Author Topic: 630 to 530 conversion  (Read 3058 times)
Offline torrinh
  • If you don't ride in the rain, you don't ride.
« on: February 15, 2009, 04:04:04 PM »
Hey guys,
so I just ordered the 530 conversion sprockets from Partsnmore, 15 tooth cf sprocket and 41 tooth rear. My question is: How many links to I need for my 530 chain? My feeling is 106. Am I warm?
1983 Kawasaki GPZ 750
1978 Honda CB750K w/ 1976 CB750F1 motor
1979 Suzuki GS550L
Offline moham
  • .fnord.
Re: 630 to 530 conversion
« Reply #1 on: February 15, 2009, 04:30:56 PM »
If it's for a 78K (I'm assuming from your sig at the bottom that it is) then read the last post in the following thread (posted in the FAQ). It's what I referred to when changing out to 530 on my Ocho.
http://forums.sohc4.net/index.php?topic=372.0
Dollar Bill Ya'll...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
« Reply #2 on: February 15, 2009, 05:23:11 PM »
Isn't the 15 /41 combo specified for a 630 chain or a chain with a 3/4 inch pitch?
A 530 is a 5/8 pitch chain.  So, the combo should be more like 18/48 or 17/48 sprockets, depending if you are going for acceleration, or lower cruise Revs.
 A 15 T 530 sprocket is going to be very small and make the chain bend a lot, thus wearing it out faster.  This is the kind of thing that makes holes in engine cases.
Offline moham
  • .fnord.
« Reply #3 on: February 15, 2009, 05:50:54 PM »
I changed to 18/48 per the thread I referenced. Looks like OP needs a couple new sprockets.
According to the model guide, 15/41 for ratio of 2.733 was stock set-up for K8.
78 750K-The Ocho
Offline torrinh
« Reply #4 on: February 15, 2009, 06:46:58 PM »
I think the diameter of the sprocket remains the same, but the teeth are cut for a 530 pitch chain. Hopefully. Anyone here use the Partsnmore 630 to 530 sprocket conversion for their k7 or k8?
1979 Suzuki GS550L
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« Reply #5 on: February 15, 2009, 08:47:36 PM »
Hi,
I have counted 103 links on my converted 630 to 530.....
Found real friends here !!!
Offline moham
  • .fnord.
« Reply #6 on: February 15, 2009, 09:01:53 PM »
I see what you mean on the partsnmore website listing those sprocket sizes as "530 conversion" but I couldn't find any hits on the search (for this site) to verify if it's accurate, which is kind of surprising. All of the searching I've done point to the 18/48 JT sprocket conversion, but I'm sure somebody that's used the partsnmore stuff will chime in. You could always call partsnmore to verify sprocket sizes and ask about chain size. I bought a 110 link o-ring chain for mine but I can't remember how many links I left off...
78 750K-The Ocho
« Reply #7 on: February 16, 2009, 01:37:00 AM »
That's impossible.  The roller valleys must be on 3/4 centers for a 630 chain and 5/8 centers for a 530 chain.
15 teeth have 15 valleys.  15 x .75 = 11.25 inch circumference.  15 x .625 = 9.375 inch circumference.
The 630 15T sprocket will have a 3.58 inch diameter, and the 530 15T sprocket will have a 2.98 inch diameter around the roller pivot centers.
The tighter you wrap a chain around a shaft, the faster it wears out.
Good luck!
Edit: teeth/valley error corrected.
« Last Edit: February 16, 2009, 03:08:08 AM by TwoTired »
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #8 on: February 16, 2009, 02:22:02 AM »
Lloyds right, different pitch chains have different diameter sprockets for a set number of teeth.  If you google it, you can find the various ISO standards, they tell you everything you need to know :D
I must pick you up on one thing there though Lloyd ;)
How can a 15 tooth sprocket only have 14 valleys?  Does the valley between the 15th & 1st teeth not count ???
1978 CB550 K3
1985 H100S
« Reply #9 on: February 16, 2009, 03:04:02 AM »
You're right.  I've been cutting wood lately where you make one less cut than the number of pieces you want.
I'll go back and edit my previous post.  I suppose I shouldn't be doing this stuff at 2 AM.  ::)
Offline CrisPDuk
« Reply #10 on: February 16, 2009, 03:47:06 AM »
That's it ::)
Edit your post and make me look like clueless numptie :(
I don't normally need help to do that either ;D
1978 CB550 K3
1985 H100S
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
