Author Topic: how much is too much blowby? (video included)  (Read 4448 times)
Re: how much is too much blowby? (video included)
« Reply #25 on: May 12, 2009, 01:05:12 PM »
i will check lowes, i am sad to say but we dont have an ACE and i love that store. How does seafoam help, by burning the oil?
Seafoam like so much of that stuff is a feel good "I did something" additive. If they put a different label on it, we could drink it and live longer. Probably have more regular BMs too.
It's supposed to tighten up loose things, loosen up tight things and make the exhaust smell better.
I use it all the time and love it.  I swear, my garden tractor was smoking so much my wife noticed and she doesn't care a whit for those things. Two doses of Seafoam and its good as new. As far as exhaust emissions, anyway. I swear.
Offline andy8190
« Reply #26 on: May 12, 2009, 01:07:58 PM »
hahaha thats awesome.... we call that the placebo effect in my field... give a kid a sugar pill and tell them its aspirin and they will swear the pain goes away in like 30 mins
Offline heffay
« Reply #27 on: May 12, 2009, 01:09:15 PM »
so your line of work is dosing little kids?   ;D
« Reply #28 on: May 12, 2009, 01:13:17 PM »
And if the child no longer complains of pain... it worked.   :D
But...SeaFoam works...I SWEAR!
Offline andy8190
« Reply #29 on: May 12, 2009, 01:22:34 PM »
haha no, i got my undergraduate degree in athletic training and worked at a highschool for a while. Never did it but i did want to try just buying sugar pills and giving them to kids when they complain and see how well they worked.
MCRider, how often and how much seafoam do you use?
« Reply #30 on: May 12, 2009, 01:26:26 PM »
Just follow the label instructions. Its like exercizing, I do it whenever I remember to.  :D
Or when I'm feeling guilty i haven't done any maintenence lately.
Offline andy8190
« Reply #31 on: May 12, 2009, 01:31:53 PM »
haha ok. I guess i need to buy it in bulk then haha
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #32 on: May 12, 2009, 05:31:07 PM »
This is my setup. It might work for you. Its on my 400F.
I was tired of all the moisture mucking up my air intake filter. >:(
Cheers
 LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline edbikerii
    • Gallery
« Reply #33 on: May 12, 2009, 06:01:48 PM »
There's nothing wrong with that amount of blow-by from your engine.  They all do about that much mist in the blowby.  If you are unsure of whether you need to do rings, then run a compression test, first dry, then wet.
The filter on the end of the breather tube is just to keep dirt in the air from getting into the oil.  Crankcase goes from pressure to vacuum whenever a piston goes down or up in one of the cylinder bores.  When it goes vacuum, it sucks in air, which if left unfiltered, will introduce airborne contaminants into the oil.
I did see the mist in your video, and I feel that it is perfectly normal.  Even brand-new engines produce some.  Sometimes brand-new engines actually produce MORE blow-by until the rings and bores are broken in.  That's why they all have PCV systems, breather filters in the airbox, or catch cans straight from the factory.
Some systems are more sophisticated than others.  The 77 CB550K airbox accomodates some oil separation which allows the oil to drain back into the crankcase after it separates from the blowby.  My 1986 GoldWing has a simple plastic oil separator/catch can which you must remove and drain whenever you change the oil.  Pretty much all cars use PCV, which sucks the blow-by back into the intake air and burns it, some after allowing the oil to condense out.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
