Author Topic: Tools...  (Read 4868 times)
Offline benly- ben
Tools...
« on: February 23, 2009, 03:30:02 PM »
1. Show off your toolbox (pics) If its a puni small one thats never tidy then be ashamed!!! ;D
2. Your fave tool?
3. the maddest mechanical tool that you`ve  ever saw?
Ben :D
"Youngest Member On The Forum! Joined When I Was 12!"
billybobobrain
Re: Tools...
« Reply #1 on: February 23, 2009, 03:49:18 PM »
2. Your fave tool?
Ben :D
RE: #3
It would have been awesome if it didn't break.
Offline benly- ben
Re: Tools...
« Reply #2 on: February 23, 2009, 03:57:22 PM »
did you make that?? or is that attempt ;D
and whats it for?
and what is your toolbox?
dont be afraid. the person with the smallest and messiest toolbox will be named and shamed ;D
My uncle is the worst you cannot find anything in his toolboxes I hate it.
In the oficcial sam green racing garage there is no clutter attall you can find any thing you want in no time.  8) 8)
Ben :D
Re: Tools...
« Reply #3 on: February 23, 2009, 04:01:12 PM »
Yes, when we tell you 5 times what it looks like ;D ;D ;D ;D ;D ;D ;D ;D OH!!!!!!! that 10mm ring spanner ;D ;D ;D ;D ;D ;D
Sam. ;)
billybobobrain
Re: Tools...
« Reply #4 on: February 23, 2009, 04:10:55 PM »
Yes I made it, It is a 15mm wrench cut in half and welded to half of a deep 14mm socket. It was for removing valve springs with the head on the motor, but I got impatient and after welding it put it in the snow @18 degrees f. and it over hardened I probably rate right up there with your uncle toolbox wise. I have 5 or 6 sets in one toolbox and my garage holds the rest. Only I can find the tools! ;D
Re: Tools...
« Reply #5 on: February 23, 2009, 04:27:17 PM »
Why do you want to take the valve caps off with the head on, the valves will fall in to the head, then you'll have to take the head off to retreive them ;D ;D ;D ;D ;D ;D ;D the idea was good though  :D :D :D :D :D
Sam. ;)
Re: Tools...
« Reply #6 on: February 23, 2009, 04:38:48 PM »
RE: #3
Turn the "handle" end 90 degrees and weld back on, or braze.  Oil quench, instead of snow temper.
Looks a good tool for changing springs a valve guide seals.  I
ll be making something similar for a 550.  Right after I make an air hose fitting for the spark plug hole.
Offline Gordon
  • 750K1, 550K2
Re: Tools...
« Reply #7 on: February 23, 2009, 04:55:15 PM »
Not if you know what you're doing. ;)
Re: Tools...
« Reply #8 on: February 23, 2009, 05:13:17 PM »
I can see what your saying Gordon but i think I'd let it smoke till it was ready for a full valve job and rebore.
Sam. ;)
Offline Caaveman82
  • Zippo
  • That'll do pig. That'll do.
Re: Tools...
« Reply #9 on: February 23, 2009, 05:18:31 PM »
Oh man, the title of this thread is very misleading.
I thought it was a political thread.  ::)
Re: Tools...
« Reply #10 on: February 23, 2009, 05:36:14 PM »
Offline rbmgf7
  • 2>4
Re: Tools...
« Reply #11 on: February 23, 2009, 05:55:00 PM »
weld a huge gusset for a backbone using some flat stock
Offline Gordon
  • 750K1, 550K2
Re: Tools...
« Reply #12 on: February 23, 2009, 06:33:46 PM »
Sam. ;)
But then you don't get to use a homemade tool.  Now where's the fun in that? ::)
Re: Tools...
« Reply #13 on: February 23, 2009, 06:52:35 PM »
Yes but homemade tools break, don't they booboobrain ;D ;D ;D ;D ;D ;D ;D
sorry Billy :D :D :D :D
Sam. ;)  only teasing with ya. ;)
Re: Tools...
« Reply #14 on: February 23, 2009, 07:00:32 PM »
TT, the snow treatment would likely harden it, not temper it.
At any rate tempering is a process that follows after hardening..
#2, this week it is the steering race puller I made on the weekend..soon it will be another..
Offline DammitDan
  • Prodigal Son
  • It lives!
Re: Tools...
« Reply #15 on: February 23, 2009, 07:22:07 PM »
I make hammers out of everyday objects on a regular basis.
Does that count?
CB750K4
Offline Gordon
  • 750K1, 550K2
Re: Tools...
« Reply #16 on: February 23, 2009, 07:35:14 PM »
Does that count?
Of course!
I make boomerangs out of tools fairly often.  The only problem is they never make the return trip! :-\
billybobobrain
Re: Tools...
« Reply #17 on: February 23, 2009, 08:15:21 PM »
Sam. ;)
You have to rotate the engine to keep the piston up then you can change valve guide seals, springs, and keepers with the head on.
You can only do two cylinders at a time, then rotate 180 degrees and do the other two.
Sam. ;)
I just intalled an 850 kit from cyclex but I couldent find a valve spring compressor to save my life so I got creative.
« Last Edit: February 23, 2009, 08:20:42 PM by billybobobrain »
billybobobrain
Re: Tools...
« Reply #18 on: February 23, 2009, 08:17:28 PM »
ROTFL!!!!!!!!!!!!!!!!!
Re: Tools...
« Reply #19 on: February 23, 2009, 08:20:21 PM »
Just stick a piece of rope in  there, then turn engine till rope pushes against valve. them remove keepers.. :o
 but everyone knows that dont they.. ???
billybobobrain
Re: Tools...
« Reply #20 on: February 23, 2009, 08:21:51 PM »
After I make my new tool that is exactly what I will do!  Thanks!
Offline Really?
Re: Tools...
« Reply #21 on: February 23, 2009, 09:06:42 PM »
#3 - a flamer at work.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Gordon
  • 750K1, 550K2
Re: Tools...
« Reply #22 on: February 23, 2009, 09:34:10 PM »
You can also use an air compressor to hold the valves up.  I employed that method once when replacing a broken valve spring on a Volvo P1800 for a friend.  Connect a compression tester fitting to your air hose and plug it into the spark plug hole.  It pressurizes the combustion chamber and holds the valves in the closed position.
Offline martino1972
  • and still a expert welder,period...
Re: Tools...
« Reply #23 on: February 23, 2009, 09:54:42 PM »
and...............haven't seen a single toolbox here yet............just imaging where this is going....halve a page furter we will be talking about the boobs from pam again....... ;D
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
Offline mark
Re: Tools...
« Reply #24 on: February 23, 2009, 10:31:42 PM »
why wait.
how about pam's..........
F you mark...... F you.
