Author Topic: I lost my key.  (Read 6599 times)
Offline ASCSurveyor
  • Knee-Blaster
  • Bikes: '05 SV645, '77 CB750K
I lost my key.
« on: February 05, 2009, 05:42:49 AM »
So in the process of preparing to move the bike, I've realized that I don't know where my key is.   ???  The bike doesn't run yet, as I'll say I'm in the process of re-building it... but what would I have to do to get a replacement key made? Or heck... even just set the bike up so I don't even need a key?
'77 750K Rebuild Blog
http://mikeshondacb.blogspot.com/
Re: I lost my key.
« Reply #1 on: February 05, 2009, 05:44:03 AM »
WHAT BIKE?
Offline Bob Wessner
  • "Carbs Suck!"
Re: I lost my key.
« Reply #2 on: February 05, 2009, 05:45:48 AM »
Check www.hondakeys.com with your number (found stamped in the ignition lock). I would be surprised if you couldn't get a new set.
Offline Alan F.
Re: I lost my key.
« Reply #3 on: February 05, 2009, 05:47:08 AM »
A good local locksmith will be able to cut you a key by referencing the bike's year and model, and the key code on your ignition lock...maybe even your seat lock.
Check with your local guys first, it'll be faster and probably cheaper too.
Offline ASCSurveyor
  • Knee-Blaster
Re: I lost my key.
« Reply #4 on: February 05, 2009, 06:24:42 AM »
WHAT BIKE?
Crap.  Sorry.  77' 750K
Re: I lost my key.
« Reply #5 on: February 05, 2009, 06:26:44 AM »
If you are lucky there will be a number on the outside of the lock, problem with your year is you have to take off loads of stuff just to remove the lock!!
Offline goon 1492
  • Sucka Repellant
Re: I lost my key.
« Reply #6 on: February 05, 2009, 07:28:08 AM »
hondakeys.com +1 , I got three at 10 or 12 dolllars a piece.
Offline ASCSurveyor
  • Knee-Blaster
Re: I lost my key.
« Reply #7 on: February 05, 2009, 07:43:19 AM »
I plan on taking the bike completely apart anyway, so it shouldn't be too much of an issue.   ;)
Offline jason teamshralp
Re: I lost my key.
« Reply #8 on: February 06, 2009, 01:54:40 AM »
you could just replace it
http://crc2onlinecatalog.com/Index_Main_Frame.htm
Click on Electrical, then Ignitions.
They are $25 and I've ordered a couple of things from these guys and they are quick and reliable. I have some on my 550 and it's great.
Offline ASCSurveyor
  • Knee-Blaster
Re: I lost my key.
« Reply #9 on: February 13, 2009, 09:34:46 AM »
I was actually kind of hoping about this, and will probably go this route.
Although I'm not sure how I'm going to get the seat off with no key.   :-[
DirtyUnderWhere
Re: I lost my key.
« Reply #10 on: February 13, 2009, 09:39:45 AM »
I had the same issue with my 72 750 and I went with the ignition switch replacement. As for the seat lock, I wasn't going to use it anyway, so i drilled out the lock cylinder(doing no damage to the housing) used a screwdriver inserted into the hole to turn the lock mechanism, and removed the housing. My ignition switch was only like 12 bucks on ebay, and it came with two keys and works well.
Offline Blasbo
Re: I lost my key.
« Reply #11 on: February 13, 2009, 10:03:58 AM »
Took me a minute to find it.
http://www.sohc4.net/files/Cutting_your_own_keys.pdf
Works great.
A K7 comes apart a little differently though.
http://forums.sohc4.net/index.php?topic=39677.msg413711#msg413711
Offline ASCSurveyor
  • Knee-Blaster
Re: I lost my key.
« Reply #12 on: April 21, 2009, 06:24:41 PM »
Ok, so update... I know... I've been so busy trying to get the SV running again, I neglected the poor CB.  :(
Anyhoo, started tearing stuff apart today, to transfer the bike inside.
Anyway, I took off the top triple, and found this number:
It's on the locking mechanism.  Problem is, it doesn't look like any of the examples on the hondakeys.com site, and doesn't appear to match any sequence.  I'm stumped.  Is this the wrong number?  Do I need to tear something else apart?
Also, how hard is drilling out the lock for the seat?  Pretty easy?
Offline heffay
Re: I lost my key.
« Reply #13 on: April 21, 2009, 06:49:20 PM »
a word on the seat...
i'm going to put this out there, that if you lose a key... you can often get to the pins on the opposite side of the seat and/or the nuts that fasten the seat to the frame.
obviously not on all sohc4s... but i know at least a couple, maybe 3.
Offline GammaFlat
Re: I lost my key.
« Reply #14 on: April 21, 2009, 06:53:03 PM »
Avoid drilling out the lock for the seat.  With an open end (10mm) or possibly a wobbly socket, you can get at the latch on the seat and remove the two nuts that hold it down.
Here's a pic of my K8 with the seat about 1/2 inch from latched.
« Last Edit: April 21, 2009, 06:57:23 PM by GammaFlat »
K6
85 Goldwing
Offline heffay
Re: I lost my key.
« Reply #15 on: April 21, 2009, 06:53:52 PM »
oh yea!!  that's actually how i did it on the 400f!  same side as the lock even!
Re: I lost my key.
« Reply #16 on: April 21, 2009, 06:57:46 PM »
Heffay is right I had to wait for my keys but I took off the seat and the the lock cylinder so i could work on the bike. These were not high security.
Offline Ecosse
  • Member #4139
    • My 550 walk around video
Re: I lost my key.
« Reply #17 on: April 21, 2009, 06:59:35 PM »
contact hondakeys.com the guy might be able to help you. can't hurt to try.
1974 CB550K
                                  Your 1%er name
Offline ASCSurveyor
  • Knee-Blaster
Re: I lost my key.
« Reply #18 on: April 21, 2009, 07:00:43 PM »
I'm not worried about security either.  Seat will be replaced with something else anyway.  Thinking of going race tail.  Can the lock be done away with alltogether?
Offline uthinkimodd
Re: I lost my key.
« Reply #19 on: April 21, 2009, 07:04:09 PM »
there is an emergency hole on the bottom of the seat lock anyhow. so you can open it and take it off. you will still need it I think to keep your seat down but what I did was just take the tumblers out of the lock.
I know because I lost my keys the other day too.  :-\
Offline GammaFlat
Re: I lost my key.
« Reply #20 on: April 21, 2009, 07:05:01 PM »
If you take apart the lock, you can remove all the springs and tumblers making it open-able with any key, screwdriver, etc.
K6
85 Goldwing
Offline myhondas
  • Not really such a
Re: I lost my key.
« Reply #21 on: April 21, 2009, 07:22:56 PM »
My nephew lost the key to my resto bike. I was also able to get the seat latch off without a key. A lot of bike dealer's know of locksmiths that can make you up a new key with the code on the lock and they year/make of the bike. Just remember that it's the same key for the front fork lock if you still want to use that. The honda key site is expensive but a good last resort place to go if all else fails. I am using him to make me a set for my 64 C100 bike that I only have one key for.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
Re: I lost my key.
« Reply #22 on: April 21, 2009, 07:26:21 PM »
There's also instructions in the FAQ about how to make your own key.  Once you have everything ready to go, it should take less than an hour.
spwg
Offline Ecosse
  • Member #4139
Re: I lost my key.
« Reply #23 on: April 21, 2009, 07:32:00 PM »
that's some key! i liked hondakeys.com because i wanted honda keys and wanted perfect fitting keys. mine weren't expensive (well, maybe compared to a hardware store cut they were), had the nice 'honda' script, and fit sweetly. my frugal friends thought me nutty.
1974 CB550K
                                  Your 1%er name
Offline myhondas
  • Not really such a
Re: I lost my key.
« Reply #24 on: April 21, 2009, 07:37:53 PM »
Gee, I went to the main FAQ page and didn't find that thread. Maybe it got pulled.
Encosse, Wait... here is the other side. It is a very unusual key from what I hear.
« Last Edit: April 21, 2009, 07:46:30 PM by myhondas »
SOHC# 5105 11228
