reply #113 on: October 28, 2010, 09:22:53 PM »
Good job!
Don't you love it when a plan actually comes together?  :)
Offline ryani
« Reply #114 on: October 29, 2010, 06:12:13 AM »
Love the tattoo idea.  I'm going to get new ink next sat.
Offline brandEn
« Reply #115 on: October 29, 2010, 07:09:21 PM »
Wow thats good info. I am looking forward to reading about your experience in the tips section. Now I gotta order some o-rings before I put my oil pump back in.
