Author Topic: Yet another swingarm swap question  (Read 1602 times)
Offline greenjeans
  • 1972 CB750K2
« on: December 10, 2008, 01:43:40 PM »
Ok, for the last hour and a half I've been going though swingarm posts and can't find the post that had year & models for easy swaps....
I have a 1972 CB750K
I would like to fit a longer swingarm on there without any machining etc...  pipe dream ?     Does anyone know definitively which years would bolt right up
to my '72 and be 1 to 2" longer ?    I plan to run the original drum on the back.
Can anybody point me in the right direction as to which year and model number I could search for ?
Thanks,  I'm back to the search....
« Last Edit: December 10, 2008, 02:03:41 PM by greenjeans »
Offline voxonda
Re: Yet another swingarm swap question
« Reply #1 on: December 10, 2008, 01:50:06 PM »
Think the F1 is longer, know for sure the F2 is longer. They both fit, at least to my knowledge.
Good luck.
Rob
Offline Geeto67
  • A grumpy
« Reply #2 on: December 10, 2008, 02:57:57 PM »
you can fit a DOHC swingarm. If you do a search there are pics. No machining but you do have to cut a few inches off the pivot. Rear spacers are up to you but you can figure it out with DOHC spacers since some of them share a wheel with the SOHC f2/3
Maintenance Matters Most
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: December 10, 2008, 05:27:08 PM »
When you say "cut off a few inches off the pivot"  what are you talking about ?
Is the DOHC frame wider by that much ??
Haven't searched DOHC swingarm yet....off to the archives
crustyxpunk
« Reply #4 on: December 10, 2008, 05:50:47 PM »
I threw my F2 swing arm on a 76 K model just fine and I know its longer than the one that came on the bike.
Offline Geeto67
  • A grumpy
« Reply #5 on: December 10, 2008, 06:25:34 PM »
really search is your friend, last post on the first page:
http://forums.sohc4.net/index.php?topic=34880.0
