Author Topic: creative choke solutions  (Read 1396 times)
Offline Mod Newb
  • Second bike, first build
« on: December 23, 2008, 10:05:31 AM »
Bought a 77 cb750k with a broken choke knob.  PO used a pair of pliers to pull up the choke; he just kept pliers under the seat and used them to pull the cable up whenever he started it.
I'd like to come up with a better solution.  I read somewhere about someone using a bicycle gear lever to do this.  Any other bright ideas out there in SOHC4 Land?
One thought I had was just to replace the carbs with another set off of a 70-76 cb750.  I believe that those years all had the choke lever on the side of the carb body.  Does anyone know how interchangeable these carbs are?  That way I could get rid of the choke cable all together.
1975 Honda cb500t
1977 Honda cb750k
Re: creative choke solutions
« Reply #1 on: December 23, 2008, 10:40:32 AM »
And you don't buy a replacement choke cable because....?
eldar
« Reply #2 on: December 23, 2008, 10:50:20 AM »
The knobs work ok. They do a good job in setting the choke and such but I have been looking for something mounted closer to the grip. A lot of bikes now have the choke on the left grip and you operate it with your thumb. Maybe check out some new bikes for ideas.
Offline Mod Newb
« Reply #3 on: December 23, 2008, 12:24:59 PM »
....because I'm an idiot.  ;D  And because of a couple (not so good) other reasons:
1. I like a minimalist set of controls/guages...that's why having a choke lever on the carb body is appealing...
2. I was curious if there were any more interesting ways that people on this forum had dealt with a similar issue; didn't find anything of the sort when I went searching...
3. For whatever stupid reason, the thought of replacing the choke cable never even crossed my mind. :-[
When I pull the choke cable up, it keeps slipping back down...Maybe I should just attach a pair of vice grips instead of pliers and keep pulling the damn thing up. ???  So much for minimalism.  ::)
1975 Honda cb500t
1977 Honda cb750k
Offline Deltarider
  • I'm back
« Reply #4 on: December 23, 2008, 12:34:46 PM »
Hear, hear, hear...
CB500K2-ED Excel black
Offline Mod Newb
« Reply #5 on: December 23, 2008, 12:58:23 PM »
Hear, hear, hear...
Yep.  Any clue if the earlier carbs are compatible with my K7?
1975 Honda cb500t
1977 Honda cb750k
