Author Topic: What parts, if any, are exactly the same across all models?  (Read 9745 times)
Offline Gordon
  • 750K1, 550K2
Re: What parts, if any, are exactly the same across all models?
« Reply #50 on: April 09, 2009, 10:13:29 AM »
What about jets?
Mainjets.
Not even close. ;D
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #51 on: April 09, 2009, 10:15:21 AM »
Thats what I am here for you know~!
Glad to fulfill my job well here......
What about jets?
Mainjets.
No.
No.
Offline alltherightpills
« Reply #52 on: April 09, 2009, 10:22:16 AM »
The original tool kit?
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #53 on: April 09, 2009, 11:19:12 AM »
the 650 provides the exception for quite a few parts, actually... BUT: oil pressure sending unit? starter solenoid edit: i'm pretty sure that's different on the 650 actually)? STARTER MOTOR?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Soos
« Reply #54 on: April 09, 2009, 12:05:48 PM »
You're right paul, the 650 kills the similarities of parts from one size of CB to another pretty much outright.
The starter from the '74cb750 I had would not fit into a 650 case... I tried.
The battery?
Now if you were to omit the 650, I think you might find a few parts at least.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline heffay
« Reply #55 on: April 09, 2009, 12:07:41 PM »
NO OMISSIONS!   8)
Offline Peterbylt
« Reply #56 on: April 09, 2009, 01:06:21 PM »
The rubber part of the foot pegs and the Kickstand Spring.
The Nut behind the handlebars.
« Last Edit: April 09, 2009, 01:36:49 PM by Peterbylt »
1975 550F SuperSport
1975 GL1000 Goldwing
1979 CM400A Hondamatic
1981 GL1100 Goldwing
1985 CMX250C Rebel
Offline mystic_1
  • 1970 CB750K
« Reply #57 on: April 09, 2009, 01:23:28 PM »
How about.....
Keys.
mystic_1
- John Augustus Shedd
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #58 on: April 09, 2009, 01:41:51 PM »
not keys - three different varieties
inside headlight bucket connection pins? (pins only not the harnesses)
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #59 on: April 09, 2009, 01:46:46 PM »
I know! I know!
Shock Nuts!
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
« Reply #60 on: April 09, 2009, 02:19:11 PM »
Nope, at least 2 different sizes, dont forget the q was all Hondas not jusr 4's so thats 49cc stepthrough to 1700cc v twin (or bigger)
Offline heffay
« Reply #61 on: April 09, 2009, 02:21:34 PM »
you are wrong... i spelled it out... AND ITS IN THE SOHC4 FORUM!
Offline heffay
« Reply #62 on: April 09, 2009, 02:22:56 PM »
ok... uh... get your mind out of the 750 gutter!
ALL MODELS OF SOHC4
there you go... 6th post on first page
« Reply #63 on: April 09, 2009, 02:40:34 PM »
Sorry, its late hear and a crap week so brain in neutral, still at least 2 diff shock nuts tho'
« Reply #64 on: April 09, 2009, 08:06:19 PM »
Gordon has it right: 754 is half right (the 500/550 and 350F had 1034 bulbs, 750 had 1157 when they were new). Instrument lamps and idiot light bulbs were the same.
Instrument lamps on the K0 750 are same as the later ones with a totally different idiot light cluster?
Yep, they are all the same small-round 3CP lamps.  ;)
Kinda hard to find, though, as the Americanized ones have bigger globes and a different part number, otherwise the same wattage and lumens.
Offline 736cc
« Reply #65 on: April 09, 2009, 08:23:07 PM »
spark plugs
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #66 on: April 09, 2009, 08:26:53 PM »
spark plugs
Interchangable, but not the same stock from factory :)
No.
Offline Spanner 1
« Reply #67 on: April 09, 2009, 08:57:43 PM »
Us idiots are the only same parts across all SOHC models!!
« Reply #68 on: April 09, 2009, 10:03:53 PM »
Jeez guys, I can't believe everyone missed this - the friggen muffler bearings
OK guys, it has to be the fuses. What about fuel tank mounts? What do I win?
« Last Edit: April 09, 2009, 10:11:09 PM by Jerry Griffin aka Rxman »
« Reply #69 on: April 09, 2009, 10:27:06 PM »
I found this out lately, & Fun Jimmy saw part of it..
Between a 500-4, 400-4, and 750-4, leaving the backbone the same, the front mounts for tank fit, and the rear mounts are all very close, although on 750 lower rails and carb clearance creates problems.. The 400  tank fits the 750 better than the 500 one.
Offline paulages
  • 1976 cb735
« Reply #70 on: April 09, 2009, 10:46:09 PM »
mounts are different on the 650. and fuses went from short to long style. i do think you're right about the muffler bearings though. and blinker fluid too, right?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #71 on: April 09, 2009, 10:46:57 PM »
turn signal buzzer and horn? wheel bearings? come to think of it, the early sandcast 750s probably ruin as much as the 650s do...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline crazypj
  • I'm brill, me
« Reply #72 on: April 09, 2009, 11:14:24 PM »
 As this is a totally pointless post,
With a big hammer, welder, some machining, anything will fit any model, its just a matter of applying the correct amount of force.  ;D
 BTW, Kawasaki are the ONLY manufacturer who ever listed muffler bearings for their bikes, (the rubber bushings in the silencer mounts)
They are similar to the taper bushings in CB350, etc, handlebar /top yoke.
PJ
Offline 736cc
« Reply #73 on: April 10, 2009, 05:55:43 AM »
90206-250-000
...and I checked to make sure
« Last Edit: April 10, 2009, 08:16:24 AM by 736cc »
Offline markb
  • When I finish my current project I might be a
« Reply #74 on: April 10, 2009, 07:14:14 AM »
Are you sure that's a good number?  I couldn't find it for any Honda.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
