Author Topic: Need a 76 or earlier CB 750 measurement.  (Read 828 times)
« on: February 11, 2009, 07:32:28 PM »
Need a Measurement  76 or earlier, on a bike with carbs on it & tank off.
I need to know how much higher than the 1 inch frame tube, the carb linkage rises at full open throttle.
If you take a piece odfstiff paper, notch for the backbone, you can set this on top of the 2,  1 inch braces and make a mark to indicate how high the linkage rises.
Anyone that can measure this, it would be much appreciated, I would have to put on different carbs to measure it myself.
Offline jaknight
  • ....Round Town Ride......
Re: Need a 76 or earlier CB 750 measurement.
« Reply #1 on: February 16, 2009, 07:30:38 PM »
Hello 754,
Hang tight until Tuesday, I will let you know,
~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline jaknight
« Reply #2 on: February 17, 2009, 04:54:34 PM »
Ok Frank,
I placed a 12" rigid scale across the top of the frame members and was able to tuck it under the arched frame member in the center that is directly behind the throttle linkage.
I measured from the bottom surface of the scale, which would relate to the top of the outside tubes.  With the throttle full open, I read .300"  ..................... for all practical purposes you could say it was .312" ............. which is 5/16 of an inch.
I sure hope this helps you out and gives you what you need.  :)
